Dayton Audio LCDART Articulating Arm TV Wall Mount Up To 30"
Dayton Audio Shadow Mount LCDART Articulating Arm TV Wall Mount Up To 30" LCD
Brand:| Model: LCDART
Shadow Mounts from Dayton Audio place the focus on your flat panel television or monitor—not the mount. The LCDART articulating arm mount is designed to work with VESA standard 50, 75 and 100 mm HDTV/monitors.
  • Extruded aluminum construction allows for up to 10" extension from wall
  • Unobtrusive finish disappears behind the LCD TVs
  • Mounting hardware and instructions included
  • ±90° of pan and swivel adjustment
  • ±12° of tilt adjustment
182-370
Weight: 3.02 lbs.
IN STOCK
List Price$50.99
You Save61%
$19.40
Buy 4-19 $17.64
Buy 20-up$16.17
Part # 182-370
Shadow Mounts from Dayton Audio place the focus on your flat panel television or monitor—not the mount. By using an inconspicuous flat black finish, the mount virtually disappears behind the display. Heavy-duty, extruded aluminum construction provides you with peace of mind knowing your HDTV investment is held securely in place for years to come. Articulating arms free up valuable desk space occupied by stand mounted TVs or monitors. Home, office, or commercial applications benefit from the ability to pull the 13"-30" HDTV into the proper viewing position when in use, and pushing it back to a stored position when finished. The LCDART features a total of 180° pan, 180° of swivel, 24° of tilt, and can extend the TV or monitor up to 10" from the wall. Standard VESA mounting sizes of 50, 75, and 100 are supported. Lag bolts, concrete anchors, Phillips head mounting screws (M4, M5, M6 and M8), safety bolts, and easy-to-follow instructions are included.Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Wall bracket: 2.6" (65 mm) W x 7.1" (180 mm) H • Articulating arm: 0.5" (12.7 mm) W x 9.8" (248 mm) L • TV bracket: 4.6" (116.9 mm) W x 4.6" (116.9 mm) H • Pan adjustment: ±90° • Swivel adjustment: ±90° • Tilt adjustment: ±12° • Extension length: 0-10" (0-254 mm) • Supported VESA sizes: 50, 75, 100 • Maximum weight capacity: 33 lbs. (15 kg).
  • Mount TypeFull-Motion Articulating
  • Mount StyleWall Mount
  • TV CapacityMedium (24" ~ 36")
  • BrandDayton Audio
  • ModelLCDART
  • Part Number182-370
  • UPC844632067822
  • Product CategoryTV Mounts & Brackets
    (14 Reviews)
  • Weight3.02 lbs.
View similar products to the Dayton Audio Shadow Mount LCDART Articulating Arm TV Wall Mount Up To 30" LCD
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount LCDART Articulating Arm TV Wall Mount Up To 30" LCD is rated 4.4286 out of 5 by 14.
Rated 5 out of 5 by from Now that is what i am talking about!!As usual, i am impressed but not surprised.This is one nice mount!Solid and lots of adjustments.Winner!!!
Date published: 2014-08-21
Rated 5 out of 5 by from Small Screen Wall Bracket by DaytonI've used this bracket before . "Bang for the buck , You CAN'T beat it " . No matter what it is , if it's Dayton It's always GOOD !
Date published: 2013-10-22
Rated 5 out of 5 by from Great Mount !!!For the simplicity of the picture showing this mount, and the low price, (even at your prices !! ), I was concerned this TV mount might not work, but your description seemed like just what i wanted.. It holds my 24" television perfectly and articulates flawlessly.My wife wanted it on the wall in our exercise area, and this is small and is completely hidden by the Television... Easy to install...Only problem was the wall piece is drilled for mounting on a 2 x4 wide way ( 4" ) side...so in a standard wall 2 screws will be in the stud and two need anchors...No biggie.. It's solid as can be...Great Mount and great price.
Date published: 2012-02-06
Rated 5 out of 5 by from Another Stellar product from Dayton!!!Got this mount the other day and wanted to install it on my desk instead of the wall.I built an 3/16 thick by 2 1/2 wide L Braket. The L bracket was 12"x12". The L bracket went under the desk and to mount of the screen. I love this little guy. I got a 25" lcd monitor on it and it works great. The only thing I wish it could do is, that you could tilt it with undoing the big nuts in the back and retighting them.Either way it works awesome for the money. If you got a nice computer system(sound) this will make browesing the web some much nice and easier.Do yourself a favor and MOVE UP in the world and clean off your desk, the way it should be.
Date published: 2011-10-18
Rated 5 out of 5 by from Like so much I adapted to larger LCDThis is a great little mount at a great price. The only problem is I wanted to use in on a Panasonic that was VESA 200x100 LCD in the bedroom. Went over to local hardware got an aluminum inch and a half wide by 8th inch thick strip cut it in two and drilled holes to fit the wall mount to my wider mount screw holes. Bingo it's worked for over a year now perfectly. The weight is now so light on the larger screens no need for a heavy duty wall mount bracket. Must be willing to do a little DIY.
Date published: 2011-10-04
Rated 4 out of 5 by from High quality mount depending on your applicationThis is a very sturdy mount and the only negative I have to say is the fact that the arm is about a foot long. So if you want your TV closer to the mounting surface than a foot get a differnet mount. Otherwise it has great utility in that the arm will give you 180 degrees of rotation about your mounting point.
Date published: 2010-01-27
Will it fit my 20" TV-see attached picture
The two sets of holes are 1- holes are 4" square and the other is a 3" square.
Asked by: Oldman
Yes, you should be able to use either set of holes. I'd suggest using the 100mm (4") pattern.
Answered by: RussR
Date published: 2011-07-06
What is the closest to the wall the tv can be placed?
Asked by: nulatitude
The minimum distance from the wall is 1-5/8"
Answered by: Chrisf
Date published: 2011-03-02
Customer projects that include: Dayton Audio Shadow Mount LCDART Articulating Arm TV Wall Mount Up To 30" LCD
