182-322_ALT_0
182-322_ALT_1
182-322_ALT_2
182-322_ALT_3
182-322_ALT_4
182-322_ALT_5
182-322_ALT_6
182-322_ALT_9
Dayton Audio Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-60" w/FREE HDMI Cable
Brand:| Model: LCD60-TM
Product Video
The Dayton Audio LCD60-TM tilting TV wall mount is designed to work with 37"-60" LCD and plasma TV displays using up to a VESA 600 mm x 400 mm bolt pattern. These TV mounts focus the attention on the television instead of the bulky mount.
  • Easy adjustable ±15° tilt places screen in the optimum viewing position
  • Solid steel construction—supports up to 175 lbs.
  • Quick installation, instructions and hardware included to get your TV mounted quickly
  • Universal mounting fits most screens
  • Patented Rail Clip™ for quick attachment of hanger feet to lower rail
  • Great replacement for the Dayton Audio LCD3260-TM LCD/Plasma Tilt Mount 32"-60"
  • UL® listed
182-322
Weight: 12.68 lbs.
IN STOCK
List Price$45.99
Regular Price$29.80
You Save16%
Sale Price
$25.00
Part # 182-322
Shadow Mounts TV mounts from Dayton Audio place the focus on your flat panel television—not the television mount. By using an inconspicuous flat black finish, the TV mount virtually disappears behind the television display.
The LCD60-TM's heavy-duty, solid-steel construction provides you with peace of mind, knowing your HDTV investment is held securely in place for years to come. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices.
The Dayton Audio Shadow Mounts LCD60-TM is compatible with 37"-60" LCD and Plasma TV displays that use up to a VESA 600 mm x 400 mm bolt pattern. Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Mounting plate width: 32.36" (822 mm) • Mounting plate height: 9.25" (235 mm) • Mounting arm width: 1.375" (35 mm) • Mounting arm height: 20.87" (530 mm) • Tilt adjustment: ±15° • Minimum mount to wall distance: 3.1" (80 mm) • Mounting width supported: 50-770 mm • Mounting height supported: 50-480 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200, 400 x 400, 600 x 400 • Maximum weight capacity: 175 lbs. (80 kg) • UL® listed.
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV CapacityLarge (37" & Up)
  • BrandDayton Audio
  • ModelLCD60-TM
  • Part Number182-322
  • UPC844632082481
  • Product CategoryTV Mounts & Brackets
    (128 Reviews)
  • Weight12.68 lbs.
  • Case Qty4
View similar products to the Dayton Audio Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-60" w/FREE HDMI Cable
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount LCD60-TM Tilting TV Wall Mount 37"-60" w/FREE HDMI Cable is rated 4.7031 out of 5 by 128.
Rated 5 out of 5 by from Great DealThis is a simple, but high-quality mount that comes with all the hardware and even an HDMI cable. Simple to install and there are many holes drilled on the vertical supports so that it can fit almost any unit out there.
Date published: 2014-10-14
Rated 5 out of 5 by from The perfect fixed mount for a rock bottom priceThis mount is made of solid steel. Very high quality product. Best mount on the market for a 37-60" TV. The kit is VERY extensive and includes bolts and screws for nearly every situation. If you have a TV on the smaller side of this range but think you will ever move up in size, buy this one and be done with it.
Date published: 2014-09-26
Rated 5 out of 5 by from Great Buythis is the second one I have bought of this Item. It does everything I want and 1/2 the cost of other brands.
Date published: 2014-08-27
Rated 5 out of 5 by from good mountA good solid mount for my 50" plasma in my kids room - good price too!
Date published: 2014-07-18
Rated 5 out of 5 by from Best mount for the moneyI have probably installed over 100 of these mounts, and have been satisfied every time. the quality of the product is excellent and the ease of install is great. The mount has smooth movement up and down, even with TVs up to 70". The spring loaded locking feature on the bottom of the arms is very convenient as well. The included HDMI is a nice bonus too.My only wish for this mount (as well as most other brands) would be to have the back plate be 36" to fully span 3 studs. Only TVs that are ~38" or less would have an issue with the plate possibly being too wide, and if you are hanging a TV that small, this mount is more than you need.Spend a couple of extra dollars on this mount over those cheap ones on other sites and you will thank yourself in the long run.
Date published: 2014-05-12
Rated 4 out of 5 by from Easy to hang, great stout support for my plasmaI purchased a month ago and got right to work mounting to my plaster walls. There are plenty of holes for finding studs and the vertical supports can slide on the horizontal bracket to help center. The HDMI cable was a nice throw in, but please, make it a useable length next time - that is why I dropped you down a star.
Date published: 2014-04-24
I just bought a Westinghouse 40" t.v. that uses a vesa 200x200 mount. is this my best option for a wall mount? will it fit?
Asked by: philipdelcampo
If you only want the mount to tilt, this will work fine. The smaller version below will also work as long as the TV does not weigh more than 100 lbs.http://www.parts-express.com/dayton-audio-shadow-mount-lcd37-tm-tilting-tv-wall-mount-23-37-w-free-hdmi-cable--182-320
Date published: 2014-09-18
I have a samsung 55" 6000 series television.  Would this bracket be compatible?
Asked by: palba22
Unfortunately we do not have a direct cross reference for TV models. If the VESA pattern on the back of the TV is 600 x 400 or less and the TV weighs less than 175 lbs, this mount will work.
Date published: 2014-08-01
What is the spacing between the wall-side mount holes?
I'm mounting to a brick veneer wall, so I'm curious if the spacing between the two rows of holes for wall-mounting fall at a distance that would match my mortar joint spacing
Asked by: StupidNicknameRequirement
The center to center distance between the wall plate screw holes vertically is 7-1/8".
Date published: 2013-10-15
Will this work for a Samsung mod# es6100 smart tv?
Asked by: rockhound415
Look at the back of your TV. In the center of the back should be a square with 4 screw holes around it. If your set has this, it has what's known as the VESA mounting system. This mount is good for up to 60". Your model is a 6100. Is that 61" Read the manual in the resources download on the right side of the page for more detail on that and whether your TV's VESA size matches the capability of this mount.
Answered by: MarkAJH
Date published: 2012-08-17
Where is this product manufactured?
Asked by: pep1224
These mounts are made in China, just like every other brand of mount. They are made just as heavy duty and quality as the mounts sold in the big box stores for four times more money. I have used a couple hundred of these over the last few years, they are excellent.
Answered by: RAK Audio
Date published: 2012-06-21
Supports VESA 500 x 300 pattern?
Will this fit a 500 (wide) x 300 (high) VESA pattern for a Panasonic 60" plasma (TCP-60S30)? TV weight is 80 lbs.If not, could you recommend another mount stocked by PE?
Asked by: mjkirk12
Yes! This mount will support VESA sizes up to 470 high by 780 wide and weights up to 175 lbs.
Answered by: JoeW
Date published: 2012-02-08
Videos
Customer projects that include: Dayton Audio Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-60" w/FREE HDMI Cable
