Dayton Audio Shadow Mount LCD3260-FM Fixed TV Wall Mount 32"-60"
Brand:|Model: LCD3260-FM|Part # 182-352
The fixed LCD3260-FM is one of our most popular flat panel TV mounts. Like all Shadow Mounts from Dayton Audio, it places the focus on your flat panel television—not the mount.
List Price$69.99
You Save59%
$28.68
Buy 4-19 $26.25
Buy 20+$24.23
Part # 182-352
  • Unobtrusive black design shadows most TVs perfectly
  • Durable steel construction for reliablilty and long life
  • Easy to install, mounting hardware included
  • Universal mounting—fits most screens
  • Slim design places TVs less than 1" off the wall
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. By using an inconspicuous flat black finish, the LCD3260-FM fixed-position mount virtually disappears behind the display. Heavy-duty, solid-steel construction provides you with peace of mind, knowing your HDTV investment is held securely in place for years to come. Fixed mounts are the perfect solution to installing your LCD and plasma TV permanently, and are suited for both commercial and residential applications.
Designed to work with VESA sizes 75, 100, 200 x 100, 200, and 400 x 200. Maximum supported weight is 175 lbs. Lag bolts, concrete anchors, Phillips head mounting screws (M4, M5, M6 and M8), safety bolts, and easy-to-follow instructions are included. Two additional height position tabs have been built into mounting arms of the LCD3260-FM to quickly adjust the TV up or down 2" from the center mount position. Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Wall bracket: 32.4" (822 mm) W x 9.25" (235 mm) H • TV bracket: 1.375" (35 mm) W x 20.9" (530 mm) H • Minimum TV to wall distance: 0.98" (24 mm) • Mounting width supported: 50-770 mm • Mounting height supported: 50-480 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200, 600 x 400 • Maximum weight capacity: 175 lbs. (80 kg).
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeFixed
  • Mount StyleWall Mount
  • TV Capacity30" to 39",40" to 49",50" to 59",60" to 69"
  • BrandDayton Audio
  • ModelLCD3260-FM
  • Part Number182-352
  • UPC844632067730
  • Product CategoryTV Mounts & Brackets
    (49 Reviews)
  • Weight9.45 lbs.
View similar products to the Dayton Audio Shadow Mount LCD3260-FM Fixed TV Wall Mount 32"-60"
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount LCD3260-FM Fixed TV Wall Mount 32"-60" is rated 4.4082 out of 5 by 49.
Rated 5 out of 5 by from Excellent product and a bargain price.I had to get a 60" screen mounted quickly. This did the job perfectly. It is quite close to the wall, which makes your work look just that much more professional. The added free HDMI cable is great and it sweetens the deal! Bargain price for such a quality product. Highly recommended!
Date published: 2015-03-13
Rated 5 out of 5 by from SolidGreat solid, heavy duty mount with a variety of hardware. Can't go wrong for the price. Be sure and order the HDMI 90 degree Part #: 181-342 for down, or Part #: 180-692 for cable going up. It is very close to the wall as described.Spend the extra $5 for the adapter just in case.
Date published: 2014-01-23
Rated 4 out of 5 by from Works fine but not for everyoneThis basic bracket worked fine for my application. Had to do a lot of measuring to figure out how to position the backet on the back of the TV so all connections I wanted to use could be used and to fit the wall brackets where studs were located. I would not suggest this to people who are not handy or patient enough to manage this. All in all a good value.
Date published: 2013-11-05
Rated 5 out of 5 by from A Great Value!This was exactly what I wanted at a price that can't be beat! Yeah, it doesn't extend or swivel, but those features were not needed for my installation. A value that can't be beat!
Date published: 2013-10-09
Rated 5 out of 5 by from TV Wall MountFast service, excellent price, great product! It took me all of twenty minutes to hang my 50" flat screen TV. Drill four holes, screw in 4 lag bolts, mount the unit to the TV, done!
Date published: 2013-04-07
Rated 1 out of 5 by from Bracket needs longer bolts!!I am hanging a 42 inch TV and purchased this bracket. The bolts to hang the bracket's to the TV are 1 inch long. Really? So, I guess when you order this bracket budget a trip to the local hardware store to purchase the hardware needed to complete the job.
Date published: 2013-03-09
  • 2016-02-10T06:53CST
  • co_hasreviews, tv_0, tr_49
  • loc_en_US, sid_182-352, PRD, sort_mostRecent
Can I use this with a VESA size 300mm x 300 mm? (an LG 55" TV)
Asked by: Christopher E
Yes.
Date published: 2016-01-04
Can I use this bracket if my Vesa size is 400 X 400?
Asked by: Brett196
Yes.
Date published: 2015-06-15
Please provide additional details about how the locking bar is attached and how it locks the tv in place?  How would I legitemlely remove the locking bar in case I needed to remove the tv at access the back panel, etc?
Asked by: Glen1960
You can view the installation instructions in the manual on the website or in the link below.www.parts-express.com/pedocs/manuals/182-352-dayton-audio-lcd3260-fm-manual.pdf
Date published: 2014-01-21
I am looking for a mount which makes it difficult to remove the TV monitor from the mount.  Does the Tv just lift off?  or, is this more permanent?
Asked by: Glenn1960
The TV hangs on this mount and can be lifted off easily, but it includes a locking bar that is to be slid into the bottom of the mount that prevents theft or the TV simply falling off the mount.
Date published: 2014-01-20
How do I determine if this product will work with my 31" LCD?
Asked by: BMO1
Measure the VESA mounting holes on the back of your panel, and compare that measurement to the supported VESA sizes under the product description, which are expressed in millimeters. These mounts will accommodate the vast majority of panels on the market for VESA mounting. The only other consideration is the weight, and I would assume that your 31" panel weighs less than 175 lbs., so that shouldn't present a problem.
Answered by: RussR
Date published: 2011-09-03
  • 2016-02-10T07:48CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_182-352, PRD, sort_recentQuestionsFirst
