Dayton Audio Shadow Mount LCD1140-SI Low-Profile Up To 40" TV Wall Mount
Brand:|Model: LCD1140-SI
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. The LCD1140-SI slide-in mount is designed to work with VESA 75, 100, 200 x 100, and 200 mounting standards. Maximum supported weight is 175 lbs.
List Price$31.99
You Save60%
$12.78
Buy 4-19 $12.25
Buy 20+$11.78
Part # 182-374
  • Low profile mounts create a custom installation appearance
  • Unobtrusive flat black finish disappears behind the display
  • Conforms to VESA mounting standards
  • Mounting hardware and instructions are included
Shadow Mounts from Dayton Audio place the focus on your flat panel television—not the mount. By using an inconspicuous flat black finish, the mount virtually disappears behind the display. Heavy-duty, solid-steel construction provides you with peace of mind knowing your HDTV investment is held securely in place for years to come. Low profile slide-in mounts maximize the aesthetic and appeal of flat panel HDTVs for residential or commercial applications. With a TV to wall distance of less than an inch, a custom installation appearance is guaranteed. Lag bolts, concrete anchors, Phillips head mounting screws (M4, M5, M6 and M8), safety bolts, and easy-to-follow instructions are included.Note: Consult your TV's owners manual for VESA sizing information.
Dimensions and Specifications: • Wall bracket: 10.8" (275 mm) W x 9.3 " (237 mm) H • TV bracket: 10.8" (275 mm) W x 9.3 " (237 mm) H • TV to wall distance: 0.9" (22 mm) • Supported VESA sizes: 75, 100, 200 x 100, 200 • Maximum weight capacity: 175 lbs. (80 kg).
  • Mount TypeFixed
  • Mount StyleWall Mount
  • TV CapacityUp to 19",20" to 29",30" to 39",40" to 49"
  • BrandDayton Audio
  • ModelLCD1140-SI
  • Part Number182-374
  • UPC844632067846
  • Product CategoryTV Mounts & Brackets
    (8 Reviews)
  • Weight5.18 lbs.
View similar products to the Dayton Audio Shadow Mount LCD1140-SI Low-Profile Up To 40" TV Wall Mount
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount LCD1140-SI Low-Profile Up To 40" TV Wall Mount is rated 4.75 out of 5 by 8.
Rated 5 out of 5 by from Good MountI used this before to mount a 40" to the ceiling over my bed. Used this one to mount a gift for my daughter. A 40" TCL roku TV. The only problem was the location of the composite inputs on this particular TV. The video plug is blocked by the mount. Strange location for the jacks. Take note that if the TV is not level when placed in the mount it can be adjusted slightly by changing the bend on the tabs where the screws that secure the 2 halves together go. Gentle hammer use.
Date published: 2015-01-18
Rated 5 out of 5 by from Great BuyThis worked great on my 32" LCD. I did have to use the spacers to leave enough room for the HDMI between the wall and the TV. But, it is still well hidden behind the TV. Even from the side view. Great price too.
Date published: 2014-08-08
Rated 4 out of 5 by from Other uses.Used these to mount a pair of rear surround speakers that I recently built and they worked perfect. Nice clean look close to the wall and you can take them down for cleaning or whatever. Heavy duty construction for a rock solid mount.
Date published: 2014-06-03
Rated 5 out of 5 by from As pictured, simple, GREAT valueCostco had $30 off a $150 TV mount. This was $22. Just as pictured. Came with a level (which I might not have thought to do). Simple is always the best answer and this is it. Low profile and with two infants starting to walk our TV needs locked down. Innovative!
Date published: 2010-03-15
Rated 5 out of 5 by from Solid, Easy to installIf you have studs in your wall where you want to mount your tv,and do not need it to pivot, then this is the unit you need. Comes with everything needed for VESA mount pattern. I hung my 32" lcd in my bedroom and its rock solid. I like how the tv is only about 5/8" away from the wall. Makes for a nice clean looking in stall and you can't beat the price.
Date published: 2009-01-06
Rated 4 out of 5 by from Nice low profile mountThis thing will let you hang your monitor or tv in minutes by yourself and has a very low profile.
Date published: 2008-12-21
  • 2015-07-30T07:20CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_182-374, PRD, sort_mostRecent
Since the space from the wall for this mount is less than an inch, can RCA cables be used for inputs on the back of the tv?
I know there are 90 degree HDMI cables, but I have one source which uses component video out.
Asked by: TW529
It really depends on the TV set, and how far those RCA inputs are set into the back of the panel. I might suggest plugging an RCA cable into the TV in question, and simply measure how far it protrudes off the back of the set. Our right angle RCA adapter (referenced below for your convenience) will extend approximately 3/4" from the jack into which it's inserted.
Answered by: RussR
Date published: 2011-07-08
what's the hole spacings on the bracket that mounts to the TV
Asked by: asaco
This mount uses VESA 75, 100, 200 x 100, and 200 mounting standards, which corresponds to a top to bottom and side to side dimension (height and width) in millimeters.VESA 75 = 75 x 75 mm or 2.95" x 2.95"VESA 100 = 100 x 100 mm or 3.94" x 3.94"VESA 200 x 100 = 200 x 100 mm or 7.87" x 3.94"VESA 200 = 200 x 200 mm or 7.87" x 7.87"
Answered by: mikevv
Date published: 2011-04-22
  • 2015-07-30T08:14CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • loc_en_US, sid_182-374, PRD, sort_recentQuestionsFirst
