Dayton Audio RS150T-8 6" Reference Woofer Truncated Frame
Brand:|Model: RS150T-8|Part # 295-342
Dayton Audio Reference Series RS150T-8 6" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
List Price$47.99
You Save24%
Buy 4+$34.63
Part # 295-342
  • Truncated cast frame - great for line arrays and MTM speaker designs
  • Long-excursion motor and suspension for strong bass performance
  • Advanced low-distortion motor design
  • Lightweight black anodized aluminum cone
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofer features a black anodized cone, heavy-duty cast frame, low-loss rubber surround, solid aluminum phase plug, rubber magnet boot, and gold terminals.
  • Nominal Diameter6"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance8 ohms
  • Frequency Response47 to 4,200 Hz
  • Sensitivity87.9 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)46.4 Hz
  • DC Resistance (Re)6.2 ohms
  • Voice Coil Inductance (Le)0.61 mH
  • Mechanical Q (Qms)1.67
  • Electromagnetic Q (Qes)0.47
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)0.51 ft.³
  • Mechanical Compliance of Suspension (Cms)1.42 mm/N
  • BL Product (BL)5.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)8.3g
  • Maximum Linear Excursion (Xmax)4 mm
  • Surface Area of Cone (Sd)85 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.12" across flats, 5.91"
  • Baffle Cutout Diameter4.78"
  • Depth2.79"
  • Bolt Circle Diameter5.43"
  • # Mounting Holes4
  • Sealed Volume0.13 ft.³
  • Sealed F3101 Hz
  • Vented Volume0.31 ft.³
  • Vented F358 Hz
  • BrandDayton Audio
  • ModelRS150T-8
  • Part Number295-342
  • UPC844632067655
  • Product CategoryWoofers
    (4 Reviews)
  • Weight2.6 lbs.
View similar products to the Dayton Audio RS150T-8 6" Reference Woofer Truncated Frame
