Dayton Audio RS75T-8 3" Reference Full-Range Driver Truncated Frame
Brand:|Model: RS75T-8|Part # 295-336
Incorporating a low-distortion motor system with a copper ring, a copper cap, and an aluminum phase plug, the RS75T-8 can outperform "boutique" drivers that cost several times the price.
List Price$32.99
You Save25%
$24.74
Buy 4+$22.68
Part # 295-336
  • Truncated cast frame—great for line arrays and MTM speaker designs
  • Full-range performance
  • Low distortion and high resolution
  • Aluminum frame, aluminum cone, rubber surround
  • Distortion-reducing copper ring, copper cap, and aluminum phase plug
  • Subtle yet high-tech look makes a bold cosmetic statement
  • Designed and engineered in USA
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Incorporating a low-distortion motor system with a copper ring, a copper cap, and an aluminum phase plug, the RS75T-8 can outperform "boutique" drivers that cost several times the price. The driver's truncated frame makes it ideal for line arrays and ultra-compact MTM designs requiring minimal driver-to-driver spacing. Its low-distortion characteristics and smooth response provide exceptional clarity, detail, and dynamics. Features a black anodized cone, heavy-duty 4-hole cast frame, low-loss rubber surround, and gold terminals.
  • Nominal Diameter3"
  • Power Handling (RMS)15 Watts
  • Power Handling (max)30 Watts
  • Impedance8 ohms
  • Frequency Response170 to 20,000 Hz
  • Sensitivity84.3 dB 2.83V/1m
  • Voice Coil Diameter0.63"
  • Resonant Frequency (Fs)189 Hz
  • DC Resistance (Re)6.1 ohms
  • Voice Coil Inductance (Le)0.32 mH
  • Mechanical Q (Qms)5.84
  • Electromagnetic Q (Qes)1.13
  • Total Q (Qts)0.95
  • Compliance Equivalent Volume (Vas)0.01 ft.³
  • Mechanical Compliance of Suspension (Cms)0.69 mm/N
  • BL Product (BL)2.58 Tm
  • Diaphragm Mass Inc. Airload (Mms)1g
  • Maximum Linear Excursion (Xmax)1.3 mm
  • Surface Area of Cone (Sd)12 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter2.83"
  • Baffle Cutout Diameter2.13"
  • Depth1.52"
  • Bolt Circle Diameter2.52"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3175.2 Hz
  • Vented Volume0.05 ft.³
  • Vented F396 Hz
  • BrandDayton Audio
  • ModelRS75T-8
  • Part Number295-336
  • UPC844632086274
  • Product CategoryWoofers
    (1 Reviews)
  • Weight0.6 lbs.
View similar products to the Dayton Audio RS75T-8 3" Reference Full-Range Driver Truncated Frame
