Dayton Audio Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-65"
Brand:|Model: LCD60-TM|Part # 182-322
The Dayton Audio LCD60-TM tilting TV wall mount is designed to work with 37"-65" LCD and plasma TV displays using up to a VESA 600 mm x 400 mm bolt pattern. These TV mounts focus the attention on the television instead of the bulky mount.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$45.99
You Save35%
$29.80
Buy 4-19 $27.96
Buy 20+$25.63
Part # 182-322
  • Easy adjustable ±15° tilt places screen in the optimum viewing position
  • Solid steel construction—supports up to 175 lbs.
  • Quick installation, instructions and hardware included to get your TV mounted quickly
  • Universal mounting fits most screens
  • Patented Rail Clip™ for quick attachment of hanger feet to lower rail
  • Great replacement for the Dayton Audio LCD3260-TM LCD/Plasma Tilt Mount 32"-65"
  • UL® listed
Shadow Mounts TV mounts from Dayton Audio place the focus on your flat panel television—not the television mount. By using an inconspicuous flat black finish, the TV mount virtually disappears behind the television display.
The LCD60-TM's heavy-duty, solid-steel construction provides you with peace of mind, knowing your HDTV investment is held securely in place for years to come. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices.
The Dayton Audio Shadow Mounts LCD60-TM is compatible with 37"-65" LCD and Plasma TV displays that use up to a VESA 600 mm x 400 mm bolt pattern. Note: Consult your TV's owners manual for VESA sizing information.
Note: Do not to exceed the weight limit of 175 lbs.
Dimensions and Specifications: • Mounting plate width: 32.36" (822 mm) • Mounting plate height: 9.25" (235 mm) • Mounting arm width: 1.375" (35 mm) • Mounting arm height: 20.87" (530 mm) • Tilt adjustment: ±15° • Minimum mount to wall distance: 3.1" (80 mm) • Mounting width supported: 50-770 mm • Mounting height supported: 50-480 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200, 400 x 400, 600 x 400 • Maximum weight capacity: 175 lbs. (80 kg) • UL® listed.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV Capacity30" to 39",40" to 49",50" to 59",60" to 69"
  • BrandDayton Audio
  • ModelLCD60-TM
  • Part Number182-322
  • UPC844632082481
  • Product CategoryTV Mounts & Brackets
    (142 Reviews)
  • Weight12.68 lbs.
Dayton Audio Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-65" is rated 4.7113 out of 5 by 142.
Rated 5 out of 5 by from Incredible valueI was really impressed by the sturdy construction design of this unit. I could have paid 3 or 4 times more for a similar unit at a local big box store. The product far exceeded my expectations and Parts Express again had nothing but world class customer service.
Date published: 2015-11-13
Rated 4 out of 5 by from Wall Mount.Easy to set-up and very strong unit by Dayton I'm very happy with it.
Date published: 2015-05-18
Rated 5 out of 5 by from Best cheapest wall mounts I have ever bought.You can't beat the price to quality ratio. This is my 3rd one of different sizes. Love them. Way to install. Just order already.
Date published: 2015-05-14
Rated 5 out of 5 by from Easy to install and use.This is the same mount I've used before. It is the third one I have purchased and I'm thinking about buying one more.
Date published: 2015-03-28
Rated 5 out of 5 by from PhenominalI purchased this mount and found it to be probably the best that I have ever used for an above the fireplace mount.
Date published: 2015-03-15
Rated 4 out of 5 by from Great quality, great priceThis is the 5th TV mount I have gotten from part express. All have been great. For the money you can't beat them. Only thing about this one was when it came, the box said it only went to 60". I had a 65". But no worries, it worked just fine.
Date published: 2015-03-07
  • 2016-02-07T07:06CST
  • co_hasreviews, tv_0, tr_142
  • loc_en_US, sid_182-322, PRD, sort_mostRecent
If I purchased the Shadow mount NON TILTING mount and wanted to get the tilting mount, could I just use the brackets that come in the package for the tilting mount and not replace the wall plate?
Asked by: Jim the webguy
Yes. The wall brackets for both are the same, only the rails differ.
Date published: 2016-01-04
Is there any adjustment to how the monitor sits on this mount once the frame is hung on the wall, or do you have to get the exact right height?
Asked by: Rich B
The height adjustment can only be made when the TV is mounted to the rails for the mount, it cannot be adjusted once the TV is mounted unless you pull the TV off the wall.
Date published: 2015-07-06
All of the connections to my TV are on the back, and not recessed. Is there enough room between the wall and back of TV for the connections with this mount?
Asked by: egclassic1
The minimum "mount to wall" distance is 3.1"
Answered by: TomI
Date published: 2015-04-06
Is this made for use in mounting to brick?
Asked by: Friedyboy
yes but use the appropriate fasters for your brick surface.
Answered by: TomI
Date published: 2015-03-30
I have an LG 55LB5900 would this bracket work? It says it can use a bracket that is a 400x400 VESA.
Asked by: Dj2005
Yes this will work fine with that VESA mounting pattern.
Date published: 2015-02-20
What size are the 3 cutouts in the wall mount the technical drawing does not indicate this?
Asked by: fred0695
Each of the three openings in the mount are 7"W x 5"H.
Date published: 2015-01-19
  • 2016-02-07T07:26CST
  • co_hasquestionsanswers, tq_17
  • loc_en_US, sid_182-322, PRD, sort_recentQuestionsFirst
Videos
