Dayton Audio SWC1-MA 1.0 cu. ft. Subwoofer Cabinet Maple
Brand:|Model: SWC1-MA|Part # 302-838
All SWC cabinets use the Dayton Audio B-REX removable/replaceable baffle exchange system. The 1" thick MDF blank baffles are custom-cut by the user to fit a given driver and amplifier, and are then fastened securely (permanently or not) into the enclosure.
List Price$264.40
Regular Price$198.80
You Save14%
Sale Price
$170.00
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 302-838
  • Net volume: 1.0 cu. ft.
  • External dimensions: 14" x 14" x 12-7/8"
All SWC cabinets use the Dayton Audio B-REX removable/replaceable baffle exchange system. The 1" thick MDF blank baffles are custom-cut by the user to fit a given driver and amplifier, and are then fastened securely (permanently or not) into the enclosure. These stout, CNC-cut boxes are constructed from 3/4" MDF side panels backed up by a 1" x 3" cross brace, resulting in a rigid, well-damped subwoofer cabinet. Finishes match the popular Dayton Audio speaker cabinets—polished gloss black lacquer, and lush natural cherry or maple hardwood. A new high-value textured black vinyl covering is available for projects that demand a more understated appearance while enjoying the benefit of greatly reduced cost. Note: These cabinets do not have cutouts for amplifiers or woofers—you will need to cut your own holes per your design. Each enclosure includes two black satin finish baffles (one each, front and back) with mounting hardware, a magnetically attached grill, and four rubber feet fastened by 6 mm barbed inserts. The barbed inserts are compatible with Dayton Audio cone spikes, available separately.
  • BrandDayton Audio
  • ModelSWC1-MA
  • Part Number302-838
  • UPC844632080968
  • Product CategorySubwoofer Speaker Cabinets
    (3 Reviews)
  • Weight28 lbs.
View similar products to the Dayton Audio SWC1-MA 1.0 cu. ft. Subwoofer Cabinet Maple
in the Subwoofer Speaker Cabinets product category.
Dayton Audio SWC1-MA 1.0 cu. ft. Subwoofer Cabinet Maple is rated 3.6667 out of 5 by 3.
Rated 4 out of 5 by from Pleasing to the eyes and earsPaired this with a Dayton reference 10" sub and a 250W plate amp. Very happy with the results. The cabinet is very solid and the natural maple finish is better than I expected.
Date published: 2013-02-12
Rated 3 out of 5 by from FlimsyInstalled a Peerless 830500 with 200W amp. at 80 Hz. cut off. A 20 lb. object danced off the cabinet's surface due to excessive vibration.Very undesirable .They are very beautiful and extremely well built .A cabinet with thicker walls and T bracing, top to bottom and side to side I would like to see.
Date published: 2011-03-14
Rated 4 out of 5 by from Ideal for modular projectsThese cabinets just happen to exactly fit a need I have for prototyping a modular build high end three way speaker- in this case, needing 1 cu ft enclosures for two 10" woofers on each side with a special tuning. As usual for Dayton audio cabinets, the build quality and finish is quite good; extra bracing is added easily, and with replaceable front and back panels, upgrades are a snap.
Date published: 2010-01-03
  • 2016-02-06T06:33CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_302-838, PRD, sort_mostRecent
Does the veneer match other PE cabinets?
I'm thinking of grabbing four of the 0.25 ft^3 curved maple cabs (linked below) and making some matching subs. These would work, but I want to be sure the finish would be the same - it's difficult to tell from the photos.http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=302-707&scqty=2
Asked by: technodanvan
These all come from the same supplier so the only difference in the finish will be the variance in the natural veneer itself.
Date published: 2013-04-15
Cabinet with two 10" Sub
Hi,It's possible put inside two 10" Subwoofer?Best Regards
Asked by: quiquas
They will have to be suitable for a small sealed enclosure (about .5 cubic feet each) and mounted on the top and bottom panels in order for this to work.
Date published: 2013-03-22
As is, does this cabinet have adequate sealing between the baffles and the cabinet or should I use additional measures to ensure a good seal?
Asked by: Lamberticus
Yes, the baffles don't just sit on those little wedges and the rim on the backside but actually have a profile which fits in to the cavity but also overlaps the outside ridge of the box for a complete seal.When I put mine together with the driver and the amp, I chose to seal the front panel with some glue but looking back at it I do not believe it would be necessary.Have fun, it's a great box.
Answered by: AudioRuso
Date published: 2013-02-01
  • 2016-02-06T08:04CST
  • loc_en_US, sid_302-838, PRD, sort_recentQuestionsFirst
