Dayton Audio Shadow Mount LCDCM60 Single TV Ceiling Mount with Tilt 32"-60"
Brand:|Model: LCDCM60|Part # 182-330
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. By using an inconspicuous flat black finish, the mount virtually disappears behind the display. Ceiling mounts are a great option for commercial and industrial settings.
List Price$72.99
You Save33%
$48.64
Buy 4-19 $46.22
Buy 20+$44.65
Part # 182-330
  • Ceiling mount rotates 360°
  • Adjustable tilt for optimum viewing angle
  • Flat black paint virtually disappears
  • Exclusive Rail Clip™ feature eliminates clumsy set screws
  • Anti-bend, double-lock design nearly eliminates column flexing
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. Heavy-duty, solid-steel construction provides you with peace of mind knowing your HDTV investment is held securely in place for years to come. Ceiling mounts are a great option for placing an HDTV in commercial and industrial settings. Adjustments are accomplished on the mounting arms by a quick turn of the knob, no tools required. The patent-pending design with the exclusive Rail Clip™ feature eliminates clumsy set screws while the heavy spring tension holds your television securely in place with simple finger-tip control. Each model features a locking system for security, anti-bending support on the included ceiling plate, and a double locking column to virtually eliminate flexing. Lag bolts, concrete anchors, Phillips head mounting screws (M4, M5, M6 and M8), safety bolts, and easy-to-follow instructions are included. Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Column: 1.5" dia. x 21.5"-32.5" L • Mounting bracket: 32.1" W x 9.4" H • TV bracket: 1.375" W x 13.8" H • Height adjustment: 21.5" -32.5" mount to ceiling. • Tilt adjustment: 20° • Rail Clip attachment • Mounting width supported: 50-770 mm • Mounting height supported: 50-480 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200, 400, 600 x 400 • Maximum weight capacity: 175 lbs. (80 kg).
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeSwivel / Tilt
  • Mount StyleCeiling Mount
  • TV Capacity30" to 39",40" to 49",50" to 59",60" to 69"
  • BrandDayton Audio
  • ModelLCDCM60
  • Part Number182-330
  • UPC844632084652
  • Product CategoryTV Mounts & Brackets
    (6 Reviews)
  • Weight18.8 lbs.
View similar products to the Dayton Audio Shadow Mount LCDCM60 Single TV Ceiling Mount with Tilt 32"-60"
in the TV Mounts & Brackets product category.
