Dayton Audio Shadow Mount DESKARM-S Articulating Desktop LCD Monitor Mount 13"-27"
Brand:|Model: DESKARM-S|Part # 182-394
Increase your productivity while decreasing eye and neck strain with Dayton Audio's single monitor DESKARM Shadow Mount.
List Price$49.99
You Save47%
$26.52
Buy 4-19 $25.29
Buy 20+$24.52
Part # 182-394
  • Reclaim valuable desk space—requires only 3.5" x 4" of mounting area
  • Reduces neck and eye strain by placing monitor at optimum viewing height and angle
  • Heavy-duty design will not sag over time
  • Integrated cable management for a smart, clean appearance
  • Increases productivity and efficiency
Dayton Audio's Shadow Mount desktop monitor mounts are designed for computer monitors up to 27". Each mount is constructed of solid aluminum and steel for superior stability, even when fully extended—a Dayton Audio desktop mount will not flex or sag. Copper joints offer smooth, fluid tilt, pan, and swivel adjustments for maximum visibility no matter your seating position.
An ultra heavy-duty C-clamp, with integrated double lock system and three mounting depths permanently affixes the mount to your desktop (from 1/2" to 4" thick) in no time flat. Height adjustments are quick and easy, and monitors can be installed in either portrait or landscape positions effortlessly—rotating 360°—to fit your application perfectly.
Dual arm joints offer up to 360° of swivel viewing adjustment, while extending up to 16.5" freeing up crucial desk space. Integrated cable management provides a neat, clean appearance and all necessary installation hardware is included.
Specifications: • Mount arm length: Adjustable up to 16.5" L • Mount height: Adjustable up to 17.7" H • Attaches to desk tops from 1/2" to 4" thick • Tilt adjustment: ± 15° • Swivel adjustment: 360° • Rotate adjustment: 360° • Supports monitors weighing up to 22 lbs. • Compatible with 75 x 75 mm and 100 x 100 mm VESA patterns (for use with larger monitors, please see the Related Items section for VESA adapters).
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeFull-Motion Articulating
  • Mount StyleDesk/Table Mount
  • TV CapacityUp to 19",20" to 29"
  • BrandDayton Audio
  • ModelDESKARM-S
  • Part Number182-394
  • UPC844632094934
  • Product CategoryTV Mounts & Brackets
    (16 Reviews)
  • Weight9.3 lbs.
View similar products to the Dayton Audio Shadow Mount DESKARM-S Articulating Desktop LCD Monitor Mount 13"-27"
in the TV Mounts & Brackets product category.
Videos
