Dayton Audio Sub-Link XR 2.4 GHz Wireless Audio Transmitter Receiver System for Subwoofers
Brand:|Model: Sub-Link XR|Part # 300-580
The Dayton Audio Sub-Link XR is a versatile audio transmitter system to use with subwoofer, surround speakers, second zone speakers, or feed TV audio to an amplifier, wirelessly.
List Price$90.99
Regular Price$69.50
You Save15%
Sale Price
$59.00
Part # 300-580
  • Make any amplifier or powered subwoofer wireless
  • Compact size fits almost anywhere
  • Can be used for powered surround speakers
  • Optimized for use with subwoofers
  • Includes transmitter, receiver, and two USB power supplies with detachable cord
Installing a second audio zone or putting a subwoofer exactly where you want it can be a challenge if you can't run the proper cables. Renters and owners of finished homes may find in-wall cabling impossible.
The Dayton Audio Sub-Link™ Wireless Audio System solves wiring dilemmas, quickly and easily. Place your subwoofer in the location that provides optimal sound without worrying about a cable. Or, add a subwoofer to the rear of your listening space to spread out the low frequency effects of your favorite movies. Check the prices on long subwoofer cables, and you might find out that in addition to being more convenient, the Sub-Link is also more affordable!
For users hoping to add stereo zone capability to an existing A/V installation, the Dayton Audio Sub-Link Wireless Audio System extends the options and uses of your primary audio system. Use the Sub-Link to add powered speakers or passive speakers running off a local amplifier to your patio, pool area, or anywhere you'd like to enjoy music away from your primary A/V system. Connect the Sub-Link to your PC, TV, or streaming media player and send a signal to any stereo in the house.
Dayton Audio's Sub-Link Wireless Audio System includes one transmitter and one receiver, two 22" 3.5 mm stereo male to stereo male RCA adapter cables, two 22" 3.5 mm stereo male 3.5 mm to mono male RCA adapter cables, two 30" USB-A male to micro USB-B male charging cables, and two USB 5V DC, 2A power adapters.
Specifications: • Transmitter / Receiver operating voltage: 5V DC, 1A • RF frequency band: 2.404 to 2.467 GHz • Modulation: GFSK • Working distance: 12 meters (40 feet; unobstructed line-of-sight) • Transmitter power: ≤ 10 dBm • Transmitter input sensitivity: 700 mV @ 1% THD • Receiver sensitivity: -85 dBm • Frequency response: 15 to 20,000 Hz +1/-3 dB • Delay time: <25ms • THD+N: -60 dB @ 1 kHz. • Dimensions per unit: 2-5/8/" L x 2" W x 1/2" H.
Pairing: These units come paired from the factory, but if they become un-paired, follow these steps. Press and hold the button on one unit. Then, press and release the button on the second unit. Finally, release the button on the first unit and your transmitter and receiver will be paired.
Note: This product uses USB for power purposes only. This product does not connect to a computer for data purposes and will not act as a sound card for the transfer of audio.
  • Special Features2.4 GHz RF Wireless
  • ConfigurationSubwoofer
  • ColorBlack
  • BrandDayton Audio
  • ModelSub-Link XR
  • Part Number300-580
  • UPC848791000089
  • Product CategoryWireless & Bluetooth Speakers
    (33 Reviews)
  • Weight0.8 lbs.
View similar products to the Dayton Audio Sub-Link XR 2.4 GHz Wireless Audio Transmitter Receiver System for Subwoofers
in the Wireless & Bluetooth Speakers product category.
Dayton Audio Sub-Link XR 2.4 GHz Wireless Audio Transmitter Receiver System for Subwoofers is rated 4.6061 out of 5 by 33.
Rated 4 out of 5 by from ?Unintended Use?Received this product about 1 week before using it. We got it to attempt to link 2 portable PA systems in an outdoor environment. It operated sucessfully with unrestricted line of sight at 100 feet between the transmitting unit and the receiving unit. This was done to avoid laying a coaxial cable on the ground in a heavy foot and vehicle traffic area, or attempting to string coaxial cable between trees. We did not experiment to determine a maximum distance over which the system would operate since 100 feet was further than what we had origenally planned, and performance was in excess of what we expected. It would get a 5 star rating from us but reservations about previous reviews stating the USB power connections were subject to breaking has caused us to refrain from disconnecting the power supplies from their respective transmitter and receiver units (a minor inconvenience).
