Dayton Audio RSS315HO-4 12" Reference HO Subwoofer 4 Ohm
Brand:|Model: RSS315HO-4|Part # 295-466
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
List Price$193.99
You Save23%
$149.38
Buy 4+$143.26
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
Part # 295-466
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Extra-thick black anodized aluminum cone for maximum rigidity
  • Triple shorting ring motor for ultra-low distortion
  • 4-layer coil for high power handling
  • Optimized parameters for small enclosures
  • Highest quality materials throughout for long-lasting performance
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose the high output version for automotive applications or for equalized high-power home subwoofers.
A knock-down 1.25 cubic foot subwoofer cabinet built specifically for the RSS315HO-4 is available here. Save 50% off the price of the cabinet when you buy the cabinet and RSS315HO-4 subwoofer (at regular price) together in this package only.
  • Nominal Diameter12"
  • Power Handling (RMS)700 Watts
  • Power Handling (max)1400 Watts
  • Impedance4 ohms
  • Frequency Response26 to 600 Hz
  • Sensitivity90.5 dB 2.83V/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight150 oz.
  • Resonant Frequency (Fs)26.2 Hz
  • DC Resistance (Re)3.2 ohms
  • Voice Coil Inductance (Le)1.75 mH
  • Mechanical Q (Qms)3.63
  • Electromagnetic Q (Qes)0.33
  • Total Q (Qts)0.31
  • Compliance Equivalent Volume (Vas)1.89 ft.³
  • Mechanical Compliance of Suspension (Cms)0.15 mm/N
  • BL Product (BL)20 Tm
  • Diaphragm Mass Inc. Airload (Mms)280.9g
  • Maximum Linear Excursion (Xmax)12.3 mm
  • Surface Area of Cone (Sd)514.7 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.36"
  • Baffle Cutout Diameter11.1"
  • Depth5.75"
  • # Mounting Holes8
  • Sealed Volume0.33 ft.³
  • Sealed F366 Hz
  • Vented Volume0.98 ft.³
  • Vented F336 Hz
  • BrandDayton Audio
  • ModelRSS315HO-4
  • Part Number295-466
  • UPC844632006944
    (31 Reviews)
  • Weight25 lbs.
View similar products to the Dayton Audio RSS315HO-4 12" Reference HO Subwoofer 4 Ohm
Dayton Audio RSS315HO-4 12" Reference HO Subwoofer 4 Ohm is rated 4.8387 out of 5 by 31.
Rated 5 out of 5 by from Build quality.Working perfect. Sounds great as a stereo sub also matched well with the other sub. Will be even better when I build the cabinet this spring.
Date published: 2015-01-19
Rated 5 out of 5 by from ThumperGreat sounding. Plays loud. Made a 1.75ft box with 14.5x1.25x 26" port. More than surprising with Dayton 500watt plate amp
Date published: 2015-01-12
Rated 5 out of 5 by from House Shak'inBuilt my very first sub and it turned out way better then expected. The Yung SD-500 plate amp is set at 3 with reciever setting for sub level set at 3 and this thing shakes it like a "Wild Thing"!!!
Date published: 2014-04-24
Rated 5 out of 5 by from Excellent subwoofer for the moneyI originally purchased one of these to take the place of a blown MK subwoofer. I was so happy with the result I purchased a second. MK subwoofers are always sealed designs, so both of these started as sealed subs in a 2 cubic foot box (each). I enjoyed the sound and fed them appropriate power (one had a 300W bash and the other a 500W bash). After modeling one day, I realized I was leaving some bass on the table, as my F3 in a sealed box was close to 60hz. I quickly drafted plans to port and ended up with a 23" long, 4" diameter port in each box. The sound is simply incredible. My F3 is now about 25hz and the overall sound is so rich and full. I was disappointed with them after awhile in the sealed form, but now after more than a year in ported I still find ways to show them off. I have switched to a pro amp giving each about 550W and they seem to love it. So, in conclusion, I am running them each in a ported MK V75 enclosure tuned to 25hz. They are rich, full and loud. Amazing value, as these are true beasts; you can tell when you see them in person.
Date published: 2013-05-17
Rated 5 out of 5 by from An affordable beast of a subI'm not an audiophile but I pretend to be. In the car I have always stuck to more common brand names for car audio. This sub replaced a 10" Kicker Solo-Baric from the late 90's that actually still worked like a champ but I wanted an upgrade.Right out of the box I was impressed with this sub. It's heavy and well made. The fit and finish are great in my eyes. I don't need flashy so this is perfect. I put it in a sealed 0.82 cu. ft. box. The box is 3/4" MDF and the front baffle is 1.5" thick. I have it powered by an Alpine PDX 1.600 which is run by an Audio Control LC7i. I have the gain all the way down and it kicks! I have played some tones in the high 20Hz range and they are acceptable. It drops off quick below that. The sub is what I wanted, musical, punchy but will still hit those low notes when they're there.If I have one gripe so far it's that the mounting holes are so close to the required cutout that there's not much material to play with. I tried to use some threaded inserts and they were too close to the cutout. I should have made the cutout even tighter.
Date published: 2013-03-27
Rated 5 out of 5 by from Great Sub for a Great Price!All i can say is this sub sound great! in my Car. The box for the sub is about .80cubic feet and given the sub only 600watt and it wants More Power! ....... The build quality is solid cast aluminum very very heavy magnet......Sorry... my English is my second langue....
Date published: 2013-02-19
  • 2016-02-06T06:52CST
  • co_hasreviews, tv_0, tr_31
  • loc_en_US, sid_295-466, PRD, sort_mostRecent
Is this subwoofer driver designed for home or car application?
Asked by: pato
This will work for either application.
Date published: 2016-01-20
Hi, How much space is occupied by the magnet structure inside the box? Regards, Per-Arne
Asked by: Pelle
This driver displaces 0.135 cubic feet.
Date published: 2016-01-07
I need 12" subs for 2 existing sealed enclosures at 1.45 ft each for my home theater system (movies and music).  My amp is a crown ce1000 that makes 560 x 2 @ 2ohms or 1100 x 1 @ 4 ohms. I'm mainly interested in sound quality.  Are these a good choice?
Asked by: Scot D
Yes these will work very well for that application.
Date published: 2016-01-04
Do you have this in an 8ohm?
Asked by: Apostolicman
Unfortunately we only have the high fidelity model available in 8 ohm.http://www.parts-express.com/dayton-audio-rss315hfa-8-12-reference-hf-subwoofer-8-ohm--295-445
Date published: 2015-06-19
1 cubic foot box tuned to 32hz to be used in a car. f3, f10, and max spl? also, will 17 square inches of port area be large enough to not present any port noise issues?
Asked by: tyler99
With that volume and tuning, your F3 is 33 Hz and your F10 is 24 Hz. Maximum SPL with 700 watts is ~115 dB (modeled). That should be enough port area but the length would need to be 37" for a 32 Hz tune.
Date published: 2015-06-17
WHAT IS THE COUNTER SINK DEPTH OF THE WOOFER?
Asked by: Wild Bill 4
The frame of this woofer is 9.6mm thick for countersinking.
Date published: 2015-06-15
  • 2016-02-06T08:06CST
  • co_hasquestionsanswers, tq_34
  • loc_en_US, sid_295-466, PRD, sort_recentQuestionsFirst
