Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 Ohm
Brand:|Model: RSS315HF-4|Part # 295-464
The Dayton Audio Reference Series subwoofer speakers take the quality and performance of the much acclaimed RS line into the subwoofer realm. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$193.99
You Save23%
$149.29
Buy 4+$142.19
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
*Domestic US orders only
Part # 295-464
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Lightweight black anodized aluminum cone for rigidity and lower moving mass
  • Triple shorting ring motor for ultra-low distortion
  • 2-layer coil for reduced back EMF
  • Suitable for sealed or vented enclosures
  • Highest quality materials throughout for long-lasting performance
As with the rest of the Dayton Audio Reference Series speakers, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion for the Reference Series RSS315HF-4 12" subwoofer speaker. The black anodized cone, rubber surround, and custom basket give this driver and the rest of the Reference Series a unique, high-end look. Choose the high fidelity version for home systems when you are looking for clean, low bass and are not restricted by cabinet size.
  • Nominal Diameter12"
  • Power Handling (RMS)400 Watts
  • Power Handling (max)800 Watts
  • Impedance4 ohms
  • Frequency Response23 to 1,000 Hz
  • Sensitivity90.3 dB 2.83V/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight150 oz.
  • Resonant Frequency (Fs)24.2 Hz
  • DC Resistance (Re)3.1 ohms
  • Voice Coil Inductance (Le)0.96 mH
  • Mechanical Q (Qms)2.83
  • Electromagnetic Q (Qes)0.45
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)2.97 ft.³
  • Mechanical Compliance of Suspension (Cms)0.23 mm/N
  • BL Product (BL)13.99 Tm
  • Diaphragm Mass Inc. Airload (Mms)188g
  • Maximum Linear Excursion (Xmax)14.3 mm
  • Surface Area of Cone (Sd)514.7 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.36"
  • Baffle Cutout Diameter11.1"
  • Depth5.75"
  • # Mounting Holes8
  • Sealed Volume1.70 ft.³
  • Sealed F340 Hz
  • Vented Volume4.54 ft.³
  • Vented F322 Hz
  • BrandDayton Audio
  • ModelRSS315HF-4
  • Part Number295-464
  • UPC844632006937
    (68 Reviews)
  • Weight25 lbs.
View similar products to the Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 Ohm
