BONUS ITEM INCLUDED
Dayton Audio SPA250 250 Watt Subwoofer Amplifier
300-803_ALT_0
300-803_ALT_1
300-803_ALT_2
300-803_ALT_3
300-803_ALT_4
300-803_ALT_5
300-803_ALT_6
Dayton Audio SPA250 250 Watt Subwoofer Plate Amplifier
Brand:|Model: SPA250|Part # 300-803
Engineered to provide flexibility, ample power, and reliability, the Dayton Audio SPA250 delivers high fidelity subwoofer amplification and is tailored for home audio and home theater audio systems.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$199.99
You Save30%
$139.80
Buy 4+$128.50
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 300-803
  • Switchable 6 dB @ 35 Hz bass boost
  • Mono Class AB output stage for solid, well defined output
  • Low-level and high-level inputs connect to any system
  • Manual, auto, or triggered on/off modes for compatibility with any automated system
  • Variable gain, crossover point and switchable phase controls optimize room integration
  • Switchable 120/240V input voltage
  • Energy efficient—draws less than 1 watt in stand-by mode
Bass boost or flat…you choose and the SPA250 delivers!
The Dayton Audio SPA250 subwoofer amplifier produces 250 watts of clean power output, and combines with a host of flexible user options to make it an unbeatable choice. A user-configurable bass boost circuit creates a 6 dB peak at 35 Hz, which allows sealed subwoofer designs and certain ported enclosures to achieve their optimum bass extension and maximum "flat" output.
Connects to almost any home audio system, and does it with ease
The SPA250 features RCA line level and banana jack speaker level inputs and outputs, automatic power-on that is triggered by any audio input signal, and a phase reverse switch to match the subwoofer to your room and your other speakers. A single amp can accept a stereo input signal and combine it into mono, which is preferred for sub bass reproduction. A preamp or receiver's LFE output may be connected to the SPA250's Left (mono) input. The internal low pass crossover is fully adjustable between 40 and 180 Hz, and of course the amp has built-in protection against internal and external faults.
We haven't run out of great features to talk about
• Variable low-pass filter at 24 dB/octave attenuation from 40 Hz ~ 180 Hz
• Switchable phase 0° (NOR) or 180° (REV)
• Variable gain MIN/MAX input voltage dependent
• Speaker level high-pass outputs 6 dB/octave at approximately 180 Hz @ 4 ohms, 90 Hz @ 8 ohms (i.e. 220 uF electrolytic capacitor)
• Line-level full bandwidth (10 Hz- 20 kHz) outputs/throughputs for adding or "daisy chaining" additional amplifiers
• Subsonic filter 12 dB/octave high-pass filter centered at 20 Hz
• Damping factor at rated power: 114 @ 100 Hz
Specifications: • Measured power output: 156 watts RMS into 8 ohms @ 0.1% THD, 252 watts RMS into 4 ohms @ < 1.0% THD • Signal to noise ratio: 90 dB A-weighted • Input impedance: 10.4K ohms • Bass boost: Switchable, 6 dB @ 35 Hz • Low pass adjustment: 40 Hz to 180 Hz • Phase adjustment: 0º (normal) 180º (reverse) • Power requirements: Switchable, 115/230 VAC, 50/60 Hz • Dimensions: 9-13/16" W x 9-13/16" H x 5" D • Cutout dimensions: 8-1/2" W x 8-1/2" H.
  • BrandDayton Audio
  • ModelSPA250
  • Part Number300-803
  • UPC844632094897
  • Product CategorySubwoofer Plate Amplifiers
    (166 Reviews)
  • Weight13.4 lbs.
View similar products to the Dayton Audio SPA250 250 Watt Subwoofer Plate Amplifier
in the Subwoofer Plate Amplifiers product category.
Dayton Audio SPA250 250 Watt Subwoofer Plate Amplifier is rated 4.4277 out of 5 by 166.
Rated 1 out of 5 by from Dead out of the boxUnit failed instantly upon first turn on. Upon performing a Google search, this is not uncommon for this unit.
Date published: 2016-02-03
Rated 4 out of 5 by from This Amp has some Bass OutputThe parts finish is excellent & everything operates smoothly. The IEC power cable fit tight in the port, other users had problems with it falling out. So that problem must have been taking care of by Dayton Audio. I didn't have a problem with any hum, but I did buy a Ground Loop Isolater for $9.80 (part # 265-012) just incase & I used it anyway to fix audio noise on my PC. I have had no problems with the Auto On feature & works just like its supposed too. The Bass Boost is in a very dumb area & has a very small switch. But this isn't a big deal anyway. The Bass Boost button is really for a sealed box settup to compensate for the dB loss at low frequency that a sealed box settup encounters. Just sett it & forget it for your subwoofer settup, turn it on for a sealed box settup & leave it off for a ported box settup. You can still use the Bass Boost button for a ported box settup if you like, but more than likely it will be to peaky or might over power your subwoofer. Some thing else people have said is that you can't use Banana Plug connectors on the High Level Inputs & Outputs, & that is not true. All you have to do is remove the plug in the center of the Binding Posts & the hole for use with Banana Plugs is right there. Also if you need to remove the spade connectors off the amps speaker wire, so you can connect a subwoofer with binding posts, you can do so without voiding the 1 year warranty. I had this problem when I went to install my subwoofer & it had binding posts instead & called Parts Express about my problem & they told me it was fine to remove the spade connectors if needed. The bass output on the SPA250 Plate Amp is most excellent & doesn't let you down one single bit. I built my own custom subwoofer settup & it ended up being a complete beast. The bass output is just wicked & is comparable to a car audio settup. It hits so hard & low when I listen to Dubstep, Rap, Industrial, & Black Metal music that it will distort your vision! I use it in my small bedroom only for listening to music on my PC & for playing video games on my Xbox 360 & Xbox One consoles. I totally recommend that you save yourself alot of money & build your own powered subwoofer. I use mine everyday for many hours straight & it gets a little warm & nothing more. Plain & simple this SPA250 Plate Amp has alot of bass output & is well worth your money. I totally recommend this amp to anyone who wants an excellent quality replacement or is building a custom made powered subwoofer for them self. I hope it will last me over 10 years of use & I will be most pleased. I would have given this product 5 stars if Parts Express would have given me the bonus item I was supposed to receive with this item, a Dayton Audio - Black Baseball Cap (part # 520-308) , but I'm only going to give it 4 stars because I never got the item.
