182-322_ALT_0
182-322_ALT_1
182-322_ALT_2
182-322_ALT_3
182-322_ALT_4
182-322_ALT_5
182-322_ALT_6
182-322_ALT_9
Dayton Audio Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-65" w/FREE HDMI Cable
Brand:| Model: LCD60-TM
Product Video
The Dayton Audio LCD60-TM tilting TV wall mount is designed to work with 37"-65" LCD and plasma TV displays using up to a VESA 600 mm x 400 mm bolt pattern. These TV mounts focus the attention on the television instead of the bulky mount.
  • Easy adjustable ±15° tilt places screen in the optimum viewing position
  • Solid steel construction—supports up to 175 lbs.
  • Quick installation, instructions and hardware included to get your TV mounted quickly
  • Universal mounting fits most screens
  • Patented Rail Clip™ for quick attachment of hanger feet to lower rail
  • Great replacement for the Dayton Audio LCD3260-TM LCD/Plasma Tilt Mount 32"-65"
  • UL® listed
182-322
Weight: 12.68 lbs.
IN STOCK
List Price$45.99
You Save35%
$29.80
Buy 4-19 $27.96
Buy 20-up$25.63
Part # 182-322
Shadow Mounts TV mounts from Dayton Audio place the focus on your flat panel television—not the television mount. By using an inconspicuous flat black finish, the TV mount virtually disappears behind the television display.
The LCD60-TM's heavy-duty, solid-steel construction provides you with peace of mind, knowing your HDTV investment is held securely in place for years to come. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices.
The Dayton Audio Shadow Mounts LCD60-TM is compatible with 37"-65" LCD and Plasma TV displays that use up to a VESA 600 mm x 400 mm bolt pattern. Note: Consult your TV's owners manual for VESA sizing information.
Note: Do not to exceed the weight limit of 175 lbs.
Dimensions and Specifications: • Mounting plate width: 32.36" (822 mm) • Mounting plate height: 9.25" (235 mm) • Mounting arm width: 1.375" (35 mm) • Mounting arm height: 20.87" (530 mm) • Tilt adjustment: ±15° • Minimum mount to wall distance: 3.1" (80 mm) • Mounting width supported: 50-770 mm • Mounting height supported: 50-480 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200, 400 x 400, 600 x 400 • Maximum weight capacity: 175 lbs. (80 kg) • UL® listed.
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV CapacityLarge (37" & Up)
  • BrandDayton Audio
  • ModelLCD60-TM
  • Part Number182-322
  • UPC844632082481
  • Product CategoryTV Mounts & Brackets
    (136 Reviews)
  • Weight12.68 lbs.
  • Case Qty4
View similar products to the Dayton Audio Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-65" w/FREE HDMI Cable
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-65" w/FREE HDMI Cable is rated 4.7132 out of 5 by 136.
Rated 4 out of 5 by from impressedI have installed 3 TV mounts beforehand I bought this one it has been the cheapest but by far the best quality one so far I was impressed on the quality
Date published: 2015-01-24
Rated 5 out of 5 by from Very solidIts a nice solid steel mount at a very reasonable price, just as good if not better than the $100 plus mounts found in stores. It comes with pretty much everything you need for mounting a tv.
Date published: 2015-01-01
Rated 5 out of 5 by from Great productlove it works great easy to install great quality love it
Rated 5 out of 5 by from Excellent product!Wall mount for my 50" TV. Excellent buy. I always buy from parts express. Products never fail me. Shipping was excellent. Arrived the same day as my TV.
Date published: 2014-12-26
Rated 5 out of 5 by from Happy customer!Product as described. Fast shipping. Good value. Happy customer.
Date published: 2014-11-30
Rated 5 out of 5 by from Tv wall mountAwesome products... This is my third one my favorite things are the price and durability.
  • 2015-02-27T06:51CST
  • co_hasreviews, tv_0, tr_136
  • loc_en_US, sid_182-322, PRD, sort_mostRecent
I have an LG 55LB5900 would this bracket work? It says it can use a bracket that is a 400x400 VESA.
Asked by: Dj2005
Yes this will work fine with that VESA mounting pattern.
Date published: 2015-02-20
What size are the 3 cutouts in the wall mount the technical drawing does not indicate this?
Asked by: fred0695
Each of the three openings in the mount are 7"W x 5"H.
Date published: 2015-01-19
Can I use this mount with a 42 inch toshiba tv? Model number of tv is 37AV502R.
Asked by: Heather777
Yes this will work fine with that TV.
Date published: 2015-01-05
Will this mount work for a Vizio Model #P702ui-B3 70" TV? The pattern on the tv is 400x400 which this mount supports, however the item description states up to 65" while the TV is 70"
Asked by: Mikey Dêép bass
As long as the VESA pattern is within the range (in this case it is) and the TV is under weight limit of the mount it will work fine.
Date published: 2014-12-18
Hello, if I send you a pic of a television bracket mount and adapter plate that I do not have a mfg name for, do you think you could possibly help me with telling what type it is and supplying me with the part as well.
Asked by: Doc P
Yes, please email our tech support at tech@parts-express.com.
Date published: 2014-12-11
I just bought a Westinghouse 40" t.v. that uses a vesa 200x200 mount. is this my best option for a wall mount? will it fit?
Asked by: philipdelcampo
If you only want the mount to tilt, this will work fine. The smaller version below will also work as long as the TV does not weigh more than 100 lbs.http://www.parts-express.com/dayton-audio-shadow-mount-lcd37-tm-tilting-tv-wall-mount-23-37-w-free-hdmi-cable--182-320
Date published: 2014-09-18
  • 2015-02-27T08:23CST
  • co_hasquestionsanswers, tq_13
  • loc_en_US, sid_182-322, PRD, sort_recentQuestionsFirst
Videos
Customer projects that include: Dayton Audio Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-65" w/FREE HDMI Cable