Date published: 2015-09-28
Rated 5 out of 5 by from Really WorksI am using this with a Dayton T amp and a set of JBL outdoor speakers. I did not want to drill holes and run speaker wire to our deck. I needed a couple of other small inexpensive cables to set it up the way I wanted. But for the last month, it has worked beautifully.
Date published: 2015-06-11
Rated 5 out of 5 by from Good overall value.I bought this to eliminate a hard wired connection to my subwoofer and it works extremely well. No worries as far as setup. No perceivable time delay, as noted in another review, when set up by my ONKYO AV receiver which has an automated speaker calibration routine. Inserting the wireless system into the subwoofer feed did not alter the prior settings established by my receiver when I reran the routine nor have I noted a change in the overall fidelity of the sub.I had hoped I could buy two and setup a stereo feed to a second zone but these operate on only one frequency and was told by my sales representative that the would interfere with each other. Not a deal breaker but it would have been nice to have the second system at The PE price.
Date published: 2015-05-25
Rated 5 out of 5 by from great for the moneyBought two sub 1200s because the 15s were out of stock, wish I would've waited it could use a bit more if your looking for the bass you had in your car when you were young this ain't gonna do it maybe two 1500s would be better but don't get me wrong there still pretty nice.and shipping is super fast
Date published: 2015-04-24
Rated 4 out of 5 by from Great Product, Just OK ManualBought this to connect a subwoofer near my favorite seat in listening room. Could not get product to work without contacting tech support. They responded quickly and accurately. Product manual should be improved to better explain set-up and trouble-shooting.
Date published: 2015-04-03
Rated 5 out of 5 by from Works As AdvertisedI bought the Sub-Link for a subwoofer in my home listening system and it worked perfectly after a quick 5-minute hookup. Doesn't get much easier than that. They even include a piece of double-stick tape to attach the receiver to the back of the speaker. I recommend this product to anyone that wants to avoid running wires to places you'd rather not and it will keep the wife happy as well.
Date published: 2015-03-21
  • 2016-02-13T06:35CST
  • co_hasreviews, tv_0, tr_33
  • loc_en_US, sid_300-580, PRD, sort_mostRecent
Is this item can fit to 220 VAC in Europe/Israel?
Asked by: Kennydan
The power adapters are 110 volt for this. They are usb powered though so you could supply your own usb power and still use it overseas if you like.
Answered by: Chrisf
Date published: 2016-02-04
I have a pair of these that I am using to send audio from my turntable to my receiver. I want to use another pair to send the audio from my receiver to my subwoofer. Will the 2 pairs interfere with each other?
Asked by: lanega
You can use more then one set as they can be paired separately. It may require pairing them a couple of times to find frequencies that are far enough apart.
Answered by: Chrisf
Date published: 2016-01-28
I have two 5 inch speakers and  10 inch sub, the master 5" does have a sub-out. Would this neat package serve as the one wifi device to get music over to the other end of a  room from my computor and have the sub covered too?
Asked by: Shirker
This is capable of transmitting two channel (stereo) sound. If you are transmitting from the sound card to the systems stereo input then this should do the job.
Answered by: Chrisf
Date published: 2016-01-27
I would like t to add an additional sub woofer to my home theater setup.  I am using a Denon AVR1508 HT Receiver that has only one subwoofer output.  If I were to use this product can I split the signal coming from the receiver sub output?
Asked by: ddlldrinc
Yes it can be split in order to install this system and a separate subwoofer.
Answered by: GregT
Date published: 2015-12-07
Could I use this device to connect a center channel to my system?
Asked by: Motel1016
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-12-09
I have a system that uses a wireless subwoofer. Can I use this device with the receiver only attached to another subwoofer and pair it with my current system? The system is the LG LAS851M.
Asked by: DFoxx
This system is only designed to pair to its mate so it is not compatible with any other system.
Answered by: Chrisf
Date published: 2015-12-08
  • 2016-02-13T07:29CST
  • co_hasquestionsanswers, tq_49
  • loc_en_US, sid_300-580, PRD, sort_recentQuestionsFirst
