300-670_ALT_0
300-670_ALT_1
Dayton Audio SAT-BK Satellite Speaker Pair Black
Brand:| Model: SAT-BK
Dayton Audio’s compact multi-purpose speakers are designed to provide excellent clarity and detail for use in any surround sound or general audio application. These speakers are capable of much bigger sound than their small size suggests.
  • Excellent clarity and detail
  • Optimized long-excursion woofers
  • Flat, neutral frequency response
  • Indoor or outdoor use
  • Magnetically shielded to prevent interference with TV screens and computer monitors
  • Mounting hardware included
300-670
Weight: 5.8 lbs.
IN STOCK
List Price$56.99
Regular Price$43.75
You Save21%
Sale Price
$34.50
Part # 300-670
Qty:  PR
Dayton Audio’s compact multi-purpose speakers are designed to provide excellent clarity and detail for use in any surround sound or general audio application. These speakers are capable of much bigger sound than their small size suggests—the smooth blending of their optimized long-excursion woofers and poly dome tweeters is the key to their outstanding performance. All speakers are voiced matched to provide a consistent sound when used together as part of a home theater system, and they work great with Dayton Audio subwoofers. The contemporary styling and black finish allows them to blend in with any decor, while the weather-resistant design means they can be used indoors or out. Included mounting bracket hardware and rubber feet for facilitating stand-mounting, wall-mounting, or free standing operation.
Specifications: • Woofer: 3-3/4" polypropylene woofer with rubber surround • Tweeter: 5/8" polycarbonate ferrofluid cooled • Power handling: 50 watts RMS/80 watts max • Impedance: 8 ohms • Frequency response: 100-20,000 Hz • Sensitivity: 87 dB 1W/1m • Dimensions: 7-1/2" H x 4-1/2" W x 5-1/4" D • Sold in pairs.
  • Input Rating8 ohm
  • Special FeaturesIndoor / Outdoor
  • Woofer Diameter3-3/4"
  • Configuration2-way
  • ColorBlack
  • BrandDayton Audio
  • ModelSAT-BK
  • Part Number300-670
  • UPC844632054969
  • Product CategoryBookshelf Speakers
  • Unit of MeasurePR
    (61 Reviews)
  • Weight5.8 lbs.
View similar products to the Dayton Audio SAT-BK Satellite Speaker Pair Black
in the Bookshelf Speakers product category.
Dayton Audio SAT-BK Satellite Speaker Pair Black is rated 4.2623 out of 5 by 61.
Rated 5 out of 5 by from Much better than expected!I needed a pair of small speakers to fit in a specific limited space. They're to replace an aged 2.1 set of Sherwood speakers that over time had lost sharpness and clarity. For bass, I purchased a new Wharfedale Force PSB passive subwoofer. Hooked up to a 200 RMS watt receiver, I'm enjoying the sound of this combination.
Date published: 2015-04-27
Rated 5 out of 5 by from Exceeded expectationsInstalled four of these speakers (and a Lepai LP-2020A+ amplifier) as the music system in a small coffee shop. Surprisingly good sound for the price. The coffee shop owner is extremely happy with his new inexpensive "surround" setup!
Date published: 2014-12-03
Rated 5 out of 5 by from best bang for the buckGot these a month ago to use as on-wall theater surrounds with my Denon receiver (90w rated at 8ohm, also using Audessy) they blend in perfectly and sound very clear. Little to no low end of course but the 3.5inch woofers do not sound thin or tinny as you might expect. If fact, if you teamed them with a sub, you'd have a great little music system.
Date published: 2014-11-10
Rated 3 out of 5 by from Seem well made, stylishBought these to use as amplified external TV speakers, but they're a bit small to use as a pair only,. . . . . not much bass. I like their 'leaned back' style for placement by the TV. Several of these and a subwoofer should make a great set-up, but I just wanted a better, clearer sound than my TV speakers produce,. . . .and that was accomplished
Date published: 2014-11-04
Rated 4 out of 5 by from added a subI'm using these along side my bedroom tv powered by the dta-1 very happy but would like a bit crisper top end..I added a 3.5' sub from a computer speaker setup that gives me 80-250 hz which has worked very well giving the sats the bottom that was missing.the sub was 25 bucks making my bedroom audio system top out around 90 bucks..if you use my recommendations do not expect major thump, the sub is only about 10 watts I run the dta between 2-3 o'clock and the sub on 8 out of ten..I did add lots of fill to the sub and some to the sats .... the sub was purchased at wallys world it is self contained......all you need is a y connector to be up and running a aux sub home system...Jim
Date published: 2014-08-29
Rated 4 out of 5 by from Great SpeakersI bought a set of five of these (comes with 4 sat spks and center channel) to use with my new Onkyo rec I blew one of them so I bought these to replace the blown one. Love the speakers for the price you won't be disappointed. They are not top of the line quality and won't take a prolonged beating at high volume but they do exceed expectations at this price point.
Date published: 2014-06-22
  • 2015-05-05T06:44CST
  • co_hasreviews, tv_0, tr_61
  • loc_en_US, sid_300-670, PRD, sort_mostRecent
What thread are the inserts?
Asked by: Rhzx12r
The threaded inserts on these speakers are M6. Our part number 300-249 would be a good choice for wall mounting these.
Date published: 2015-01-15
Can these be mounted horizontally with the included mounts?
Asked by: Audiophool
Unfortunately the mounts that are included only allow for vertical mounting.
Date published: 2014-08-21
Would these speakers work with mounts like these: http://www.parts-express.com/sanus-wms3b-tilt-swivel-speaker-mount-pair-black--240-828  I already have similar mounts installed on my wall, so I'd like to use those instead of the included hardware.
Asked by: jknuckey
Yes these mounts will work with the Dayton speakers as long as you have the proper bolt thread on the mounts.
Date published: 2014-07-17
Are the screws that come with these supposed to fit through the key holes on the back of the mounting plates once they are screwed into the wall? The screws I got are too big to fit through that hole.
Asked by: Boxerbucks5150
Yes those are supposed to be used for wall mounting. If the screw head is slightly too big to fit the keyhole you may have to use a smaller screw.
Date published: 2014-06-24
Would the part number 275-025 be a suitable tweeter upgrade for this speaker if I could make it fit?
Asked by: rome2000
Technically it will work as a replacement tweeter but there will likely need to be heavy modifications required to get it to mount.
Date published: 2014-07-06
Which speaker connection would be better for these speakers, Banana Plugs or Spade connectors?
Asked by: MonoPestoso
Spade...Banana is too much bulk.
Answered by: MarkC.
  • 2015-05-05T09:49CST
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_300-670, PRD, sort_recentQuestionsFirst
Customer projects that include: Dayton Audio SAT-BK Satellite Speaker Pair Black
