Dayton Audio RSS265HO-44 10" Reference HO DVC Subwoofer
Brand:|Model: RSS265HO-44|Part # 295-463
The RSS265HO-44 10" High Output Reference Subwoofer from Dayton Audio is designed for high power handling and extremely low distortion. A small enclosure requirement allows it to be used in car audio and space limited home audio applications.
List Price$189.99
You Save26%
Buy 4+$132.94
Dayton Audio Baseball Cap
Qty: 1Part # 520-308
List Price:$19.99
*Domestic US orders only
Part # 295-463
  • Dual 4 ohm voice coils for many wiring options
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Extra-thick black anodized aluminum cone for maximum rigidity
  • Triple shorting-ring motor for ultra-low distortion
  • Parameters optimized for small enclosures
  • Highest quality materials throughout for long-lasting performance
Dayton Audio's 10" RSS265HO-44 High Output Reference Series subwoofer is purpose-built for moving lots of air, extreme power handling, extremely low distortion... and it does it all with an extremely small enclosure requirement! The minimum airspace optimization of this driver makes it perfect for car audio automotive applications and limited space home audio applications.
To minimize distortion, three copper short-circuit paths are built into the motor. This reduces second, third, and intermodulation distortion to levels only attained previously by expensive, exotic subwoofers. A side benefit is reduced energy storage and inductance, making the RSS265-HO-44 a very musical subwoofer. In fact, frequency response remains very flat up to 500 Hz.
Additional features include: a heavy gauge black anodized aluminum cone that resists deformation from extreme air pressure levels found inside of small sealed enclosures, a fully ventilated motor for reduced power compression, a rigid cast aluminum frame for structural integrity, and a tough rubber surround that won't wear down over years of use. Dual 4-ohm voice coils allow for a wide array of wiring options.
As with all Dayton Audio subwoofers, you receive a full 5-year warranty. Designed and engineered in the U.S.A.
  • Nominal Diameter10"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)1200 Watts
  • Impedance2 ohms
  • Frequency Response25 to 600 Hz
  • Sensitivity90.5 dB 2.83V/1m
  • Voice Coil Diameter2.58"
  • Resonant Frequency (Fs)27.6 Hz
  • DC Resistance (Re)1.6 ohms
  • Voice Coil Inductance (Le)0.77 mH
  • Mechanical Q (Qms)4.42
  • Electromagnetic Q (Qes)0.50
  • Total Q (Qts)0.45
  • Compliance Equivalent Volume (Vas)1.23 ft.³
  • Mechanical Compliance of Suspension (Cms)0.21 mm/N
  • BL Product (BL)9.39 Tm
  • Diaphragm Mass Inc. Airload (Mms)161g
  • Maximum Linear Excursion (Xmax)13.25 mm
  • Surface Area of Cone (Sd)352.3 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Overall Outside Diameter10.5"
  • Baffle Cutout Diameter9.25"
  • Depth5"
  • Sealed Volume0.55 ft.³
  • Sealed F346 Hz
  • Vented Volume1.5 ft.³
  • Vented F322 Hz
  • BrandDayton Audio
  • ModelRSS265HO-44
  • Part Number295-463
  • UPC848791000324
    (3 Reviews)
  • Weight17.2 lbs.
View similar products to the Dayton Audio RSS265HO-44 10" Reference HO DVC Subwoofer
in the Car Subwoofer Speakers product category.
