Dayton Audio Shadow Mount LCD60-TM Tilting TV Wall Mount 37"-65"
Brand:|Model: LCD60-TM|Part # 182-322
The Dayton Audio LCD60-TM tilting TV wall mount is designed to work with 37"-65" LCD and plasma TV displays using up to a VESA 600 mm x 400 mm bolt pattern. These TV mounts focus the attention on the television instead of the bulky mount.
List Price$45.99
Regular Price$29.80
You Save19%
Sale Price
$24.00
Part # 182-322
  • Easy adjustable ±15° tilt places screen in the optimum viewing position
  • Solid steel construction—supports up to 175 lbs.
  • Quick installation, instructions and hardware included to get your TV mounted quickly
  • Universal mounting fits most screens
  • Patented Rail Clip™ for quick attachment of hanger feet to lower rail
  • Great replacement for the Dayton Audio LCD3260-TM LCD/Plasma Tilt Mount 32"-65"
  • UL® listed
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the television mount. By using an inconspicuous flat black finish, the TV mount virtually disappears behind the television display.
The LCD60-TM heavy-duty, solid-steel construction provides you with peace of mind, knowing your HDTV investment is held securely in place for years to come. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices.
The Dayton Audio Shadow Mount LCD60-TM is compatible with 37"-65" LCD and Plasma TV displays that use up to a VESA 600 mm x 400 mm bolt pattern. Note: Consult your TV's owner's manual for VESA sizing information.
Note: Do not to exceed the weight limit of 175 lbs.
Specifications: • Mounting plate width: 32.36" (822 mm) • Mounting plate height: 9.25" (235 mm) • Mounting arm width: 1.375" (35 mm) • Mounting arm height: 20.87" (530 mm) • Tilt adjustment: ±15° • Minimum mount to wall distance: 3.1" (80 mm) • Mounting width supported: 50-770 mm • Mounting height supported: 50-480 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200, 400 x 400, 600 x 400 • Maximum weight capacity: 175 lbs. (80 kg) • UL® listed.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV Capacity30" to 39",40" to 49",50" to 59",60" to 69"
  • BrandDayton Audio
  • ModelLCD60-TM
  • Part Number182-322
  • UPC844632082481
  • Product CategoryTV Mounts & Brackets
    (147 Reviews)
  • Weight12.68 lbs.
Videos
