295-420_ALT_0
295-420_ALT_1
295-420_ALT_2
Dayton Audio TIT400C-4 15'' Titanic Mk III Subwoofer 4 Ohm
Brand:|Model: TIT400C-4|Part # 295-420
To produce loud, hard hitting, deep bass in large home environments, you need to move a lot of air, and the Dayton Audio Titanic MKIII 15" subwoofer speaker will do just that!
Part # 295-420
  • Sturdy die cast frame keeps everything in perfect alignment
  • Stacked ceramic ferrite magnets provide massive motor strength
  • Extended pole piece keeps more voice coil wire in the magnetic field
  • Large diameter voice coil and under-spider venting handle the power
  • Kevlar-reinforced cone and large rubber surround allow full excursion
  • Manufactured in the USA
Optimized for a variety of enclosures, the Dayton Audio Titanic MKIII 15" speaker is THE driver when you are looking to build the ultimate home theater subwoofer! The Titanic MkIII sub will hit hard with deep, loud bass. Thanks to its large surface area and long excursion, the 15" MKIII will sweep over 3 liters of air!
  • Nominal Diameter15"
  • Power Handling (RMS)800 Watts
  • Power Handling (max)1600 Watts
  • Impedance4 ohms
  • Frequency Response19 to 500 Hz
  • Sensitivity88.7 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight136 oz.
  • Resonant Frequency (Fs)24.2 Hz
  • DC Resistance (Re)3.8 ohms
  • Voice Coil Inductance (Le)3.11 mH
  • Mechanical Q (Qms)6.75
  • Electromagnetic Q (Qes)0.52
  • Total Q (Qts)0.49
  • Compliance Equivalent Volume (Vas)5.46 ft.³
  • Mechanical Compliance of Suspension (Cms)0.17 mm/N
  • BL Product (BL)16.8 Tm
  • Diaphragm Mass Inc. Airload (Mms)253.9g
  • Maximum Linear Excursion (Xmax)20.5 mm
  • Surface Area of Cone (Sd)804.2 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.5"
  • Baffle Cutout Diameter14"
  • Depth7.8"
  • # Mounting Holes8
  • Sealed Volume2.43 ft.³
  • Sealed F342 Hz
  • Vented Volume5.28 ft.³
  • Vented F322 Hz
  • BrandDayton Audio
  • ModelTIT400C-4
  • Part Number295-420
  • UPC844632000553
    (35 Reviews)
  • Weight24.2 lbs.
View similar products to the Dayton Audio TIT400C-4 15'' Titanic Mk III Subwoofer 4 Ohm
Videos
