Dayton Audio ST210-8 8" Series II Woofer
Brand:|Model: ST210-8|Part # 295-100
Dayton Audio's ST210-8 8" Series II woofer is designed and built in the USA to provide class-leading bass punch and definition. An 8" woofer with output rivaling that of many ten-inchers!
Part # 295-100
  • Large voice coil provides efficient, low distortion output
  • Unique suspension provides excellent transient response
  • Perfect for home and car audio applications
  • Made in USA
The Dayton Audio Series II Heavy Duty woofers feature natural sounding chemically treated paper cones that provide extra durability and long life. The combination of a heavy magnet structure, vented pole piece, bumped back plate, and large voice coil provides the Dayton Audio ST210-8 8" Series II woofer with excellent power handling capability, high efficiency, and very low distortion. Its unique suspension system consists of a rubber surround and large flat spider for superior damping characteristics and outstanding transient response. Made in the USA.
  • Nominal Diameter8"
  • Power Handling (RMS)180 Watts
  • Power Handling (max)360 Watts
  • Impedance8 ohms
  • Frequency Response45 to 3,000 Hz
  • Sensitivity90.1 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Magnet Weight38 oz.
  • Resonant Frequency (Fs)44.4 Hz
  • DC Resistance (Re)7.7 ohms
  • Voice Coil Inductance (Le)2.05 mH
  • Mechanical Q (Qms)9.08
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)1 ft.³
  • Mechanical Compliance of Suspension (Cms)0.44 mm/N
  • BL Product (BL)13 Tm
  • Diaphragm Mass Inc. Airload (Mms)29.5g
  • Maximum Linear Excursion (Xmax)5.55 mm
  • Surface Area of Cone (Sd)221.7 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.22"
  • Baffle Cutout Diameter6.95"
  • Depth3.8"
  • Bolt Circle Diameter7.87"
  • # Mounting Holes8
  • Sealed Volume0.35 ft.³
  • Sealed F396 Hz
  • Vented Volume1.03 ft.³
  • Vented F353 Hz
  • BrandDayton Audio
  • ModelST210-8
  • Part Number295-100
  • UPC844632000027
  • Product CategoryWoofers
    (38 Reviews)
  • Weight8.635 lbs.
View similar products to the Dayton Audio ST210-8 8" Series II Woofer
