Dayton Audio TIT320C-4 12" Titanic Mk III Subwoofer 4 Ohm
Brand:|Model: TIT320C-4|Part # 295-404
The Dayton Audio TIT320C-4 12" subwoofer driver is the Mk III version of the incredibly successful Titanic Series. These USA-made drivers have won fame and respect for their ability to reproduce deep, clean bass response that suits most applications and tastes.
A restocked/refurbished, or Open Box unit of the product is available -- see it now
Part # 295-404
  • Sturdy die cast frame keeps everything in perfect alignment
  • Stacked ceramic ferrite magnets provide massive motor strength
  • Extended pole piece keeps more voice coil wire in the magnetic field
  • Large diameter voice coil and under-spider venting handle the power
  • Kevlar-reinforced cone and large rubber surround allow full excursion
  • Manufactured in the USA
Frequently Bought Together
The legend continues... we took our most popular subwoofer driver and improved both its power handling and performance. The Dayton Audio Titanic MkIII 12" subwoofer is ideal for most home theater environments and will produce prodigious amounts of output in just about any listening room. Works great in sealed or vented enclosures. This is the woofer of choice for most rooms, offering outstanding performance and a reasonable box size.
  • Nominal Diameter12"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance4 ohms
  • Frequency Response22 to 500 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight100 oz.
  • Resonant Frequency (Fs)24.9 Hz
  • DC Resistance (Re)3.1 ohms
  • Voice Coil Inductance (Le)2.79 mH
  • Mechanical Q (Qms)7.03
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.45
  • Compliance Equivalent Volume (Vas)2.27 ft.³
  • Mechanical Compliance of Suspension (Cms)0.18 mm/N
  • BL Product (BL)15.45 Tm
  • Diaphragm Mass Inc. Airload (Mms)225.6g
  • Maximum Linear Excursion (Xmax)18.7 mm
  • Surface Area of Cone (Sd)502.7 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.5"
  • Baffle Cutout Diameter11"
  • Depth6.33"
  • # Mounting Holes8
  • Sealed Volume0.81 ft.³
  • Sealed F347 Hz
  • Vented Volume2.58 ft.³
  • Vented F325 Hz
  • BrandDayton Audio
  • ModelTIT320C-4
  • Part Number295-404
  • UPC844632000522
    (28 Reviews)
  • Weight20 lbs.
View similar products to the Dayton Audio TIT320C-4 12" Titanic Mk III Subwoofer 4 Ohm
