182-396_ALT_0
182-396_ALT_1
182-396_ALT_2
Dayton Audio Shadow Mount DESKARM-D Articulating Desktop Dual LCD Monitor Mount 13"-27"
Brand:| Model: DESKARM-D
Product Video
Increase your productivity while decreasing eye and neck strain with Dayton Audio's dual monitor DESKARM Shadow Mount.
  • Reclaim valuable desk space—requires only 3.5" x 4" of mounting area
  • Reduces neck and eye strain by placing monitor at optimum viewing height and angle
  • Heavy-duty design will not sag over time
  • Integrated cable management for a smart, clean appearance
  • Increases productivity and efficiency
  • Perfect for power users
182-396
Weight: 13.55 lbs.
IN STOCK
List Price$69.99
You Save44%
$38.72
Buy 4-19 $35.20
Buy 20-up$32.27
Part # 182-396
Dayton Audio's Shadow Mount desktop monitor mounts are designed for computer monitors up to 27". Each mount is constructed of solid aluminum and steel for superior stability, even when fully extended—a Dayton Audio desktop mount will not flex or sag. Copper joints offer smooth, fluid tilt, pan, and swivel adjustments for maximum visibility no matter your seating position.
An ultra heavy-duty C-clamp, with integrated double lock system and three mounting depths permanently affixes the mount to your desktop (from 1/2" to 4" thick) in no time flat. Height adjustments are quick and easy, and monitors can be installed in either portrait or landscape positions effortlessly—rotating 360°—to fit your application perfectly.
Dual arm joints offer up to 360° of swivel viewing adjustment, while extending up to 16.5" freeing up crucial desk space. Integrated cable management provides a neat, clean appearance and all necessary installation hardware is included.
Specifications: • Mount arm length: Adjustable up to 16.5" L • Mount height: Adjustable up to 17.7" H • Attaches to desk tops from 1/2" to 4" thick • Tilt adjustment: ± 15° • Swivel adjustment: 360° • Rotate adjustment: 360° • Supports two monitors weighing up to 22 lbs. each • Compatible with 75 x 75 mm and 100 x 100 mm VESA patterns (for use with larger monitors, please see the Related Items section for VESA adapters).
  • Mount TypeFull-Motion Articulating
  • Mount StyleDesk/Table Mount
  • TV CapacitySmall (< 24")
  • BrandDayton Audio
  • ModelDESKARM-D
  • Part Number182-396
  • UPC844632094941
  • Product CategoryTV Mounts & Brackets
    (33 Reviews)
  • Weight13.55 lbs.
View similar products to the Dayton Audio Shadow Mount DESKARM-D Articulating Desktop Dual LCD Monitor Mount 13"-27"
in the TV Mounts & Brackets product category.
Dayton Audio Shadow Mount DESKARM-D Articulating Desktop Dual LCD Monitor Mount 13"-27" is rated 4.6667 out of 5 by 33.
Rated 5 out of 5 by from Very Happy with the ProductWe bought three of these about a month ago and couldn't be happier. Because they were inexpensive I didn't expect much and was pleasantantly surprised at how heavy duty they are.
Date published: 2014-09-02
Rated 5 out of 5 by from Well BuiltI orginally purchased one of these dual mounts through work for my office. I was very impressed with how sturdy the mount was and how quickly it could be assembled and set-up. I was so impressed, I personally purchased a unit for my home computer system and love it. It is so easy to set-up and it clears your desktop of those bulky monitor stands, allowing you more room to work.
Date published: 2014-08-05
Rated 5 out of 5 by from Awesome ProductThis product exceeded my expectations. It is extremely durable and heavy duty. I would expect this level of quality from a much more expensive product.
Date published: 2014-03-27
Rated 5 out of 5 by from Strong, Adjustable SimplicityI am surprised by the value of this monitor mounting system. It is adjustable in every direction. Resistance is adjustable under the knuckle covers with provided Allen wrench. The height is set by the post with set screws so the support arms don't rotate on you while adjusting monitor's screen to any position needed. I have two 23" monitors, 7" off my desk and could raise that to 10" if needed. This is the height I had with the stock monitor stands, so works excellent for me. I do need longer cables to take advantage of the cable management system but I had this problem with the stock stands anyway.
Date published: 2014-03-18
Rated 4 out of 5 by from Great productI bought this product three weeks ago and it's been a dream so far. I have two 21.5" monitors and the holes on the plates lined up perfectly. The arms looked thick at first but it adds to the study nature of the setup. It sits on the edge of my desk and has plastic clips to manage the cables. I would definitely recommend this product to someone.
Date published: 2014-02-19
Rated 5 out of 5 by from GREAT QUALITY AND PRICE!!!I am please with this mount. I do with it was taller, but I've made it work. I am currently only using only one side of it because I have my monitors stacked one over the other. The lower monitor stays on it's stand, and I use this mount to put the other one over it. Since the pole wasn't tall enough for my purpose, I improvised by taking out the lower mounting bolts, bolting the unit to a 2x4 and bolting that to the back edge of my desk. It took a little work, but it now does what I wanted. I am extremely pleased with the quality of the monitor mount - no cheap plastic or cheap parts. It's all solid metal, and everything adjusts like you would want it to. The pictures shows my current set-up and how I mounted it to the 2x4 and on my desk. Thank you, Parts Express!!!
Date published: 2014-01-30
Do you have an arm extension for the keyboard?
Asked by: karin
Unfortunately no, all we have at this time are monitor mounts.
Date published: 2014-08-18
What is the outside diameter of the vertical support pole?
Asked by: Snappason
The diameter of the vertical pole is 1-15/16".
Date published: 2014-06-16
how tall?
With the left and rear arms mounted on the vertical pole at its most highest position, What is the height of the upper mounting hole of the vesa mount? I need to know how much clearance I'll have under the monitors with this mount - thanks
Asked by: mp3jeep
That will be approximately 18-1/4" (463.55mm).
Answered by: RussR
Date published: 2012-04-10
what is the total weight of both monitors this stand is rated for. What is the max width of each monitor that the stand accepts.
Asked by: magmusic
According to the description, 2x22 pound 27" monitors max. These are well made, but I would not hang monitors larger than 22" for safety. Newer monitor flat-screens are lighter weight however.
Answered by: Fanden
Date published: 2012-03-06
Videos
Customer projects that include: Dayton Audio Shadow Mount DESKARM-D Articulating Desktop Dual LCD Monitor Mount 13"-27"
