BONUS ITEM INCLUDED
300-492_ALT_0
300-492_ALT_1
300-492_ALT_2
300-492_ALT_3
Dayton Audio SA230/2VS8 Dual Subwoofer System Amplifier Bundle
Brand:|Model: SA230/2VS8|Part # 300-492
Dayton Audio has combined two VS8 subwoofer systems with the SA230 amplifier for an unstoppable package. Place the compact subwoofers under a couch, chair, or table, without being constrained by the amplifier's location.
List Price$649.99
You Save35%
$423.86
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
*Domestic US orders only
Part # 300-492
  • Two long-excursion 8" DVC subwoofers
  • 230W mono Class AB amplifier
  • Optimized combination for home theater applications
  • Low-profile subwoofer enclosures with modern finish
  • Design yields limitless placement options
Dayton Audio's SA230/2VS8 dual subwoofer package includes two modern low-profile subwoofers and a powerful stand-alone amplifier for a combination that promises to be heard but not seen. The Dayton Audio VS8 was designed and engineered to work specifically with the SA230 amplifier for clean and punchy bass that enhances any home audio system. Having two VS8s working together means more bass to fill up your room, while utilizing the full potential of the SA230 amplifier.
Each VS8 subwoofer system contains an 8" long-throw dual voice coil driver. The complex bass reflex design utilizes a flared port to produce much more bass than expected from such a small enclosure. The omni-directional dispersion characteristics and shallow enclosure of this subwoofer facilitate limitless placement options. The VS8 fits between wall studs, and is easy to install (requires a Dayton Audio VS8IG in-wall mounting kit.). Place underneath or behind furniture in a down-firing position using the included rubber feet, which elevate the subwoofer and protect surfaces. The VS8 is finished in a dark brushed aluminum-look vinyl wrap that complements any décor.
The Dayton Audio SA230 amplifier delivers all of the clean, solid power required to drive two VS8's to their full potential. Its tabletop design is compatible with many other popular electronic devices and different styles of multimedia furniture. This amplifier is engineered to provide high fidelity subwoofer amplification and is tailored for home audio and home theater audio systems. Its variable gain, bass boost, crossover frequency, and phase adjustment guarantee perfect integration with any audio system in any listening environment. Short circuit and thermal overload protection are included.
VS8 Subwoofer Specifications: • 8" long-throw DVC subwoofer • Power handling: 120 watts RMS (60 watts RMS per coil) Impedance: 8 ohm single channel, 2 ohm single channel, 4 ohm dual channel • Frequency response: 35 – 200 Hz • Sensitivity: 87.5 dB 1W/1M • Dimensions: 18-7/8" H x 14" W x 2-3/4" D.
SA230 Amplifier Specifications: • Rated power output (1% THD): 156 watts into 8 ohms, 233 watts into 4 ohms • Signal to noise ratio: 85 dB A-weighted • Input impedance: 12K ohms • Gain: 0 dB to +10 dB • Bass boost: 25 Hz to 50 Hz • Low pass adjustment: 80 Hz to 180 Hz @ 18 dB/octave • Phase adjustment: 0° to 180° • Dimensions: 17-1/4" W x 3-3/4" H x 13-7/8" D • Power requirements: 120/230 VAC, 50/60 Hz • Stand-by power rating: 120V 0.82W • Weight: 18 lbs.
Dayton Audio SA230/2VS8 Dual Subwoofer System Amplifier Bundle includes the following items:
Qty Part # Item
1300-813Dayton Audio SA230 230W Subwoofer Amplifier
2300-490Dayton Audio VS8 8" Universal Low-Profile Subwoofer
  • ConfigurationSubwoofer
  • Woofer Diameter8"
  • BrandDayton Audio
  • ModelSA230/2VS8
  • Part Number300-492
  • UPC844632089619
  • Product CategoryPassive Subwoofers
  • Weight51 lbs.
View similar products to the Dayton Audio SA230/2VS8 Dual Subwoofer System Amplifier Bundle
in the Passive Subwoofers product category.
