Dayton Audio TW-0.50CH 0.50 cu. ft. 2-Way Speaker Cabinet Cherry
Brand:|Model: TW-0.50CH|Part # 302-722
Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and braces, gluing veneer, and finishing.
List Price$149.38
You Save25%
$112.32
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 302-722
  • Very rich, real wood cherry veneer
  • .494 ft³ net internal volume
  • Exclusive baffle replacement system
  • Magnetic grill fasteners
If you want to create a loudspeaker without investing the time and money building one from scratch, these cabinets are the answer. Dayton Audio pre-made enclosures eliminate the time-consuming and messy steps of cutting wood, assembling the panels and braces, gluing veneer, and finishing. Using Dayton Audio speaker cabinets will guarantee superior results every time. 3/4" MDF side and back panel construction is reinforced by a 3/4" MDF "shelf" brace running vertically up the sides and across the top and bottom. The entire cabinet, including the rear, is covered with a very rich, genuine cherry wood veneer with a semi-gloss finish. The baffle is 1" MDF with a black satin finish and rabbeted construction. It offers the flexibility of the B-REX replacement system and comes pre-finished without any driver cutouts. The grill is secured to the baffle by neo magnets in line with the machine screws that fasten the baffle to the enclosure. Two 1/4" holes on the back simplify installation of Dayton Audio knock-in binding posts. The cabinet is extremely rigid and solid, with minimized panel resonance. Complete with baffles, hardware, and grills. Add crossover parts, port tubes, damping materials, binding posts, and your drivers to create a complete system rivaling the appearance of the most lavishly presented audiophile speakers.
Dimensions: 14" H x 8.5" W x 12" D.
Note: Cabinet dimensions do not include grill
One of the most innovative features is the exclusive Baffle Replacement and EXchange (B-REX) system, which allows the front baffle to be easily removed for prototyping and construction. The satin black finish baffle has 4 pre-drilled holes for machine screws that line up with matching threaded inserts, to secure the baffle to the cabinet. The baffle can be installed or removed an infinite number of times. This is great for initial driver cutouts, allowing the work to take place on a piece of flat stock, rather than on a finished cabinet.
Thanks to the B-REX system, if you are uncertain whether your speakers are complete, the machine screws by themselves can be used to hold the baffle in place. Once you are ready to finalize the design, they then act as clamps too hold the baffle in place while your glue is setting. Blank baffles are available separately, allowing further possibilities in terms of using a single cabinet for multiple pairs of drivers. As you can see, the versatility offered by the B-REX system is unmatched in any other pre-finished cabinet!
  • BrandDayton Audio
  • ModelTW-0.50CH
  • Part Number302-722
  • UPC844632019005
  • Product CategoryHi-Fi Speaker Cabinets
    (2 Reviews)
  • Weight19 lbs.
View similar products to the Dayton Audio TW-0.50CH 0.50 cu. ft. 2-Way Speaker Cabinet Cherry
in the Hi-Fi Speaker Cabinets product category.
Dayton Audio TW-0.50CH 0.50 cu. ft. 2-Way Speaker Cabinet Cherry is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from I would buy againI used to build speaker cabinets but this time I ordered from PE and this is a great time saver.The cabinet is well constructed and looks flawless. I would recommend to have a clear tap over the surfaces before doing your work on it. Cut the driver hole, terminal cup, ... etc. Otherwise, your tools may scratch it.I am not sure the 4 small bolts can hold the baffle securely without any vibration. So my solution is to glue the baffle to the body to void the "Exchange Baffle" feature. I think I made the right decision.Overall, I am happy with the cabinets. I can complete my 2 speakers project within 1 day instead of a week like I used to do.Great product.
Date published: 2013-01-07
Rated 4 out of 5 by from Descent over allnice looking finish, well put together.easy to work with fully assembled. magnetic cover doesnt cover to the edges of the cherry so you need to have the whole thing put together like it is out of the box, which is why i gave it a 4/5. i used 2 cabinents with 2 200W speakers without the front cover(magnetic cover on) and is decent over all
Date published: 2011-10-10
  • 2016-02-07T06:34CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_302-722, PRD, sort_mostRecent
Is it possible to have cutouts for Dayton Audio drivers? I was considering the DC130A-8 midrange and the RS28F-4 tweeter.
Asked by: keith9422
This enclosure comes with blank baffles that will need to be cut for whichever drivers you want to use. This is something that the end user will have to do.
Date published: 2015-03-16
  • 2016-02-07T07:13CST
  • loc_en_US, sid_302-722, PRD, sort_recentQuestionsFirst
