182-328_ALT_0
182-328_ALT_1
182-328_ALT_2
182-328_ALT_3
182-328_ALT_4
182-328_ALT_5
182-328_ALT_6
182-328_ALT_7
182-328_ALT_8
Dayton Audio Shadow Mount LCDCM37 Single TV Ceiling Mount with Tilt 23"-37"
Brand:| Model: LCDCM37
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. By using an inconspicuous flat black finish, the mount virtually disappears behind the display. Ceiling mounts are a great option for commercial and industrial settings.
  • Ceiling mount rotates 360°
  • Adjustable tilt for optimum viewing angle
  • Flat black paint virtually disappears
  • Patented Rail Clip™ feature eliminates clumsy set screws
  • Anti-bend, double-lock design nearly eliminates column flexing
182-328
Weight: 15.45 lbs.
IN STOCK
List Price$65.99
You Save35%
$42.66
Buy 4-19 $38.78
Buy 20-up$35.55
Part # 182-328
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. Heavy-duty, solid-steel construction provides you with peace of mind knowing your HDTV investment is held securely in place for years to come. Ceiling mounts are a great option for placing an HDTV in commercial and industrial settings. Adjustments are accomplished on the mounting arms by a quick turn of the knob, no tools required. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices.
Each model features a locking system for security, anti-bending support on the included ceiling plate, and a double locking column to virtually eliminate flexing. Lag bolts, concrete anchors, Phillips head mounting screws (M4, M5, M6 and M8), safety bolts, and easy-to-follow instructions are included. Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Column: 2" (50.8 mm) dia. x 59" (1500 mm) L • Mounting bracket: 20.7" (525 mm) W x 9.4" (240 mm) H • TV bracket: 1.375" (34.9 mm) W x 13.8" (350 mm) H • Height adjustment: 17-3/4" (450 mm) from 2 ft. mount to ceiling, to 3.45 ft. mount to ceiling • Tilt adjustment: 20° • Rail Clip attachment • Mounting width supported: 50-480 mm • Mounting height supported: 50-330 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200 • Maximum weight supported: 100 lbs. (45 kg).
  • Mount TypeSwivel / Tilt
  • Mount StyleCeiling Mount
  • TV CapacityMedium (24" ~ 36")
  • BrandDayton Audio
  • ModelLCDCM37
  • Part Number182-328
  • UPC844632084645
  • Product CategoryTV Mounts & Brackets
    (3 Reviews)
  • Weight15.45 lbs.
View similar products to the Dayton Audio Shadow Mount LCDCM37 Single TV Ceiling Mount with Tilt 23"-37"
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount LCDCM37 Single TV Ceiling Mount with Tilt 23"-37" is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Worked Great!This mount was used to hang a 32" LCD TV in a corner of a porch.The length and tilt were just right for easy viewing. The easy on & off TV clips makes it real easy to remove before a storm. Used a Sony media box to stream videos via Wi-Fi
Date published: 2012-07-04
Rated 5 out of 5 by from Great TV Mount for the money!Purchased this mount for a flat screen I was installing in my unfinished basement. Wanted it to have the capability to swivel so I could view it from different areas - the ceiling mount was the perfect answer for this. At first the mount felt a little cheap when I assembled it, but once it was hung and the TV mounted to it, everything tightened up and felt secure. Infinite adjustments - up/ down, tilt, and 360 swivel.
Date published: 2012-07-02
Rated 5 out of 5 by from T.V.MOUNT-PROFESSIONAL LOOKING -HIGH TECHTHIS CEILING MOUNT WAS EASY TO INSTALL AND LOOKS GREAT. I CUT THE POLE DOWN THROUGH A DROP TILE CEILING OVER A GUEST BEDROOM IN BASEMENT. IT TILT SO MUCH THAT I CAN SEE T.V. PERFECT- WITHOUT 3 PILLOWS.GREAT PRICE TOO.RETAILERS WANT 200 BUCKS OR MORE WHEN YOU BUY A T.V BUT I,M SMARTER .I KNOW ABOUT PARTS EXPRESS.
Date published: 2012-01-19
advertized to fit 37" but product specs/TV capacity says 24' to 36" . I have a 37" class JVC Emerald LED series , will this fit?
Asked by: Rickibus
As long as the weight limit and TV VESA mount size is within the limits of the mount itself it will work.
Date published: 2014-01-02
Customer projects that include: Dayton Audio Shadow Mount LCDCM37 Single TV Ceiling Mount with Tilt 23"-37"
