Dayton Audio RSS390HF-4 15" Reference HF Subwoofer 4 Ohm
Brand:|Model: RSS390HF-4|Part # 295-468
Engineered to provide high-volume, low-distortion bass in larger rooms and other highly demanding applications, the Dayton Audio RSS390HF-4 15" Reference Series subwoofer speaker offers the perfect combination of high definition sound quality and low frequency impact.
List Price$224.99
You Save23%
$172.69
Buy 4+$165.18
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 295-468
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Lightweight black anodized aluminum cone for rigidity and lower moving mass
  • Triple shorting ring motor for ultra-low distortion
  • 2-layer coil for reduced back EMF
  • Suitable for sealed or vented enclosures
  • Highest quality materials throughout for long-lasting performance
The Dayton Audio Reference Series RSS390HF-4 15" speakers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intemodulation distortion are kept extremely low by utilizing three magnetic short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose the high fidelity version for home systems when you are looking for clean, low bass and are not restricted by cabinet size.
  • Nominal Diameter15"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)1000 Watts
  • Impedance4 ohms
  • Frequency Response18 to 800 Hz
  • Sensitivity91.2 dB 2.83V/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight150 oz.
  • Resonant Frequency (Fs)19.5 Hz
  • DC Resistance (Re)3 ohms
  • Voice Coil Inductance (Le)0.92 mH
  • Mechanical Q (Qms)3.02
  • Electromagnetic Q (Qes)0.50
  • Total Q (Qts)0.43
  • Compliance Equivalent Volume (Vas)7.49 ft.³
  • Mechanical Compliance of Suspension (Cms)0.22 mm/N
  • BL Product (BL)15 Tm
  • Diaphragm Mass Inc. Airload (Mms)306g
  • Maximum Linear Excursion (Xmax)14 mm
  • Surface Area of Cone (Sd)829.6 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.29"
  • Baffle Cutout Diameter14.01"
  • Depth7.01"
  • # Mounting Holes8
  • Sealed Volume2.88 ft.³
  • Sealed F337 Hz
  • Vented Volume8.96 ft.³
  • Vented F321 Hz
  • BrandDayton Audio
  • ModelRSS390HF-4
  • Part Number295-468
  • UPC844632055027
    (49 Reviews)
  • Weight30 lbs.
View similar products to the Dayton Audio RSS390HF-4 15" Reference HF Subwoofer 4 Ohm
Dayton Audio RSS390HF-4 15" Reference HF Subwoofer 4 Ohm is rated 4.7143 out of 5 by 49.
Rated 5 out of 5 by from Only one night in, but certainly shakes the house!I recently installed this into an empty AV123 MFW-15 Moho cabinet I bought at the AV123 auction when they were going out of business. Since I've been satisfied with the bass output of my AV123 LS-6's, the cabinet sat in my garage for the last 5+ years waiting for a "turbo upgrade" I could never afford. After reading a review on a another forum where someone installed this woofer with success in a MFW cabinet, I decided to give it a try and couple it with a Bash 300 plate amp for about a third of the turbo upgrade price. I am barely into break in at this point, but after a few hours of listening to Dolby Atmos demo's and a couple movies segments, I can easily say that I made the right choice to buy this. The LS's have plenty of musical bass output and I'm really only craving the seat/window/house shaking experience that I was lacking and this certainly does the trick!! I will play with some more settings tonight, and test some music on it as well, but needless to say it was money well spent and If I should need a car subwoofer in the future, this will be it as well. Great product at a great price!!!
Date published: 2016-01-21
Rated 1 out of 5 by from Voice coil came apart 300w Dayton denies warranty.Has this sub the 5.3ft enclosure recommended by Matt P on here 15 min into our Christmas party it starts making scratching noise. They said the voice coil former was bottomed and broke off, or as I suspect, the voice cool split and bottomed before I could get over to shut it off. Anyways, I replaced it with a Stereo Integrity HT18 rated at a lower rms@ 600 but it sounds better, it's louder and will definitely handle more power. I own 9 other Dayton audio products but after their handling of this I won't buy again.
Date published: 2015-10-01
Rated 5 out of 5 by from Amazing sound quality and depthI went from a 12" RE Audio sub at half the price to this sub and could instantly hear and feel the difference. It looks great in my Dayton Audio 2 cu. ft. Cherry Cabinet although the grill doesn't fit right because of the width of the frame. I'll try extending the grill with some round disc magnets.
