Dayton Audio TIT280C-4 10" Titanic Mk III Subwoofer 4 Ohm
Brand:|Model: TIT280C-4|Part # 295-414
Building on the reputation of the MKII subwoofers, the Dayton Audio Titanic MKIII 10" sub driver excels at producing very clean and musical bass in a small speaker enclosure.
Part # 295-414
  • Sturdy die cast frame keeps everything in perfect alignment
  • Stacked ceramic ferrite magnets provide massive motor strength
  • Extended pole piece keeps more voice coil wire in the magnetic field
  • Large diameter voice coil and under-spider venting handle the power
  • Kevlar-reinforced cone and large rubber surround allow full excursion
  • Manufactured in the USA
Renowned for its abilities as a great small box subwoofer for home or automotive applications, the Dayton Audio Titanic Series TIT280C-4 10" subwoofer outperforms many 12" drivers! Reaping the benefits of the MKIII improvements, this woofer is now even better for medium-duty home theater applications in small-to-medium sized rooms. The small 10" format is perfect for multi-driver or multi-subwoofer situations. With an upgraded 2-1/2" voice coil and 18.7 mm of Xmax, this low frequency speaker is great for home and automotive applications in both sealed and vented enclosures.
  • Nominal Diameter10"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance4 ohms
  • Frequency Response28 to 400 Hz
  • Sensitivity85 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight100 oz.
  • Resonant Frequency (Fs)29.6 Hz
  • DC Resistance (Re)3.3 ohms
  • Voice Coil Inductance (Le)3.09 mH
  • Mechanical Q (Qms)7.34
  • Electromagnetic Q (Qes)0.47
  • Total Q (Qts)0.44
  • Compliance Equivalent Volume (Vas)1 ft.³
  • Mechanical Compliance of Suspension (Cms)0.19 mm/N
  • BL Product (BL)14.25 Tm
  • Diaphragm Mass Inc. Airload (Mms)156.1g
  • Maximum Linear Excursion (Xmax)18.7 mm
  • Surface Area of Cone (Sd)330.1 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter11"
  • Baffle Cutout Diameter9.33"
  • Depth5.8"
  • # Mounting Holes8
  • Sealed Volume0.34 ft.³
  • Sealed F358 Hz
  • Vented Volume1.05 ft.³
  • Vented F330 Hz
  • BrandDayton Audio
  • ModelTIT280C-4
  • Part Number295-414
  • UPC123456789
    (15 Reviews)
  • Weight2 lbs.
View similar products to the Dayton Audio TIT280C-4 10" Titanic Mk III Subwoofer 4 Ohm
