182-322_ALT_0
182-322_ALT_1
182-322_ALT_2
182-322_ALT_3
182-322_ALT_4
182-322_ALT_5
182-322_ALT_6
182-322_ALT_9
Dayton Audio Shadow Mount LCD60-TM Tilting TV Wall Mount 37"-60" w/FREE HDMI Cable
Brand:| Model: LCD60-TM
Product Video
The Dayton Audio LCD60-TM tilting TV wall mount is designed to work with 37"-60" LCD and plasma TV displays using up to a VESA 600 mm x 400 mm bolt pattern. These TV mounts focus the attention on the television instead of the bulky mount.
  • Easy adjustable ±15° tilt places screen in the optimum viewing position
  • Solid steel construction—supports up to 175 lbs.
  • Quick installation, instructions and hardware included to get your TV mounted quickly
  • Universal mounting fits most screens
  • Patented Rail Clip™ for quick attachment of hanger feet to lower rail
  • Great replacement for the Dayton Audio LCD3260-TM LCD/Plasma Tilt Mount 32"-60"
  • UL® listed
182-322
Weight: 12.68 lbs.
IN STOCK
List Price$45.99
You Save35%
$29.80
Buy 4-19 $27.96
Buy 20-up$25.63
Part # 182-322
Shadow Mounts TV mounts from Dayton Audio place the focus on your flat panel television—not the television mount. By using an inconspicuous flat black finish, the TV mount virtually disappears behind the television display.
The LCD60-TM's heavy-duty, solid-steel construction provides you with peace of mind, knowing your HDTV investment is held securely in place for years to come. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices.
The Dayton Audio Shadow Mounts LCD60-TM is compatible with 37"-60" LCD and Plasma TV displays that use up to a VESA 600 mm x 400 mm bolt pattern. Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Mounting plate width: 32.36" (822 mm) • Mounting plate height: 9.25" (235 mm) • Mounting arm width: 1.375" (35 mm) • Mounting arm height: 20.87" (530 mm) • Tilt adjustment: ±15° • Minimum mount to wall distance: 3.1" (80 mm) • Mounting width supported: 50-770 mm • Mounting height supported: 50-480 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200, 400 x 400, 600 x 400 • Maximum weight capacity: 175 lbs. (80 kg) • UL® listed.
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV CapacityLarge (37" & Up)
  • BrandDayton Audio
  • ModelLCD60-TM
  • Part Number182-322
  • UPC844632082481
  • Product CategoryTV Mounts & Brackets
    (121 Reviews)
  • Weight12.68 lbs.
  • Case Qty4
View similar products to the Dayton Audio Shadow Mount LCD60-TM Tilting TV Wall Mount 37"-60" w/FREE HDMI Cable
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount LCD60-TM Tilting TV Wall Mount 37"-60" w/FREE HDMI Cable is rated 4.6942 out of 5 by 121.
Rated 5 out of 5 by from greatHappy with the purchase it works install is easy and nice mount for a good price
Date published: 2014-03-20
Rated 5 out of 5 by from This is the one to buyAs I was shopping around for Wall Mounts, the cost was out of this world!! However, after reading the reviews about the Dayton Wall Mount, I said that I would give it a try. It was really easy to use and I feel confident that my 60" TV is secure!! I would recommend this Wall Mount to my friends... Great buy!!
Date published: 2014-03-19
Rated 5 out of 5 by from Very nice!Love it! Wasn't sure at first but my TV looks amazing and I love the tilting feature!!! Happy customer!!!
Date published: 2014-02-27
Rated 5 out of 5 by from Great TV mount!!A friend told me about this TV mount. I bought it a few days later and used it to hang my 52" TV. It worked great and was easy to install. I would buy it again if I ever have the need.
Date published: 2014-02-24
Rated 5 out of 5 by from Best deal foundSecond large flat-screen mount I've bought, at a fraction of others' offerings' prices, + a FREE HDMI cable?! No brainer, BUY this. Robust, mucho hardware to match your TV included. Can't go wrong!
Date published: 2014-01-30
Rated 5 out of 5 by from great mount, great price!I have used several of these and they work wonderfully with any television.
Date published: 2014-01-23
How far from wall is tv once mounted?
Asked by: bg17
The minimum TV to wall distance, once mounted, is 3.1".
Answered by: mikevv
Date published: 2012-12-11
Will this support VESA 400x400?
Asked by: acwd
For something that small, I would recommend the LCD37-TM instead of the LCD60-TM. The wall plate and the tilt arms are shorter and will not stick out as far.
Answered by: RAK Audio
Date published: 2011-12-25
Will this work for a Samsung mod# es6100 smart tv?
Asked by: rockhound415
Look at the back of your TV. In the center of the back should be a square with 4 screw holes around it. If your set has this, it has what's known as the VESA mounting system. This mount is good for up to 60". Your model is a 6100. Is that 61" Read the manual in the resources download on the right side of the page for more detail on that and whether your TV's VESA size matches the capability of this mount.
Answered by: MarkAJH
Date published: 2012-08-17
Supports VESA 500 x 300 pattern?
Will this fit a 500 (wide) x 300 (high) VESA pattern for a Panasonic 60" plasma (TCP-60S30)? TV weight is 80 lbs.If not, could you recommend another mount stocked by PE?
Asked by: mjkirk12
Yes! This mount will support VESA sizes up to 470 high by 780 wide and weights up to 175 lbs.
Answered by: JoeW
Date published: 2012-02-08
Where is this product manufactured?
Asked by: pep1224
These mounts are made in China, just like every other brand of mount. They are made just as heavy duty and quality as the mounts sold in the big box stores for four times more money. I have used a couple hundred of these over the last few years, they are excellent.
Date published: 2012-06-21
What is the spacing between the wall-side mount holes?
I'm mounting to a brick veneer wall, so I'm curious if the spacing between the two rows of holes for wall-mounting fall at a distance that would match my mortar joint spacing
Asked by: StupidNicknameRequirement
The center to center distance between the wall plate screw holes vertically is 7-1/8".
Date published: 2013-10-15
Videos
Customer projects that include: Dayton Audio Shadow Mount LCD60-TM Tilting TV Wall Mount 37"-60" w/FREE HDMI Cable
