Dayton Audio Shadow Mount AM378 TV Monitor Wall Mount 13"-37"
Brand:|Model: AM378|Part # 182-369
Shadow Mounts TV mounts from Dayton Audio place the focus on your flat panel television -- not the hardware. By using an inconspicuous flat black finish, the Shadow Mounts AM378 TV mounting system virtually disappears behind the television display.
List Price$34.99
You Save24%
$26.72
Buy 4-19 $24.47
Buy 20+$22.60
Part # 182-369
  • Lightweight mounts for lightweight televisions
  • Built-in cable management hooks
  • Integrated level makes installation easier
  • Compatible with televisions up to 37"
Sometimes you don't need a huge TV mount to make a big impression, and Dayton Audio's Shadow Mounts AM378 can certainly hold its own. Aluminum construction allows this mount to weigh less than other mounts while handling loads of 55 lbs. Features include the ability to tilt a total of 30° (±15°), rotate to any viewing position, and fold almost flat against the wall. The single arm extends 2.8"-8" from the wall.
The Shadow Mounts AM378 is compatible with 13"-37" televisions with up to VESA 100 mm x 100 mm bolt pattern. Note: Consult your TV owner's manual for VESA sizing information.
Specifications: • Pan adjustment: ±90° • Swivel adjustment: ±90° • Tilt adjustment: ±15° • Rotate adjustment: ±180° • Extension from the wall: 2.8"-8" • Supported VESA sizes: 75 x 75, 100 x 100 • Maximum weight capacity: 55 lbs.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeFull-Motion Articulating
  • Mount StyleWall Mount
  • TV CapacityUp to 19",20" to 29",30" to 39"
  • BrandDayton Audio
  • ModelAM378
  • Part Number182-369
  • UPC848791000591
  • Product CategoryTV Mounts & Brackets
    (3 Reviews)
  • Weight2.65 lbs.
