Clearance Item
240-760_ALT_0
240-760_ALT_1
Dayton Audio S3GS43 Satellite Speaker Stand Pair Square Glass Base
Brand:| Model: S3GS43
Dayton Audio speaker stands are the ideal accessory to your home theater or stereo sound system. These satellite speaker stands can be adjusted from 27" to 43" in height, raising the speaker to the optimum listening height.
  • Elegant square glass base
  • Chrome ring at the bottom of support tube
  • Adjustable spikes on base plate
  • Speaker cable channel through tube
  • Multi-mount for easy attachment of most speakers
  • Supports up to 5 lbs.
240-760
Weight: 8.14 lbs.
IN STOCK
List Price$42.99
You Save24%
$32.87
Buy 6-up$30.19
Part # 240-760
Qty:  PR
Dayton Audio speaker stands are the ideal accessory to your home theater or stereo sound system. The satellite speaker stands can be adjusted from 27" to 43" in height, raising the speaker to the optimum listening height. The overall design of these speaker stands is an experience in subtle detail. The bottom plate is an elegant 3/8" clear glass with adjustable chrome spikes and measures 8 1/2" x 8 1/2". The textured steel post that supports the top plate is accent at the bottom with a chrome ring. The multi-mount allows you to attach almost any satellite speaker easily and can support up to 5 lbs. The stands weigh 8.14 lbs per pair. These satellite speaker stands are the perfect companion to the SSGS24 24" Glass Base Speaker Stands.
  • BrandDayton Audio
  • ModelS3GS43
  • Part Number240-760
  • UPC844632077821
  • Product CategorySpeaker Stands
  • Unit of MeasurePR
    (4 Reviews)
  • Weight8.14 lbs.
  • Case Qty5
View similar products to the Dayton Audio S3GS43 Satellite Speaker Stand Pair Square Glass Base
in the Speaker Stands product category.
Dayton Audio S3GS43 Satellite Speaker Stand Pair Square Glass Base is rated 3.75 out of 5 by 4.
Rated 3 out of 5 by from Needs better quality control.These are great stands once you get the correct hardware.I ordered(4 - 2 pairs) of these a few weeks ago and once I received them there was a chip on one of the glass bases and one of the pole bases was stripped and wouldn't allow the nut to be screwed on. Also, the screw in feet would not screw in all the way on 3 of them. Once all the issues were fixed they were assembled in no time at all and they work quite well. I use them with the Energy Take Classic 5 speaker system and they fit perfectly on these! If you don't mind possibly going through some "issues" with these they are very nice looking and worth the money.Please note the 3 star rating is for the product, not Parts Express. They were exceptional working with on all the issues I had with these.
Date published: 2012-11-05
Rated 4 out of 5 by from Economical BeautyThese speaker stands are priced very well and I trust the parts express name and product so I decided to give them a try. They came with a square glass base with 4 metal spike feet. The 90% mount on top is made of plastic and my Dayton HTP-3 5.1 Home Theater satellite speakers which I thought that these where made for sagged on them. There is a hole close to the top of each pole to route the wiring inside the pole. Slick but the hole has sharp edges, which I would recommend radiuses with a deburring as another reviewer stated so the wire would slide through without being cut and to prevent future abrasion. The look with the wire hidden in the stand is very clean except for the very back of the speaker maybe I didn t know how to install it but I couldn't cover the wiring on the very back of the speaker w/the cover that I thought came w/the stands for that purpose. The assembly instructions were incomplete when it came to mounting the pole to the glass base but it was easy to figure out once you look at all the parts. Just be sure to use a plastic washer between the nuts on the pole and the glass plates. 4 plastic washers are provided for that purpose. Considering the sale price, these are still a decent value.
Date published: 2010-12-27
Rated 5 out of 5 by from Happy with purchaseFast shipping, easy to set up and looks great !
Date published: 2010-03-09
Rated 3 out of 5 by from For Small, Light SpeakersMine came with a round glass base with 3 feet, not the pincushion, 4 footed, base as described and shown. I'm okay with that since three feet are better kinematically. The 90 mount on top is made of plastic and my 4.5lb Minimus 7's sagged when mounted. A 1/2" rubber spacer (Not included) between the bottom of the speaker and the pole helped a lot. There is a hole close to the top of each pole to route the wiring inside the pole. Slick but the hole has sharp edges, which I radiused with a deburring tool so the wire would slide through without being cut and to prevent future abrasion.The assembly instructions were incomplete when it came to mounting the pole to the glass base but it was easy to figure out once you look at all the parts. Just be sure to use a plastic washer between the nuts on the pole and the glass plates. 4 plastic washers are provided for that purpose. My 3 footed stands are a bit wobbly on our thin carpeted floor, with no padding, so running the wires through the poles is a good idea to minimize non-concentric forces that could tottle them.Considering the sale price, these are a pretty good value.
Date published: 2010-01-15
  • 2015-01-31T22:55CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_240-760, PRD, sort_mostRecent
Customer projects that include: Dayton Audio S3GS43 Satellite Speaker Stand Pair Square Glass Base
