Dayton Audio Shadow Mount AM3713 Articulating TV Monitor Wall Mount 13"-37"
Brand:|Model: AM3713|Part # 182-371
Shadow Mounts TV mounts from Dayton Audio place the focus on your flat panel television—not the television mount. By using an inconspicuous flat black finish, the TV mount virtually disappears behind the television display.
List Price$42.99
You Save30%
$29.88
Buy 4-19 $28.16
Buy 20+$26.90
Part # 182-371
  • Lightweight mounts for lightweight televisions
  • Built-in cable management hooks
  • Integrated level makes installation easier
  • Compatible with televisions and monitors up to 37"
For installation of medium-sized TV displays, the Shadow Mounts AM3713 is ideal. The AM3713 accommodates loads of up to 44 lbs., thanks to its aluminum construction. Features include the ability to tilt a total of 30 degrees (-15° ~ +15°), rotate to almost any viewing position, and fold almost flat against the wall. The AM3713's dual arms extend outward 13" from the wall.
The Dayton Audio Shadow Mounts AM3713 is compatible with 13" ~ 37" televisions or monitors with up to VESA 200 mm x 200 mm bolt pattern. Note: Consult your TV or monitor owner's manual for VESA sizing information.
Specifications: • Pan adjustment: ±90° • Swivel adjustment: ±90° • Tilt adjustment: ±15° • Rotate adjustment: ±180° • Maximum extension from the wall: 2.8"-13" • Supported VESA sizes: 75 x 75, 100 x 100, and 200 x 200 • Maximum weight capacity: 44 lbs.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
  • Mount TypeFull-Motion Articulating
  • Mount StyleWall Mount
  • TV CapacityUp to 19",20" to 29",30" to 39"
  • BrandDayton Audio
  • ModelAM3713
  • Part Number182-371
  • UPC848791000607
  • Product CategoryTV Mounts & Brackets
    (10 Reviews)
  • Weight3.3 lbs.
Dayton Audio Shadow Mount AM3713 Articulating TV Monitor Wall Mount 13"-37" is rated 4.3 out of 5 by 10.
Rated 5 out of 5 by from Smooth Operation, Quick InstallI bought this mount for a TV in the corner of my kitchen. It went up very easily with the hardware provided. The only thing I wasn't thrilled about was the VESA mount, which does accommodate 200x200 after adding extenders to the original footprint. I would have liked to have known that the VESA mount that is pictured is NOT the full 200x200. Other than that little detail, the unit as a whole does the job quite well.
Date published: 2015-03-17
Rated 4 out of 5 by from Easily worth its price, simple and functional.Easy installation and it works well, not visually intrusive, *much* better for overall viewing experience and convenience. Easy to use, easy to fine tune the TV's position as needed. Plenty of extension length but also gets the TV very close to the wall when folded up. Easily beefy enough for anything within its weight rating.No instructions in the box; the product page has the link.Mine came with extra parts never identified, four small plates and various bolts (not shown on its parts list).NOTE that--like any articulating TV mount--it's installed only on a stud or solid anchor point; sheet rock alone = no cigar.This is a good product and IMO not at all overpriced.
Date published: 2015-03-11
Rated 3 out of 5 by from Review TitleOver all I am quite happy with the build of this mount but it is absolutely impossible to tighten the lock on the ball joint/socket enough to keep a larger/heavier TV from tilting downward. I ended up wedging a very small piece of bar stock under the joint/socket to keep it at the angle I was looking for. This may not be an issue with a smaller/lighter TV but since I am on the upper end of the envelope it was an issue for me.
Date published: 2015-01-12
Rated 5 out of 5 by from TV Mount AM3713Works great, Looks great, Easy to install, Great price, Great and prompt service. I couldn't ask for a better product or deal
Date published: 2014-12-30
Rated 4 out of 5 by from Works greatThis is my 2nd one. Holds up a 32" Vizio for my mother. Easy to mount and easy adjustment.Only hitch was that the supplied mounting screws didn't fit the molly anchors provided. I had some better ones handy so it was only a minor inconvenience.
Date published: 2014-12-01
Rated 4 out of 5 by from MountThe item works as advertised. Good for kids room. Easy install too.
Date published: 2014-08-03
  • 2016-02-06T07:17CST
  • co_hasreviews, tv_0, tr_10
  • loc_en_US, sid_182-371, PRD, sort_mostRecent
I have a 32 inch coby t.v. and bought the Dayton shadow mount AM3713 and the mounting holes on back of t.v. are to far away for this mount evan with adapter feet that were supplied .Are there longer ones for this mount?
Asked by: cabin1
an adapter may be possible, it is best to start by measuring the bolt distances. that is what the Vesa mounting pattern is,. For example a vesa 100 is a 100 mm x 100 mm mounting,
Answered by: Chrisf
Date published: 2015-04-09
Your description above says that this bracket will support VESA sizes of both 100 X 100 and 200 X 200.   If this is the case, then is it correct that it also will support a VESA size of 200 X 100? Thanks.
Asked by: bmckjb
No, this will only handle a 100 x 100 or 200 x 200 due to the pattern of the bolts themselves.
Date published: 2014-02-14
what is the weight limit on this mount
Asked by: perrymueller
The weight limit is 44 pounds.
Date published: 2014-02-10
  • 2016-02-06T08:44CST
  • loc_en_US, sid_182-371, PRD, sort_recentQuestionsFirst
