Dayton Audio RSS460HO-4 18" Reference HO Subwoofer 4 ohm
Brand:|Model: RSS460HO-4|Part # 295-472
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
List Price$324.99
You Save19%
$261.78
Buy 4+$245.97
Part # 295-472
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Extra-thick black anodized aluminum cone for maximum rigidity
  • Triple shorting ring motor for ultra-low distortion
  • 4-layer coil for high power handling
  • Optimized parameters for relatively small enclosures
  • Highest quality materials throughout for long-lasting performance
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intemodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
A knock-down 4.0 cubic foot subwoofer cabinet built specifically for the RSS460HO-4 is available here. Save over $40 off the price of the cabinet when you buy the cabinet and RSS460HO-4 subwoofer (at regular price) together in this package.
  • Nominal Diameter18"
  • Power Handling (RMS)900 Watts
  • Power Handling (max)1800 Watts
  • Impedance4 ohms
  • Frequency Response20 to 500 Hz
  • Sensitivity93 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)18.8 Hz
  • DC Resistance (Re)3.2 ohms
  • Voice Coil Inductance (Le)2.24 mH
  • Mechanical Q (Qms)4.05
  • Electromagnetic Q (Qes)0.35
  • Total Q (Qts)0.32
  • Compliance Equivalent Volume (Vas)9.61 ft.³
  • Mechanical Compliance of Suspension (Cms)0.14 mm/N
  • BL Product (BL)23.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)499g
  • Maximum Linear Excursion (Xmax)12.75 mm
  • Surface Area of Cone (Sd)1164 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.17"
  • Baffle Cutout Diameter16.69"
  • Depth8.94"
  • # Mounting Holes8
  • Sealed Volume3.04 ft.³
  • Sealed F340 Hz
  • Vented Volume7.5 ft.³
  • Vented F323 Hz
  • BrandDayton Audio
  • ModelRSS460HO-4
  • Part Number295-472
  • UPC844632099618
    (16 Reviews)
  • Weight42.35 lbs.
View similar products to the Dayton Audio RSS460HO-4 18" Reference HO Subwoofer 4 ohm
