Dayton Audio Shadow Mount THIN3260 Super Slim TV Wall Mount 32"-60"
Brand:|Model: THIN3260|Part # 182-348
Mounting your TV should be a quick, simple process... and it is with the Dayton Audio THIN3260 super slim Shadow Mount! In minutes your TV will be mounted less than half an inch off the wall.
List Price$24.99
You Save37%
$15.80
Buy 4-19 $14.25
Buy 20+$12.98
Part # 182-348
  • Holds TVs less than 7/16" off the wall
  • Installs in minutes
  • Durable cold steel construction
  • Great for picture perfect installations
  • Works great for point-of-purchase displays and portrait display applications
  • UL® listed
HDTV mounting systems should all be this easy to install! In a matter of minutes, you can be enjoying your wall mounted TV. The super slim design holds your TV as close to the wall as possible for a custom look. Built into each TV bracket is a spring loaded clip that locks your TV in place onto the mounting rail. Removing the TV for adjustment or cable connection is quick and easy using the included release draw cord.
Specifications: • Mounting rail dimensions: 33.5" W x 2" H • TV mounting bracket dimensions: 1.75" W x 17.5" H • Distance from wall to back of TV: 0.4" • VESA sizes supported: 50 mm x 50 mm to 800 mm W x 400 mm H • Maximum weight capacity: 150 lbs. • UL® listed.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeFixed
  • Mount StyleWall Mount
  • TV Capacity30" to 39",40" to 49",50" to 59",60" to 69"
  • BrandDayton Audio
  • ModelTHIN3260
  • Part Number182-348
  • UPC844632094989
  • Product CategoryTV Mounts & Brackets
    (6 Reviews)
  • Weight3.8 lbs.
View similar products to the Dayton Audio Shadow Mount THIN3260 Super Slim TV Wall Mount 32"-60"
in the TV Mounts & Brackets product category.