Date published: 2016-01-15
Rated 4 out of 5 by from Good Value, some drawbacksThis amp works like it should. It is a good match for the 12" Dayton classic sub. I am happy with the combo.The base boost is internal, you need to remove a small plug on the inside of the amp to activate the boost. When installed this plug is inside of the enclosure. So, unless you want to remove and reinstall the amp, the boost is either permanently on, or permanently off.The auto-on feature is finicky. It will not power on at low volume. I made a few adjustments to my old AV receiver and it helped, but not a complete fix. When it powers off I get a noticeable thump.
Date published: 2016-01-09
Rated 5 out of 5 by from still going strong after a yearI bought this last winter to replace an amp in my 15 year old Velodyne 10" sub. Plate dropped right into place with no issue and has been working great ever since. Has more power than the original amp, and bass seems tighter as a result. Auto off occasionally makes a small pop, but auto on/off seems to work great otherwise. It's in a 5.1 system paired to a Mirage LCR soundbar and it blends very well after a bit of tuning and placement testing.We listen to music for several hours per day so it's on quite a bit ... but no quality issues so far. Great product for our use.
Date published: 2015-12-26
Rated 5 out of 5 by from Great Product. Exceeded My Expectations!After experiencing intermittent problems with my 10 year old HSU Research VTF-2 subwoofer, it was determined that the amplifier had failed. I was faced with the issue of purchasing or upgrading to a brand new sub, or replacing the amplifier, based on the advise of HSU tech support. After researching some of the popular home theater forums, I learned that the Dayton Audio SPA250 plate amplifier was a recommended replacement for the VTF-2 amplifier. It fit perfectly, as if it was made specifically for the HSU product. The screws lined up exactly with the subwoofer cabinet, the wires easily attached to the driver, and the entire installation took no more than 15 minutes. Added bonus - the price was $75 cheaper than the HSU replacement amp with free shipping, and it has 100 watts more power than the HSU amp. The HSU VTF-2 even sounds better, with a clearer, tighter sounding bass. Couldn't be happier!!
Date published: 2015-11-19
Rated 3 out of 5 by from Great amp! poor case...I bought this amp to replace a blown one on a Speakercraft Bassx dual 8 subwoofer someone gave to me. After I modified the box to accept the amp, I installed it as it was shipped to me, and tested it in my system. I immediately noticed a buzzing noise, even at low volumes, from the plastic inside case of the amp vibrating, and causing air to leak around and through the connections, switches, and heatsink on the back of the amp. I ended up removing the inside case and using black silicone to seal everything up. I reinstalled the amp without the plastic inside case, since it wasn't stiff enough to do anything anyway. The amplifier functions great now after several hours of chasing leaks.I would recommend a separate chamber to be built into a box if I were building one from scratch and using this amp.
Date published: 2015-11-03
  • 2016-02-11T06:26CST
  • co_hasreviews, tv_0, tr_166
  • loc_en_US, sid_300-803, PRD, sort_mostRecent
Can I connect this sub plate amp as follows?: line level input to sub amp from my TV (1/8" mini to RCA) line level output to separate power amp is full range? No filters? leading to main speakers?
Asked by: jackreynolds
Yes, the low level outputs are just a full range pass through so that will work well.
Answered by: Chrisf
Date published: 2016-02-09
I'm looking to buy this to power 2 to 4 Aurasound Bass Shakers, but how do I connect them to the amp? I see the positive and negative wires in the back but they have some kind of connector on them. Can I just cut the connector off and attach speaker wire?
Asked by: MikeLL
That is correct you can just remove the connectors or use a male faston type connector to attach to the black and red output wires on this amplifier.
Answered by: Chrisf
Date published: 2016-01-26
what is the best woofer that i can buy for my SPA250 amp plate? because my old one dry out and fell apart.
Asked by: FZGN
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2016-01-20
Hi I have one SPA250 amplifier and I want to use it to give power output to 2 Subwoofers (4 ohms & 256 RMS for each one) Q/ Can I use put my two Subwoofers in SERIE configuration to work successfully with the SPA250? and work with 156 watts into 8RMS ?
Asked by: Caesar
Yes this amplifier will work fine with an 8 ohm load like that.
Date published: 2016-01-07
I bought this amp & found out it has connectors that won't connect to my subwoofers speaker terminals because it has 5-way binding posts. Will I void the 1 year warranty if I cut them off so I can use this amp on the subwoofer I just bought with the amp?
Asked by: Pain for Fun 1980
No, cutting off the spade connectors is common and will not void the warranty.
Date published: 2016-01-05
Does the SPA250 subwoofer plate amp have a relay on it so it doesn't produce speaker thump when turned on or from waking up threw the auto on setting?
  • 2016-02-11T07:03CST
  • co_hasquestionsanswers, tq_144
  • loc_en_US, sid_300-803, PRD, sort_recentQuestionsFirst
Videos
