Dayton Audio Shadow Mount LCD1330-TM Full-Motion TV Wall Mount Up To 30" LCD
Brand:|Model: LCD1330-TM|Part # 182-376
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. The LCD1130-TM full motion mount is compatible with flat panel TVs using VESA 75 and 100 mounting standards. Maximum supported weight is 50 lbs.
List Price$34.99
Regular Price$14.50
You Save17%
Sale Price
$12.00
Part # 182-376
  • Unobtrusive black finish disappears behind flat panel TVs
  • ±30° swivel adjustment
  • ±15° tilt adjustment
  • Conforms to VESA 75 and 100 mounting standards
  • Mounting hardware and instructions included
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. By using an inconspicuous flat black finish, the mount virtually disappears behind the display. Heavy-duty, solid-steel construction provides you with peace of mind knowing your HDTV investment is held securely in place for years to come. A full motion mount allows a viewer to tilt or swivel a flat panel TV into the optimum viewing position. A total of 60° swivel adjustment and 30° tilt adjustment offers almost unlimited placement options. Lag bolts, concrete anchors, Phillips head mounting screws (M4, M5, M6 and M8), safety bolts, and easy-to-follow instructions are included. Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Wall bracket: 3.1" (80 mm) W x 4.3" (109 mm) H • TV bracket: 4.3" (110 mm) W x 4.3" (110 mm) H • TV to wall distance: 3.9" (98 mm) • Swivel adjustment: ±30° • Tilt adjustment: ±15° • Supported VESA sizes: 75, 100 • Maximum weight capacity: 50 lbs. (23 kg).
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeFull-Motion Articulating
  • Mount StyleWall Mount
  • TV CapacityUp to 19",20" to 29",30" to 39"
  • BrandDayton Audio
  • ModelLCD1330-TM
  • Part Number182-376
  • UPC844632067853
  • Product CategoryTV Mounts & Brackets
    (8 Reviews)
  • Weight1.83 lbs.
View similar products to the Dayton Audio Shadow Mount LCD1330-TM Full-Motion TV Wall Mount Up To 30" LCD
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount LCD1330-TM Full-Motion TV Wall Mount Up To 30" LCD is rated 5.0 out of 5 by 8.
Rated 5 out of 5 by from excellent gearI bought two of this and very surprised the quality and features they have also they include a leveler tool and different sizes of screws and bushings even for rear flat tvs or rear curved tvs. Very pleased with this item AAA+++ thanks
Date published: 2014-07-15
Rated 5 out of 5 by from Very nice little unit!!This mount bolted right up to the flat screen like it was made for it!!The mount allows up and down as well as left and right adjustment it is approx. six inches from the wall behind it so plug your wires in before you put the mount back together !!
Date published: 2014-01-22
Rated 5 out of 5 by from Great mount for the priceThis TV mount worked out great for the 24" LED I installed. It yields an excellent array of viewing angles and for $25 you can't beat the features. It even came with a level to assist in the installation.
Date published: 2013-03-24
Rated 5 out of 5 by from Nice mount!Mounted a 19in LCD to the wall, no problems at all. Very well built. Easy to install and comes with everything I needed. Good range of motion.
Date published: 2013-01-21
Rated 5 out of 5 by from Does the job wellI installed this piece into sheetrock for a 20" LCD monitor (about 18-20lbs.) and it holds very well. Make sure that you tighten the two lock nuts enough to keep the monitor from sagging. Works great and looks beautiful. The semi-gloss/matte finish is very classy.
Date published: 2009-09-11
Rated 5 out of 5 by from Dayton LCD1330-TM LCD Full Motion LCD Mount 13"-30Does what it is supposed to do and is reasonably priced. I used it on a 26" flat TV any larger and the mounting flange will be to small.
Date published: 2009-05-12
  • 2016-02-13T07:05CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_182-376, PRD, sort_mostRecent
Provided images are different configurations.  Image drawing displays the mounting holes on the sides in which only one side will line up with wall stud.  The diagram image displays the mounting holes vertically which will line up with stud.  Which is it?
Asked by: tharris1103
This mount can be oriented either way.
Date published: 2015-11-30
Hi will this mount work on a 31" TV as long as it's correct VESA? Thanks
Asked by: cpcc
A 31" TV might be a bit much for this. If it is within the weight limit it will technically work, but you might really have to tighten the bolts in order for it not to droop.
Date published: 2015-07-31
Hello. How much distance wall to back of television?
Asked by: ACTQS
TV to wall distance is 3.9".
Date published: 2014-06-13
  • 2016-02-13T07:50CST
  • loc_en_US, sid_182-376, PRD, sort_recentQuestionsFirst
