Dayton Audio SUB-1500 15" 150 Watt Powered Subwoofer
Brand:|Model: SUB-1500|Part # 300-634
For those who like to turn it up! The Dayton Audio SUB-1500 15" powered subwoofer delivers massive, room-shaking bass in any room, even large home theaters. The 15" driver and 150 watts of power achieve stunning low-end impact and excellent control. The best value in bass!
List Price$299.99
You Save34%
$198.00
Part # 300-634
  • Enormous 15" heavy-duty, long-throw woofer
  • 150W amplifier with selectable auto-on feature for satisfying power
  • Downward-firing flared port design for clean, powerful bass
  • Perfect for large home theater rooms
  • Unobtrusive texture black vinyl finish cabinet with removable grill
Add thrilling low-frequency effects to your home cinema experience!
Big bass in big rooms means you need to move lots of air, and there’s no substitute for square inches! Dayton Audio’s SUB-1500 powered subwoofer features an enormous, heavy-duty 15" driver, for huge air movement and massive low end performance, plus an amplifier that combines 150 watts of house-shaking power with excellent control. The bottom-firing flared port bass reflex design reduces port noise at high output, for cleaner bass that blends more effortlessly with your system and room.
Onboard connectivity makes this an easy-to-add and easy-to-adjust solution
The amplifier additionally features low and high level inputs, plus high-level passthrough outputs, a phase reversal switch, separately adjustable subwoofer level control, an auto on-off switch (activated by an input signal), and an infinitely variable 12 dB electronic low-pass filter. The low profile enclosure with rounded corners, modern styling, and unobtrusive black vinyl finish will complement the décor of any home theater room.
Power and punch to spare, but from a ridiculously compact enclosure
Specifications: • Power output: 150 watts RMS • Frequency response: 23-140 HzBox design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch: 0/180 degrees • Power switch: On/Auto/Off • Power requirements: 120 VAC, 60 Hz • Dimensions (rubber feet included): 19-3/4" H x 19-1/4" W x 19-3/4" D.
Are you ready to cut the cord?
New! Add the 300-580 Dayton Audio Sub-Link XR wireless subwoofer kit to any Dayton Audio powered subwoofer, for limitless placement possibilities and great bass without wires! Click here to go wireless.
c|net: A maximum-fun subwoofer - March 26, 2014
  • Woofer Diameter15"
  • BrandDayton Audio
  • ModelSUB-1500
  • Part Number300-634
  • UPC848791001079
  • Product CategoryPowered Subwoofers
    (34 Reviews)
  • Weight60.0000 lbs.
View similar products to the Dayton Audio SUB-1500 15" 150 Watt Powered Subwoofer
in the Powered Subwoofers product category.
Dayton Audio SUB-1500 15" 150 Watt Powered Subwoofer is rated 4.6471 out of 5 by 34.
Rated 5 out of 5 by from Exelent SubI ordered this sub a week ago and the bad boy showed up at my home today.This beast is the best,look out Bose cause Dayton is passing you by.
Date published: 2015-12-30
Rated 1 out of 5 by from Very disappointing !I have auditioned this sub in my two channel stereo for about a year now (wife got it for me for christmas last year, 2014) and I am disappointed to say the least in its performance. 15" woofer in a huge box does not make for huge bass which should be expected from a sub of this caliber. No it is not a 500 dollar sub BUT I have had many a sub that are smaller in the same price range that will simply outperform this one.
Date published: 2015-11-08
Rated 5 out of 5 by from Fills the house!I've only had for a few weeks but I am happy so far. Went from an eight inch Yamaha(good for small room) to this and it does what the eight inch didn't and that is fill my house with sound. House is about 1500 square feet. I can't compare to other brands but I am happy.
Date published: 2015-11-02
Rated 4 out of 5 by from Good valueFor the money it sounds pretty good. Seems a little underpowered when listening to music but sounds good with movies. Overall I would recommend.
Date published: 2015-09-22
Rated 5 out of 5 by from Awesome value for the money, Get at least 2.I originally bought 2 of them than I figure 2 more would do the trick. Yes I have 4 of them in a 9.2 channel reciever with Y connections used on the SUB OUT. Room is bigger than most. I would suggest using the 180 degree switch as oppose to 0 and keep both crossover and gain at around 12 o clock posiitons. Front facing is best and near corner. My 4-12 inch upstairs Cerwin Vega's are better and go deeper and much tighter, but they also have 2 QSC Pro Power Amps on them...but for the price... you can't beat it the value of them.
Date published: 2015-06-10
Rated 5 out of 5 by from Have 2 stacked.They are a great value. I moved my HSU tower sub (12 in.) to another room where it is happy. I first got 1 a few months ago and then they went out of stock. My son bought a second one for my wife and my 25th anniversary (with her knowledge). The second one is stacked on the first. Our theater room has a 9 1/2 foot ceiling and is 18 feet wide and is open to the opposite kitchen wall 40 feet away. There are Three shelving units about 15 feet away from the media wall ( including all but the rear channel speakers) which are on the shelving units. It is a lot of area to fill with bass and the HSU was OK but not completely up to the task. As far as performance - the HSU goes just a bit lower - but with less output as you would expect with a smaller driver. I use my theater for movies of course, but I also listen to music. I'm very impressed with both the quality and quantity of bass that I'm getting from these woofers. They are also nicely finished and look good with my system. I have purchased drivers, crossovers, speaker kits and finished speakers from Parts Express over the years and these are the most fun!
Date published: 2015-05-27
  • 2016-02-08T06:17CST
  • co_hasreviews, tv_0, tr_34
  • loc_en_US, sid_300-634, PRD, sort_mostRecent
does it come with the correcet cords to hook up to my computer or will i have to buy that sepertaly
Asked by: bassbassbassbass
This subwoofer only includes the power cord, all other cords you may need for your application will have to be purchased separately.
Date published: 2015-12-22
Would you recommend this sub strictly for rap music/dubstep??
Asked by: lellon123
Once you have it dialed in right, this sub will rock anything you put to it. Dub step and rap sound good through it also, but home theater is where this sub shines!
Answered by: Jeffro4704
Date published: 2015-10-22
Hi: I have this sub. What is the ohm rating of the driver in the sub1500? The power rating of the amp. is 150 watts. Is that rating rms at 4 or 8 ohms? Would it be ok to use a higher rated amp. in this sub? Thanks!
Asked by: dvdphile
The woofer in this sub is 4 ohm. You could use a higher power amplifier, but we do not have the specific power rating for the woofer itself, so using a different amp will void the warranty on the woofer.
Date published: 2015-08-19
After reading information asked before me, would preamping before going into this plate amp add to the performance of this sub? Or would I be wasting time money doing so?
Asked by: Sevual26
The subwoofer output from a normal receiver is all you will need to get the most from this subwoofer.
Date published: 2015-04-17
What the max spl?
Asked by: Willie Earl
Not amazing. Its capable of playing decently loud but not a bassheads woofer. To me its amp clips too soon and is fairly weak.
Answered by: PsychoSnake
Date published: 2015-02-16
is this sub compatible with a vizio soundbar???
Asked by: bobbybomac1226
This depends. If the sound bar has a preamp or subwoofer output, this will work. If it does not have any outputs unfortunately this will not work with it.
Date published: 2015-02-11
  • 2016-02-08T07:00CST
  • co_hasquestionsanswers, tq_35
  • loc_en_US, sid_300-634, PRD, sort_recentQuestionsFirst
