Dayton Audio TW-0.75CH 0.75 cu. ft. 2-Way Speaker Cabinet Cherry
Brand:|Model: TW-0.75CH|Part # 302-732
Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and braces, gluing veneer, and finishing.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$198.17
You Save25%
$149.00
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 302-732
  • Very rich, real wood cherry veneer
  • .780 ft³ net internal volume
  • Exclusive baffle replacement system
  • Magnetic grill fasteners
If you want to create a loudspeaker without investing the time and money building one from scratch, these cabinets are the answer. Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and braces, gluing veneer, and finishing. Using Dayton Audio speaker cabinets will guarantee superior results every time. 3/4" MDF side and back panel construction is reinforced by a 3/4" MDF "shelf" brace running vertically up the sides and across the top and bottom. The entire cabinet, including the rear, is covered with a very rich, genuine cherry wood veneer with a semi-gloss finish. The baffle is 1" MDF with a black satin finish and rabbeted construction. It offers the flexibility of the B-REX replacement system and comes pre-finished without any driver cutouts. The grill is secured to the baffle by neo magnets in line with the machine screws that fasten the baffle to the enclosure. Two 1/4" holes on the back simplify installation of Dayton Audio knock-in binding posts. The cabinet is extremely rigid and solid, with minimized panel resonance. Complete with baffles, hardware, and grills. Add crossover parts, port tubes, damping materials, binding posts, and your drivers to create a complete system rivaling the appearance of the most lavishly presented audiophile speakers.
Dimensions: 17" H x 10" W x 12.5" D.
Note: Cabinet dimensions do not include grill
One of the most innovative features is the exclusive Baffle Replacement and EXchange (B-REX) system, which allows the front baffle to be easily removed for prototyping and construction. The satin black finish baffle has 4 pre-drilled holes for machine screws that line up with matching threaded inserts, to secure the baffle to the cabinet. The baffle can be installed or removed an infinite number of times. This is great for initial driver cutouts, allowing the work to take place on a piece of flat stock, rather than on a finished cabinet.
Thanks to the B-REX system, if you are uncertain whether your speakers are complete, the machine screws by themselves can be used to hold the baffle in place. Once you are ready to finalize the design, they then act as clamps too hold the baffle in place while your glue is setting. Blank baffles are available separately, allowing further possibilities in terms of using a single cabinet for multiple pairs of drivers. As you can see, the versatility offered by the B-REX system is unmatched in any other pre-finished cabinet!
  • BrandDayton Audio
  • ModelTW-0.75CH
  • Part Number302-732
  • UPC844632019036
  • Product CategoryHi-Fi Speaker Cabinets
    (4 Reviews)
  • Weight24 lbs.
View similar products to the Dayton Audio TW-0.75CH 0.75 cu. ft. 2-Way Speaker Cabinet Cherry
in the Hi-Fi Speaker Cabinets product category.
Dayton Audio TW-0.75CH 0.75 cu. ft. 2-Way Speaker Cabinet Cherry is rated 5.0 out of 5 by 4.
Rated 5 out of 5 by from Nice speaker enclosureThese are great enclosures for people that don't have time to make their own or don't know how. The cherry finish is beautiful. It is nice to have the front removable so you can cut your holes as needed. It is also nice because it is easy to add hurricane nuts or other threaded inserts for the driver mounting and easy to add insulation. One word of advice is to cover the enclosure with tape when working on it. I use the blue paint tape so it is easy to pull it off when done. I cover the whole front and back sides and then just the corners so the don't get scratched.
Date published: 2015-05-05
Rated 5 out of 5 by from Nice versatile box.I use this box with a Fostex 6.3" woofer and it is solid. The inside dimension of the grill height does require careful layout if building a front ported 2-way.
Date published: 2013-06-25
Rated 5 out of 5 by from Great ProductSolid build quality and value. These cabinets are beautiful and Sound wonderful.
Date published: 2008-04-20
Rated 5 out of 5 by from Outstanding quality and beautyI've purchased 5 cases in three sizes for a home theater system and am just blown away by the quality and look of these cabinets. Every joint is perfectly aligned, the cherry veneer is absolutely flawless, and the grill is simple but attractive. These cabinets compare with those found on speakers costing several thousand dollars. I highly recommend them.
Date published: 2008-03-05
  • 2016-02-11T06:24CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_302-732, PRD, sort_mostRecent
Should this enclosure be ported or can it be acoustic suspension? If ported should the port be on the front or the back?
Asked by: mactommy
This can be use for either application. Whether you port or not depends on the woofer you decide to use.
Date published: 2016-01-20
Can I fit the Dayton Audio DS215-8 8 woofer in this cabinet?
Asked by: mactommy
Yes, the usable baffle width is about 9" when you consider the round over on the edges.
Date published: 2016-01-15
What is the largest woofer you can put in this cabinet? Also I assume you have to cut to holes for the speakers.
Asked by: mactommy
The largest woofer the baffle will support is about 9" due to the rounded edges.
Would the Dayton Designer Series 6.5" woofer(DS175-8) or the Dayton 7" Aluminum Cone Woofer(DA175-8) work with these cabs in a ported 2-way?
Asked by: FMJnb
Yes, the DA175-8 will work well and the better option for you.
Answered by: MattW
Date published: 2015-04-24
Does Parts Express cut out the openings in the enclosures? I'm thinking about buying a couple of the enclosures in cherry and my eyesight isn't what it once was. I also don't have the proper tools to do that with.
Asked by: KI6POW
Unfortunately we do not provide a baffle cutting service for the baffles in these enclosures.
Date published: 2014-05-28
  • 2016-02-11T07:05CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_302-732, PRD, sort_recentQuestionsFirst
