Dayton Audio RSS315HFA-8 12" Reference HF Subwoofer 8 Ohm
Brand:|Model: RSS315HFA-8|Part # 295-445
Dayton Audio's Reference Series RSS315HFA-8 12" subwoofer utilizes the same low-distortion design as the rest of the series, but provides an 8 ohm alternative for increased connection and impedance-loading options.
List Price$193.99
You Save23%
$149.29
Buy 4+$142.19
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
*Domestic US orders only
Part # 295-445
  • Extensively vented motor eliminates power compression and allows quiet excursion
  • Lighter-weight black anodized aluminum cone minimizes moving mass
  • 2-layer coil for reduced back EMF
  • Triple shorting-ring motor for ultra-low distortion
  • Optimized for large enclosures
  • Highest quality materials throughout for long-lasting performance
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of the RSS315HFA-8 12" driver is ultra-low-distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three magnetic short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose this High Fidelity (HF) version for home speaker systems when your priority is clean, low bass and you are not restricted by cabinet size.
  • Nominal Diameter12"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)700 Watts
  • Impedance8 ohms
  • Frequency Response25 to 1,500 Hz
  • Sensitivity85.7 dB 2.83V/1m
  • Voice Coil Diameter2.58"
  • Resonant Frequency (Fs)22.2 Hz
  • DC Resistance (Re)6.5 ohms
  • Voice Coil Inductance (Le)1.56 mH
  • Mechanical Q (Qms)2.50
  • Electromagnetic Q (Qes)0.54
  • Total Q (Qts)0.45
  • Compliance Equivalent Volume (Vas)3.43 ft.³
  • Mechanical Compliance of Suspension (Cms)0.27 mm/N
  • BL Product (BL)18 Tm
  • Diaphragm Mass Inc. Airload (Mms)194g
  • Maximum Linear Excursion (Xmax)14.3 mm
  • Surface Area of Cone (Sd)506.7 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.36"
  • Baffle Cutout Diameter11.1"
  • Depth5.75"
  • # Mounting Holes8
  • Sealed Volume1.54 ft.³
  • Sealed F340 Hz
  • Vented Volume4.63 ft.³
  • Vented F320 Hz
  • BrandDayton Audio
  • ModelRSS315HFA-8
  • Part Number295-445
  • UPC844632088681
    (7 Reviews)
  • Weight24.5 lbs.
View similar products to the Dayton Audio RSS315HFA-8 12" Reference HF Subwoofer 8 Ohm
