Dayton Audio RS180S-8 7" Reference Shielded Woofer 8 Ohm
Brand:|Model: RS180S-8|Part # 295-364
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price.
OUT OF STOCK
Due In: 3/29/2016
List Price$58.99
You Save23%
$45.32
Buy 4+$43.16
Part # 295-364
  • Long-excursion motor and suspension for strong bass performance
  • Subtle yet high-tech look makes a bold cosmetic statement
  • Ultra-low stray magnetic field allows extremely close proximity to CRT's
  • Designed and engineered in the U.S.A.
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofers feature a shielded motor system, black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, and solid aluminum phase plug.
  • Nominal Diameter7"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)120 Watts
  • Impedance8 ohms
  • Frequency Response41 to 3,600 Hz
  • Sensitivity86.9 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)37.7 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)0.79 mH
  • Mechanical Q (Qms)1.45
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.36
  • Compliance Equivalent Volume (Vas)0.812 ft.³
  • Mechanical Compliance of Suspension (Cms)1.05 mm/N
  • BL Product (BL)7.28 Tm
  • Diaphragm Mass Inc. Airload (Mms)17g
  • Maximum Linear Excursion (Xmax)6 mm
  • Surface Area of Cone (Sd)124.7 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.11"
  • Baffle Cutout Diameter5.75"
  • Depth3.86"
  • Bolt Circle Diameter6.63"
  • # Mounting Holes6
  • Sealed Volume0.22 ft.³
  • Sealed F388 Hz
  • Vented Volume0.49 ft.³
  • Vented F350 Hz
  • BrandDayton Audio
  • ModelRS180S-8
  • Part Number295-364
  • UPC844632000331
  • Product CategoryWoofers
    (35 Reviews)
  • Weight5.5 lbs.
View similar products to the Dayton Audio RS180S-8 7" Reference Shielded Woofer 8 Ohm
Dayton Audio RS180S-8 7" Reference Shielded Woofer 8 Ohm is rated 4.6 out of 5 by 35.
Rated 5 out of 5 by from Impressive: bigger sound than sizeI built a set of speakers based on Paul Carmody's Amiga using this woofer, and I have to say I'm amazed by this woofer. Given a decent sized ported enclosure, they offer great excursion and deep yet tight bass. With two of these up and going I see no reasonable need for a sub on this system.Everything up to the tweeter crossover point remains tight and clean. There are a few issues with this woofer that can easily be handled with a crossover, so I see no need to spend a ton more on a driver to get something worthwhile.
Date published: 2015-01-23
Rated 4 out of 5 by from Very smooth soundingPurchased a pair of these for a kit I was building. One arrived defective and had to be sent back. After receiving the replacement and installing with my custom made crossover, I must say, these are some smooth sounding speakers! Just remember, the key to great sound is with the right crossover design. There's two peaks at 6k and 9k and if not dealt with will have an unpleasant sound.
Date published: 2014-12-07
Rated 5 out of 5 by from 6+ Years Later - Still AmazingWhen I chose the MTM project to build, I wanted power, precision and durability in a package I could afford. Well, I got it. Critical listening sessions, home theater, PC gaming, loud parties... these drivers have delivered on all fronts, every day, often for 5+ hours a day. The heart of the system is, I feel still the crossover. However, without such excellent drivers the project would not have been nearly as satisfactory.This is a driver that's gotten the job done for me for years, at a very reasonable cost. I'm not sure what more one could ask for. At this size, in the do-all woofer category this is the high water mark.
Date published: 2012-07-14
Rated 5 out of 5 by from Great sound and value and attractive speakerThis is a substantial speaker that sounds excellent, at a great value. What more could you want in a mid-woofer of this size? I have used them for the past 5 years in an MTM design and couldn't be more pleased. I'm using 2 of them per speaker in a ported and braced 1 cu. ft. enclosure with a 4th order crossover network and in conjunction with the RS-28F tweeter. Great low frequency response (especially for a 7" driver) and clear, articulate and non-colored midrange. Had to recently replace one because of my error (accidentally sent massive amounts of distortion through them, on two occasions, when I turned off my tube pre-amp/DAC before turning off the DIY amp. Duh! As a testament to the durability of these speakers, only one of the 4 woofers and neither of the RS28F tweeters blew out). I was pleased to see that the replacement looked and sounded exactly the same as the original purchased so long ago.
Date published: 2012-03-08
Rated 5 out of 5 by from Exceptional valueLow distortion, clean sound, excellent build quality, bucking magnet, easy T-S params to deal with. The result in a correctly designed enclosure is far better than what you can expect for the money. Or anyway, what you could have expected before this driver came out. The 8" is great, too. Total steal.
Date published: 2011-09-23
Rated 4 out of 5 by from Solid speaker.4 years and still sounding strong as a satellite replacement in some Cerwin Vega SAT6's. They actually seem to take a little more power than rated, high pass crossover 6db 120Hz; powered by Adcom GFA-555. Very happy with this purchase.
Date published: 2010-08-11
  • 2016-02-09T06:22CST
  • co_hasreviews, tv_0, tr_35
  • loc_en_US, sid_295-364, PRD, sort_mostRecent
What is the distance from one mounting hole to the other mounting hole directly across? Thanks!
Asked by: drumsandcymbals
The bolt circle on this is 168.5mm (6.63 inches)
Answered by: Chrisf
Date published: 2016-01-26
I want to use 2 of this kind in a 3 way set up as woofers, will my crossover work with a points  are 1300hz and 4500hz with a 12db slope
Asked by: dannyrey77
This requires a bit more information in order to proceed. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-02-25
I have a pair of CR95 boston speakers ,I need to replace a woofer ,would the dayton audio RS180s-8-7" work for me ,If not what do you suggest,Thanks.
Asked by: derrick1
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-12-31
I have a pair of cr 95 boston speakers , I need to replace one ,would this be a good replacement,thanks.
Asked by: derrick1
I'm looking for a 7" mid woof for a Mission 700  two way from the '80s. The Mission's are 6ohm but all the 7" 6ohm options are too expensive.  Would a 8 work ok as a replacement or would the internal c/o blow it or my 50 watt amp?
Asked by: mission Impossible
Edit to above question:I want to know if I can replace the 7" 6ohm speaker with a 7" 8ohm speaker.
Answered by: mission Impossible
Date published: 2014-10-09
Hi Apart from the RS722 speakers, are there any two way projects which could use this woofer paired with the Dayton DC28 or Dayton RS28 tweeter? And would the Dayton XO2W-2K crossover be OK? My amp can't cope with4 ohms. Thank you Geoff
Asked by: Hobi
Date published: 2014-10-07
  • 2016-02-09T07:00CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_295-364, PRD, sort_recentQuestionsFirst
