Dayton Audio RS150-8 6" Reference Woofer
Brand:|Model: RS150-8|Part # 295-354
Dayton Audio Reference Series RS150-8 6" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
List Price$51.99
You Save24%
$39.45
Buy 4+$37.23
Part # 295-354
  • One of the lowest distortion, highest resolution driver series available
  • Low-distortion high-excursion motor system with two short-circuit paths
  • Compliant suspension and rigid black anodized aluminum cone for strong bass performance
  • Heavy-duty 6-hole cast frame, low-loss rubber surround, and solid aluminum phase plug
  • Designed and engineered in the USA
The Dayton Audio Reference Series was conceived with one goal in mind—low distortion. Each speaker was carefully designed and optimized to offer the highest performance with the lowest distortion levels. At the same time, by focusing on features that contribute to sound quality and eliminating unnecessary frills, the drivers offer value unparalleled in the industry. Dayton Audio Reference Series RS150-8 6" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
  • Nominal Diameter6"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance8 ohms
  • Frequency Response47 to 4,200 Hz
  • Sensitivity88.7 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)47.8 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.55 mH
  • Mechanical Q (Qms)1.66
  • Electromagnetic Q (Qes)0.43
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)0.59 ft.³
  • Mechanical Compliance of Suspension (Cms)1.63 mm/N
  • BL Product (BL)5.59 Tm
  • Diaphragm Mass Inc. Airload (Mms)7.4g
  • Maximum Linear Excursion (Xmax)4 mm
  • Surface Area of Cone (Sd)85 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.91"
  • Baffle Cutout Diameter4.78"
  • Depth2.89"
  • Bolt Circle Diameter5.43"
  • # Mounting Holes6
  • Sealed Volume0.1 ft.³
  • Sealed F3116 Hz
  • Vented Volume0.26 ft.³
  • Vented F368 Hz
  • BrandDayton Audio
  • ModelRS150-8
  • Part Number295-354
  • UPC844632088742
  • Product CategoryWoofers
    (6 Reviews)
  • Weight3.55 lbs.
View similar products to the Dayton Audio RS150-8 6" Reference Woofer
