182-320_ALT_0
182-320_ALT_1
182-320_ALT_2
182-320_ALT_3
182-320_ALT_5
182-320_ALT_6
182-320_ALT_9
Dayton Audio Shadow Mount LCD37-TM Tilting TV Wall Mount 23"-37" w/FREE HDMI Cable
Brand:| Model: LCD37-TM
The Dayton Audio Shadow Mounts LCD37-TM is designed to work with 23"-37" LCD and plasma TV displays. It mounts your television securely while remaining unseen behind the display.
  • Easily adjustable ±15° tilt capability places screen in the optimum viewing position
  • Solid steel construction—supports up to 100 lbs.
  • Quick installation—instructions and hardware included
  • Universal mounting fits most screens
  • Patented Rail Clip™ for quick attachment of hanger feet to lower rail
  • UL® listed
182-320
Weight: 9.8 lbs.
IN STOCK
List Price$38.99
You Save27%
$28.64
Buy 4-19 $26.22
Buy 20-up$24.22
Part # 182-320
Shadow Mounts from Dayton Audio place the focus on your flat panel plasma and LCD television—not the mount. By using an inconspicuous flat black finish, the mount virtually disappears behind the display. Heavy-duty, solid-steel construction provides you with peace of mind, knowing your HDTV investment is held securely in place for years to come. Tilt mounts allow you to adjust the viewing angle ±15°, opening up placement options.
Adjustments are accomplished on the LCD37-TM's mounting arms by a quick turn of the knob, with no tools required. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices. Lag bolts, concrete anchors, Phillips head mounting screws (M4, M5, M6 and M8), safety bolts, and easy-to-follow instructions are included. Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Wall bracket: 21" W x 9.3" H (532 x 235 mm) • TV bracket: 1.375" W x 14.3" H (35 x 350 mm) • Tilt adjustment: ±15° H • Minimum TV to wall distance (when tilted): 0.98" (24 mm) • Mounting width supported: 50-720 mm • Mounting height supported: 50-330 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200 • Maximum weight capacity: 100 lbs. (45 kg) • UL® listed.
  • Mount TypeTilting
  • Mount StyleWall Mount
  • TV Capacity20" to 29",30" to 39"
  • BrandDayton Audio
  • ModelLCD37-TM
  • Part Number182-320
  • UPC844632082474
  • Product CategoryTV Mounts & Brackets
    (28 Reviews)
  • Weight9.8 lbs.
View similar products to the Dayton Audio Shadow Mount LCD37-TM Tilting TV Wall Mount 23"-37" w/FREE HDMI Cable
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount LCD37-TM Tilting TV Wall Mount 23"-37" w/FREE HDMI Cable is rated 4.75 out of 5 by 28.
Rated 5 out of 5 by from What a great mount!Much higher quality than I was expecting for the price. It came with all of the hardware I needed including bolts for the TV itself. After I installed the TV I had a fair amount of adjustment available since it's a smaller 32" set. I would definitely recommend this unit for most installs. It's great!
Date published: 2015-04-11
Rated 5 out of 5 by from Great MountMounted my 32" Sony on the wall in my Mobil Home. This worked greatwith the many slots and holes for mounting to the wall. Interior wallsin mobiles have 24" stud spacing which creates a challenge.
Date published: 2014-11-13
Rated 4 out of 5 by from Nice mountThis is the third one I've purchased for three different installs. Never any major issues. The only thing I did to them is grind a tiny bit of metal on the release tabs so that they grab a little more of the mount. Over all very pleased.
Date published: 2014-07-25
Rated 5 out of 5 by from very goodVery good product that's is very easy to install and live with
Date published: 2014-06-29
Rated 5 out of 5 by from Great Deal!I use this mount for a 40" TV. While the measurements of the TV exceed the maximum size recommendation for use with this mount, there is no issue, as the weight is well less than the maximum. The mount was easy to install and it holds the TV very securely. Tilt adjustments are smooth and removal is simple. With newer, lighter big-screens, installation and adjustment is a one-person job.As other reviewers note, the preferred mounting method is directly into wall studs (usually 16" apart), which is what I did. If you cannot, the second-best method is to use toggle bolts. These are not to be confused with plastic anchors, which will not work well in plaster or plasterboard walls. My recommendation is to wire the input/antenna and the house electricity through the wall if you can, so that the connections are fully hidden behind the TV. This yields the most professional-looking result.The mounting hardware provided is plentiful and varied, and it is sorted for use well in its packaging. You will have hardware left over. Instructions are pictorial and are quite easy to understand. The 3' cable supplied with the mount is all but useless, but longer cable is inexpensive and readily available.Lastly, and certainly not least, an almost-identical mount is being sold in one of the Big Box DIY stores for literally three times the price.
Date published: 2014-06-12
Rated 5 out of 5 by from Great productThis is the 3rd PE wall mount I've purchased, and I recommend them to anyone who'll listen. Can't understand why the big box stores still offer overpriced mounts with no hardware when these are available. Make sure your TVs VESA pattern is compatible, then buy with confidence. You won't be disappointed.
Date published: 2014-01-25
  • 2015-07-02T08:13CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_28
  • loc_en_US, sid_182-320, PRD, sort_mostRecent
what is the MAXIMUM TV-to-wall distance for this bracket?   (i.e., how for out, away from the wall, can the TV be pulled?)   Thanks again.
Asked by: bmckjb
The TV does not pull away from the bracket, it only tilts. With the TV parallel to the wall, the bracket "thickness" is 0.98". The bracket does include spacers for mounting the TV, I do not have lengths of these spacers on hand.
Date published: 2014-02-14
how far out from the wall will this bracket extend?
Asked by: bmckjb
Minimum TV to wall distance is 0.98".
Date published: 2014-02-13
Why is the size limit 23-37"?
My TV is 48 lbs and takes a 400x200 mm spacing with M6 screws. These specifications seem to fit this bracket. However, my TV is a 46" Insignia. I prefer this bracket because it is much smaller than the LCD60-TM. Can I use the LCD37-TM for my TV?
Asked by: Puzzled on size
Yes this will work with your TV, You are within the weight limit and mounting size limitations so there will not be a problem.
Date published: 2013-03-27
  • 2015-07-02T10:00CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • loc_en_US, sid_182-320, PRD, sort_recentQuestionsFirst
Customer projects that include: Dayton Audio Shadow Mount LCD37-TM Tilting TV Wall Mount 23"-37" w/FREE HDMI Cable
