Dayton Audio RS125T-8 5" Reference Woofer Truncated Frame
Brand:|Model: RS125T-8|Part # 295-340
Utilizing an advanced motor system and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price.
List Price$42.99
You Save24%
$32.74
Buy 4+$29.98
Part # 295-340
  • Truncated cast frame, great for line arrays and MTM speaker designs
  • Long-excursion motor and suspension for strong bass performance
  • Advanced low-distortion motor design
  • Distortion-reducing copper ring in magnetic gap
  • Lightweight black anodized aluminum cone
  • Designed and engineered in the U.S.A.
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing an advanced motor system and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofer features a black anodized cone, heavy-duty cast frame, low-loss rubber surround, solid aluminum phase plug, distortion-reducing magnetic gap copper ring, rubber magnet boot, and gold terminals.
  • Nominal Diameter5"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response75 to 9,200 Hz
  • Sensitivity86.9 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)76 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)0.58 mH
  • Mechanical Q (Qms)2.62
  • Electromagnetic Q (Qes)0.61
  • Total Q (Qts)0.50
  • Compliance Equivalent Volume (Vas)0.13 ft.³
  • Mechanical Compliance of Suspension (Cms)0.87 mm/N
  • BL Product (BL)5.04 Tm
  • Diaphragm Mass Inc. Airload (Mms)5.1g
  • Maximum Linear Excursion (Xmax)2.8 mm
  • Surface Area of Cone (Sd)54.1 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.94"; across flats 4.06"
  • Baffle Cutout Diameter3.7"
  • Depth2.17"
  • Bolt Circle Diameter4.43"
  • # Mounting Holes4
  • Sealed Volume0.008 ft.³
  • Sealed F3209 Hz
  • Vented Volume0.06 ft.³
  • Vented F3106 Hz
  • BrandDayton Audio
  • ModelRS125T-8
  • Part Number295-340
  • UPC844632079795
  • Product CategoryWoofers
    (2 Reviews)
  • Weight1.95 lbs.
View similar products to the Dayton Audio RS125T-8 5" Reference Woofer Truncated Frame
