Dayton Audio SD215-PR 8" Passive Radiator
Brand:|Model: SD215-PR|Part # 295-492
The Dayton Audio Passive Radiators are excellent general-purpose passives suitable for replacement or for new construction.
List Price$22.99
You Save22%
$17.95
Buy 4+$17.25
Part # 295-492
The Dayton Audio Passive Radiators are excellent general-purpose passives suitable for replacement or for new construction. A built-in mass disc offers a good starting point for most designs, and a convenient M5 threaded hole (screw included) allows different types of weights to be added if desired. Cosmetically and mechanically, the passives match the Shielded DVC line of subwoofers, with a poly coated paper cone and medium-roll rubber surround for clean excursion and long life. The possibilities with these passives are endless, from floor standing two-ways to small active/passive subwoofer systems.
Specifications: • Fs: 21 Hz • Vas: 1.40 cu. ft. • Qms: 2 • Cms: 0.75 mm/N • Mms: 75 g • Sd: 194 sq. cm. • Xmax: 9 mm • Dimensions: Overall diameter: 8.50", Cutout diameter: 7.09", Depth: 2.28".
Note: Adding mass to the passive radiator will decrease Fs and increase Qms.
Tip: As a general rule the passive radiator(s) should be able to move double the volume of air as the active woofer(s)/subwoofer(s) in the system. For example: A passive radiator system for a 8" woofer/subwoofer that has 9mm of X-max would require 2-8" passive radiators with 9mm of X-max. For single passive radiator systems, it is common to use a passive that is larger than the active woofer(s)/subwoofer(s).
  • Nominal Diameter8"
  • BrandDayton Audio
  • ModelSD215-PR
  • Part Number295-492
  • UPC844632000393
  • Product CategoryPassive Radiators
    (14 Reviews)
  • Weight1 lbs.
View similar products to the Dayton Audio SD215-PR 8" Passive Radiator
in the Passive Radiators product category.
Dayton Audio SD215-PR 8" Passive Radiator is rated 4.2143 out of 5 by 14.
Rated 5 out of 5 by from Great SaleThis was to replace a worn passive radiator for a Boston hd/ 9. The quality was better than the original. And the price was right. Quick delivery too. I'm very happy.
Date published: 2015-10-20
Rated 5 out of 5 by from My 8-inch subwoofer was reborn!I was looking into replacing a somewhat noisy bass reflex port with two of these passive radiators on my Energy ESW-8 8-inch powered subwoofer. Only a couple days after placing the order they arrive at my door. My first ever experience buying from Parts-Express. I'm impressed. Their customer service and tech support have been excellent and promptly answered all the questions I had about performing this mod. Though I was dutifully warned that there's no guarantee against excursion problems due to the unavailability of exact specs on the Energy active driver. I acquired this sub at relatively little cost so I figured it was worth the risk.So I plugged the port, cut two holes on opposite sides to mount these PRs, and voila! From an entry level subwoofer with a noisy port, to an upgraded reborn sub sporting dual PRs and now I must say the difference is simply stunning! And actually looks pretty sweet, too! No more port noise, and I'm now able to drive the sub to higher dB levels than ever before. The turbulence of the factory port would not allow this as it would readily chuff before reaching anywhere near this volume level. No chuffing, just pure beautiful bass! Of course I can't exactly crank it to super high levels as it's still a small subwoofer and the PRs CAN blow if abused and Energy's ribbed elliptical surround type drivers may be a tad too long-throw for these PRs (so I'm using caution).I know PRs aren't magic, but you gotta admit, the physics behind a driver that isn't wired to anything and produces no sound on its own, yet seems to magically pump so much bass energy using nothing more than air pressure fluctuations caused by the movement of the active driver does seem like magic. They worked wonders for this little subwoofer! Such a low-cost upgrade, yet the results were little short of astounding. I'm really happy. Thanks, Parts-Express!
Date published: 2015-10-11
Rated 1 out of 5 by from Passive is an Understatementthis unit is a joke. Dayton Audio...I'm gone. This is the last DA product I'll ever bet on again.
