Dayton Audio RS150-4 6" Reference Woofer 4 Ohm
Brand:|Model: RS150-4|Part # 295-372
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Woofer features a black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, solid aluminum phase plug, and gold terminals.
List Price$46.99
You Save24%
$35.62
Buy 4+$33.99
Part # 295-372
  • 4 ohm impedance is perfect for series pairs in MTMs and center channel speakers
  • Excellent car audio midrange/midbass
  • High-end low-distortion motor with two shorting paths to reduce inductance
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofer features a black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, solid aluminum phase plug, and gold terminals.
  • Nominal Diameter6"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance4 ohms
  • Frequency Response48 to 4,000 Hz
  • Sensitivity91.8 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)45.1 Hz
  • DC Resistance (Re)3.1 ohms
  • Voice Coil Inductance (Le)0.34 mH
  • Mechanical Q (Qms)1.96
  • Electromagnetic Q (Qes)0.40
  • Total Q (Qts)0.33
  • Compliance Equivalent Volume (Vas)0.579 ft.³
  • Mechanical Compliance of Suspension (Cms)1.62 mm/N
  • BL Product (BL)4.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)7.7g
  • Maximum Linear Excursion (Xmax)4.4 mm
  • Surface Area of Cone (Sd)85 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.91"
  • Baffle Cutout Diameter4.78"
  • Depth2.76"
  • Bolt Circle Diameter5.43"
  • # Mounting Holes6
  • Sealed Volume0.123 ft.³
  • Sealed F3114 Hz
  • Vented Volume0.256 ft.³
  • Vented F369 Hz
  • BrandDayton Audio
  • ModelRS150-4
  • Part Number295-372
  • UPC844632054235
  • Product CategoryWoofers
    (21 Reviews)
  • Weight2.8001 lbs.
View similar products to the Dayton Audio RS150-4 6" Reference Woofer 4 Ohm
