Dayton Audio TWC-0.25BK 0.25 cu. ft. 2-Way Curved Speaker Cabinet Pair Black
Brand:|Model: TWC-0.25BK|Part # 302-701
Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and bracing, gluing veneer, and finishing.
List Price$289.94
You Save25%
$218.00
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 302-701
  • Attractive curved-sided design is extremely rigid and reduces diffraction
  • Piano-quality black lacquer finish
  • .283 ft³ net internal volume
  • Sold in pairs
  • Exclusive baffle replacement system
  • Magnetic grill fasteners
If you want to create a loudspeaker without investing the time and money building one from scratch, these cabinets are the answer. Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and bracing, gluing veneer, and finishing. Using Dayton Audio speaker cabinets will guarantee superior results every time. 3/4" MDF side and back panel construction is reinforced by a 3/4" MDF "shelf" brace running vertically up the sides and across the top and bottom. The entire cabinet, including the rear, is covered with a piano-quality black lacquer finish that is extremely glossy and reflective. The baffle is 1" MDF with a black satin finish and rabbeted construction. It offers the flexibility of the B-REX replacement system and comes pre-finished without any driver cutouts. The grill is secured to the baffle by neo magnets in line with the machine screws that fasten the baffle to the enclosure. Two 1/4" holes on the back simplify installation of Dayton Audio knock-in binding posts. Attractive curved-sided design is extremely rigid and solid, with minimized panel resonance. Complete with baffles, hardware, and grills. Add crossover parts, port tubes, damping materials, binding posts, and your drivers to create a complete system rivaling the appearance of the most lavishly presented audiophile speakers.
Dimensions: 12" H x (7.5" Front, 4.5" Back) W x 11" D.
Note: Cabinet dimensions do not include grill
One of the most innovative features is the exclusive Baffle Replacement and EXchange (B-REX) system, which allows the front baffle to be easily removed for prototyping and construction. The satin black finish baffle has 4 pre-drilled holes for machine screws that line up with matching threaded inserts, to secure the baffle to the cabinet. The baffle can be installed or removed an infinite number of times. This is great for initial driver cutouts, allowing the work to take place on a piece of flat stock, rather than on a finished cabinet.
Thanks to the B-REX system, if you are uncertain whether your speakers are complete, the machine screws by themselves can be used to hold the baffle in place. Once you are ready to finalize the design, they then act as clamps too hold the baffle in place while your glue is setting. Blank baffles are available separately, allowing further possibilities in terms of using a single cabinet for multiple pairs of drivers. As you can see, the versatility offered by the B-REX system is unmatched in any other pre-finished cabinet!
  • BrandDayton Audio
  • ModelTWC-0.25BK
  • Part Number302-701
  • UPC844632059407
  • Product CategoryHi-Fi Speaker Cabinets
  • Unit of MeasurePR
    (2 Reviews)
  • Weight26 lbs.
View similar products to the Dayton Audio TWC-0.25BK 0.25 cu. ft. 2-Way Curved Speaker Cabinet Pair Black
in the Hi-Fi Speaker Cabinets product category.
Dayton Audio TWC-0.25BK 0.25 cu. ft. 2-Way Curved Speaker Cabinet Pair Black is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Great Value!Very strong construction. Beautifully finished. Great value. Recommended.
Date published: 2009-06-18
Rated 5 out of 5 by from What's your time worth?The build and finish of these cabinets is excellent. The pictures do not them justice, not by a long stretch. The gloss black is very smooth, very reflective, very close to a grand piano. The removable baffles are a big time saver during final assembly and easy access for tweaking the final crossover values. The pre-drilled terminal holes, the magnetic grilles, the hex nut baffle mounts, all great features that make these cabinets a bargain at the price.It could take someone days to produce something like this. What's your time worth?
Date published: 2008-02-23
  • 2016-02-08T06:21CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_302-701, PRD, sort_mostRecent
are these cabinets made from regular mdf or formaldehyde free mdf?
Asked by: wd88
These are made from standard MDF.
Date published: 2014-11-24
Will the new Esoteric 7" woofers fit in these cabinets and work perfect for midbass application from 80Hz-300Hz. Subs RSS315HFA from 80Hz down, mids faital pro W6N8-120 6" 300-2500Hz, tweeters Audax TW025A20 1" 2500Hz up.
Asked by: Fred Kelelr
The usable baffle width on this cabinet is about 6-1/2". The overall frame diameter of the ES woofer is just under 7", so the frame will overhang the round overs slightly. The volume will work well in order for the woofer to reach the desired 80 Hz, but you may want to consider the 0.38 cubic foot cabinets instead.
Date published: 2014-09-09
Can this accommodate RS150p and RS28F ?
Asked by: Ashd
Yes this will work well with those drivers.
Date published: 2014-03-17
What wall mount/floor mount will work with this enclosure?
Asked by: curiousmarc
Unfortunately we do not offer a wall bracket that will support the weight of these speakers. Any floor stand that will support 13-15 pounds will work.
Date published: 2013-05-14
Are these boxes big enough for these drivers:HiVi F5 5" Bass/Midrange?
Asked by: geekspeak
Yes these will work fine for the Hi-Vi F5 driver. I would recommend venting with a 1.5" diameter, 4" long port.
Date published: 2013-01-07
What is the thread on the bolts that hold the baffles on?
Asked by: planet10
The cap screws for these cabinets are a 4mm hex screw.
Answered by: RussR
Date published: 2011-10-10
  • 2016-02-08T06:57CST
  • co_hasquestionsanswers, tq_6
  • loc_en_US, sid_302-701, PRD, sort_recentQuestionsFirst