Date published: 2015-07-04
Rated 5 out of 5 by from Great value, excellent product, fast safe shippingGreat value and very fast and safe shipping. I bought the sub to replace a torn cone subwoofer in an older Definitive 1500 Powerfield sub that was otherwise in good condition. This company was recommended by a Definitive tech because they didn't make a direct replacement anymore. The told me what to look for and I found and installed this sub myself. The bass is fantastic and nice and tight. I couldn't be happier with the purchase.
Date published: 2015-04-17
Rated 5 out of 5 by from Made an Audiophile subwooferI wanted a music sub woofer, not a boombox, to compliment my Klipsch LaScala speakers. I installed this Speaker in a sealed 5.5 cu ft well braced box made from birch plywood lined with fiberglass with wood screws 3 inches apart. I made a separate box for the Bash 500 plate amplifier to keep the box good and tight. I wanted good low tight defined bass to blend with the horn loaded bass from the Lascala's. The sound is superb and exceeded my expectations. I hear now what I have been missing all these years. Bass like this was unattainable when I first started buying equipment but with 500 watt amplifiers and 15" speakers that can take the power it is now possible at a reasonable cost. Be forewarned that this is a large box and the speaker would most likely sound as good in a smaller box but size is not a problem with me. Parts Express service was superb. For some reason there was not a power cord with the Bash and after calling them one was sent that day and I received it 2 days later.
Date published: 2014-10-16
Rated 5 out of 5 by from Very Good SubsBrilliant speakers, use two of these to play Dub Reggea, very nice clean & Deep Bass at low volumes.Delivery was quiet quick with no problems.I have already recommended to friends.
Date published: 2014-06-03
  • 2016-02-05T06:15CST
  • co_hasreviews, tv_0, tr_49
  • loc_en_US, sid_295-468, PRD, sort_mostRecent
Looking at your subwoofer kit that uses your SPA1000 amp and two RSS315HFA-8 12" speakers.  Was wondering if I replaced 12" speakers with 15" say RSS390HF-4 15" if they might mate up?  Matching my Kiplish RSW15 dual subwoofer
Asked by: Home theater
I understand that this is the recomended speaker for BFM Home theater horn loaded sub. My question is would it also be suitable for Dj use in that configuration. http://www.billfitzmaurice.com/THT.html
Asked by: Dj ZONE
The THT was designed for *HOME* *THEATER* use (hence the name). The driver is not a pro level driver, and the volume of the enclosure is appropriate for home use, not for nightclub / bar use. If you want to play gigs, build a pro sub, like T24, T30, T45, T60. BFM had many designs, each well suited to their own realms.
Answered by: Chunder from down under
Date published: 2016-01-22
I have a pair of these (RSS390HF-4) that i am putting in a 4.75ft3 sealed boxes. I'm looking to power them with either a QSC GX5 or maybe go a little cheaper with a Behringer EPX2800. Any thoughts on which 1 or should I go with something else entirely?
Asked by: BalooTheBear
Either of those will work in terms of power output. You might also consider something like the NU3000DSP which will help you dial the room response into something much smoother sounding.
Date published: 2016-01-14
I HAVE A 2 CHANNEL AMP THATCAN PUSH 750  4 OHMS IS THIS ENOUGH TO DRIVE THIS I WANT TO USE FOR HOME THEATER  IS  THERE  A GOOD PORTED ENCLOSER WITH A FRONT FIRING SLOT ANY IDEAS
Asked by: JOHNNY66
That amp will be fine for this woofer. Unfortunately we do not have any ported enclosures available for this woofer.
I have just built a house and the main room will be 40ftx22ft x 16ft high into a vaulted ceiling, the room is also the kitchen and dining room but one end will be the listening area, need to fill this with bass 2 subs? HF or Umax?
Asked by: mauineilc
Date published: 2015-12-21
What would be the smallest vented box I could use with this sub with a max height of 19"
Asked by: Scotto
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-12-18
  • 2016-02-05T06:57CST
  • co_hasquestionsanswers, tq_50
  • loc_en_US, sid_295-468, PRD, sort_recentQuestionsFirst
