Dayton Audio RSS265HF-4 10" Reference HF Subwoofer 4 Ohm
Brand:|Model: RSS265HF-4|Part # 295-460
The Dayton Audio RSS265HF-4 10" subwoofer features the high-definition/low-distortion attributes of the acclaimed Reference Series, and provides great results in compact single-driver subwoofer speaker systems...or when used in multiples!
OUT OF STOCK
Due In: 8/11/2016
List Price$176.99
You Save23%
$135.86
Buy 4+$129.39
Part # 295-460
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Lightweight black anodized aluminum cone for rigidity and lower moving mass
  • Suitable for sealed or vented enclosures
  • Triple shorting ring motor for ultra-low distortion
  • 2-layer coil for reduced back EMF
  • Highest quality materials throughout for long-lasting performance
As with the rest of the Reference Series, the main focus of the Dayton Audio RSS265HF 10" subwoofer is ultra-low distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, thick rubber surround, and custom basket give this Dayton Audio driver a unique, high-end look. Choose the High Fidelity (HF) version for home systems when you are looking for clean, low bass and are not restricted by speaker cabinet size.
  • Nominal Diameter10"
  • Power Handling (RMS)350 Watts
  • Power Handling (max)700 Watts
  • Impedance4 ohms
  • Frequency Response22 to 1,000 Hz
  • Sensitivity87.8 dB 2.83V/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight100 oz.
  • Resonant Frequency (Fs)25.6 Hz
  • DC Resistance (Re)3.5 ohms
  • Voice Coil Inductance (Le)0.96 mH
  • Mechanical Q (Qms)3.06
  • Electromagnetic Q (Qes)0.53
  • Total Q (Qts)0.45
  • Compliance Equivalent Volume (Vas)1.90 ft.³
  • Mechanical Compliance of Suspension (Cms)0.32 mm/N
  • BL Product (BL)11.43 Tm
  • Diaphragm Mass Inc. Airload (Mms)120g
  • Maximum Linear Excursion (Xmax)12.3 mm
  • Surface Area of Cone (Sd)356.3 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.47"
  • Baffle Cutout Diameter9.25"
  • Depth5.37"
  • # Mounting Holes6
  • Sealed Volume0.53 ft.³
  • Sealed F351 Hz
  • Vented Volume1.68 ft.³
  • Vented F327 Hz
  • BrandDayton Audio
  • ModelRSS265HF-4
  • Part Number295-460
  • UPC844632006913
    (48 Reviews)
  • Weight18 lbs.
View similar products to the Dayton Audio RSS265HF-4 10" Reference HF Subwoofer 4 Ohm
