Dayton Audio Shadow Mount HD3260ARM Heavy-Duty Full-Motion TV Wall Mount 32"-60"
Brand:|Model: HD3260ARM|Part # 182-361
There simply is no better mount for integrating HDTVs into custom applications than the Dayton Audio HD3260ARM Shadow Mount.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$79.99
You Save14%
$68.90
Buy 4-19 $64.50
Buy 20+$58.88
Part # 182-361
  • Great for placing TVs in the corner of a room
  • Designed for TVs 32" to 60"
  • Durable steel construction
  • Extends up to 20" from a wall
  • ± 45° of left to right swivel and ± 15° of tilt
  • Features patented RailClip™ function
The Dayton Audio HD3260ARM Shadow Mount features scissor arms creating the ultimate support for your HDTV (up to 60" or 150 lbs.) while offering up to 20" of extension from the wall. Additionally, this mount makes corner and off-axis mounting simple and easy with ± 45° of left to right swivel. With ± 15° of tilt, you aren't locked in to a particular mounting height—perfect for custom applications such as mounting your HDTV above a fireplace. 2 mm cold-rolled steel is used throughout for maximum durability. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices.
Specifications: • Mounting plate dimensions: 19.7" W x 9.6" H • TV plate dimensions: 32" W x 9.4" H • TV bracket dimensions: 1.375" W x 21" H • Swivel adjustment: ± 45° • Tilt adjustment: ± 15° • Distance from wall: Adjustable from 4.5" to 20" • VESA sizes supported: 50 mm W x 50 mm H up to 700 mm W x 400 mm H • Maximum weight capacity: 150 lbs.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeFull-Motion Articulating
  • Mount StyleWall Mount
  • TV Capacity30" to 39",40" to 49",50" to 59",60" to 69"
  • BrandDayton Audio
  • ModelHD3260ARM
  • Part Number182-361
  • UPC844632094996
  • Product CategoryTV Mounts & Brackets
    (28 Reviews)
  • Weight31.85 lbs.
View similar products to the Dayton Audio Shadow Mount HD3260ARM Heavy-Duty Full-Motion TV Wall Mount 32"-60"
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount HD3260ARM Heavy-Duty Full-Motion TV Wall Mount 32"-60" is rated 4.9643 out of 5 by 28.
Rated 4 out of 5 by from Strong but not full motionthis mount works great and I have used it to mount as large as 75" tv's, but it will not allow you to turn larger sets past about 25 degrees horz and will not allow any size past about 45 degrees. This is typical of any unit that uses two arms. It could also use a heavier clamp on the tilt. This thing is strong and durable and easy to install. It easily the best deal I have found in mounts.
Date published: 2016-01-06
Rated 5 out of 5 by from Heavy duty mountThe other brands that Parts Express sellmay be lighter but they are twice the price!
Date published: 2015-03-21
Rated 5 out of 5 by from Heavy Duty is Right!This machine is quite stout. I have an old Sony Wega. It tips at over 100 lbs. This mount has no trouble supporting it while doing all the extension, swing & tilt. Hint: set your tilt before setting the TV with brackets on the mount. If you don't, there will not be enough room for your hand to grip the thumb screws. Or, you can use a water valve handle. Worked for me.
Date published: 2015-02-04
Rated 5 out of 5 by from Great Item, Even Better is its Price!Simple to install, sturdy, feels& looks strong, I looked at a lot of these type mounts before I ordered this one, So do yourself a favor & stop looking & order this one now!
Date published: 2015-01-04
Rated 5 out of 5 by from Great deal for quality itemThis bracket is very sturdy and was relatively easy to install. Definitely was easier with two people due to the weight, but overall easy to install. Instructions were clear and all parts were included. Definitely recommend
Date published: 2014-12-15
Rated 5 out of 5 by from Excellent wall mountGrabbed one of these for my 50" Plasma. This mount is heavy duty/very well built. Love the multi swivel whenever necessary. Will buy another for my bedroom setup.
Date published: 2014-11-23
  • 2016-02-12T06:40CST
  • co_hasreviews, tv_0, tr_28
  • loc_en_US, sid_182-361, PRD, sort_mostRecent
Will this work with my samsung 50" led smart tv
Asked by: rockymaroo
We do not have a reference for the TV's that will fit our mounts. You will have to compare the VESA mount size from your TV's manual to the sizes this mount will support. As long as the VESA size for your TV is within 50 mm W x 50 mm H up to 700 mm W x 400 mm H it will fit without a problem.
Date published: 2014-09-11
Would this work with a Vizio 50" LCD?  I think the mounts for it are 800 x400.
Asked by: Rose
Unfortunately this will only handle up to a 700mm width.
Date published: 2014-02-14
This item says "150lb". Does that mean a 100lb 70" is ok since it says 60" limit?
Asked by: rollingradios
Yes. As long as the TV has a VESA mount size within the limits of the mount and is under the weight limit it will work fine.
Date published: 2014-01-24
Will this work with the Panasonic TC-P65VT60?
The TV is only 93 lbs and the mount is rated up to 150 lbs so weight shouldn't be an issue. I'm not sure what the width of the TV has to do with it, but I want to make sure that it will work for it.
Asked by: maseline
This mount will support a TV with a VESA mount size up to 700mm x 400mm. Please check the manual for the TV and see if the VESA size falls within these dimensions.
Date published: 2013-10-28
How is the Cable Management? just zip ties?
Asked by: Myke
Yes, there is no specific cable managment built in to this mount.
Date published: 2013-06-10
Side to Side position on the wall
I really like this and want to put it on the wall but I'm worried about side-to-side position. The back in 19.5" wide and it needs two studs. That means it could only move a few inches left or right at most.I'm trying to think of a workaround, maybe mount a 33" piece of plywood on the wall to three studs then screw it into that.Any other ideas?I imagine that when it's about 1/2-way out, the TV would be movable left and right. But I wanted it to be centered when it is all the way back and all the way out.
Asked by: learn2turn
It is best to mount direct to the studs when possible. There are some other alternatives though, such as the Toggler brand anchors that are rated for up to 265 pounds each.
Answered by: Chrisf
Date published: 2012-11-27
  • 2016-02-12T07:18CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_182-361, PRD, sort_recentQuestionsFirst