Date published: 2015-09-30
Rated 5 out of 5 by from Contol The Bass In Reflex Full Range SpeakerI had purchased a pair of Audio Nirvana Super 8 ALNICO full range drivers after being told that they were the "perfect storm" speaker and that they provided the most bass of all the different Audio Nirvana drivers. I built an enclosure to specifications provided by the manufacture and was left with a bass reflex speaker that has fantastic mids and highs but the bass was uncontrolled and left much to be desired. They sat unused for years and then I decided to try putting a passive radiator in the enclosure to see if that would help. Wow, exactly what was needed. The passive radiator provided the control that was missing with just a 3" port. The tight and precise bass is so smooth and real. It truly was the missing piece to this loud speaker.
Date published: 2014-08-22
Rated 4 out of 5 by from Great replacement for Sunfire Tru Jr. SubwooferThe screw holes don't line up with the existing holes, but a few new screws and a drill takes care of all of that. Great replacement for the radiator of a Sunfire Junior Subwoofer. Once the woofer stretches out and gets loose, it works and sounds great.
Date published: 2014-08-06
Rated 4 out of 5 by from Replaced blown Sunfire Super Junior passive radiatorI bought this to replace a blown Sunfire Super Junior passive radiator. It fit the hole perfectly. I believe it, like any speaker, could use some warming up and stretching before criticizing it. In the week I have had it in the enclosure, I believe it has warmed up considerably. I have yet to meter the sub again and I have yet to open the amp on it but my initial observation is saying that I will need to pin the volume back a little. Great price, great value and it does the job!
Date published: 2013-09-09
  • 2016-02-07T06:35CST
  • co_hasreviews, tv_0, tr_14
  • loc_en_US, sid_295-492, PRD, sort_mostRecent
My internal ft^3 is .426, 11.5" x 8" x 8" and I'm using a TB W6-1139SIF 6-1/2" sub w/ a 60w mono amp. Will this PR work in this size enclosure? Any suggestions would be appreciated.
Asked by: They88
This combination will work well. I would recommend adding 25 grams to the passive for a tuning frequency of 38 Hz and an F3 of 41 Hz.
Date published: 2015-12-08
I'm building an overhead subwoofer for my golf cart and have (2) Dayton dcs165-4. I want to go sealed considering the elements. Would 2 of these 8" radiators help spl in an open environment like that, and what volume should I be shooting for? Thanks.
Asked by: BrianSC
The passives will help extend the bottom end but they won't provide much more output over a sealed design. If you decide to use the passives I would recommend a 0.45 cubic foot volume with 75 grams added to each which will tune the enclosure to about 45 Hz.
Date published: 2015-12-11
Would just one of these 8" passive radiators work paired with a JL-Audio 6W3v3? Or would it require 2? In such a scenario, minimum sealed box volume would be? Would weight need to be added to the PR? How is weight typically added?
Asked by: TheGDog
This will work with one passive. I would recommend a volume of 0.32 cubic feet with 75 grams added to the passive which will tune to 37 Hz and provide an F3 of 37 Hz.
Date published: 2015-10-15
To eliminate port noise on my Energy ESW-8 8-inch powered subwoofer, I'm looking to seal up the reflex port and add one (or two) of these PRs. The sub goes down to about 33-hz. Would this passive radiator fit the bill for what I need?
Asked by: albeau
It could, unfortunately we have no way of modeling anything to help with tuning or how much weight to add. If the active woofer is 8", I would recommend two 8" passives. Adding weight will drop the tuning frequency but you don't want to add more than 75 grams to each of these.
Can you use an 8 inch passive Radiator, with an 15 inch woofer, 6.25 cubic ft. cabinet? it was calling for 2 four inch ports 1 inch long, Can I use the passive instead?
Asked by: jamman69
Answered by: MattW
Date published: 2015-07-20
Would this PR be a good fit for the Dayton SD215A-88 8" sub in a .35 cu ft box? Or would I be better off leaving the subs sealed? This would be under each front seat in my car for midbass. Transient response is slightly more important than volume
Asked by: Bendy
Yes, that passive radiator will work well with the SD215A-88 in a .35Ft3.
Answered by: MattW
  • 2016-02-07T07:16CST
  • co_hasquestionsanswers, tq_17
  • loc_en_US, sid_295-492, PRD, sort_recentQuestionsFirst
