Dayton Audio RS125-8 5" Reference Woofer
Brand:|Model: RS125-8|Part # 295-353
Dayton Audio Reference Series RS125-8 5" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
List Price$40.99
You Save23%
$31.57
Buy 4+$30.07
Part # 295-353
  • One of the lowest distortion, highest resolution driver series available
  • Low-distortion high-excursion motor system with two short-circuit paths
  • Compliant suspension and rigid black anodized aluminum cone for strong bass performance
  • Heavy-duty 6-hole cast frame, low-loss rubber surround, and solid aluminum phase plug
  • Designed and engineered in the USA
The Dayton Audio Reference Series was conceived with one goal in mind—low distortion. Each speaker was carefully designed and optimized to offer the highest performance with the lowest distortion levels. At the same time, by focusing on features that contribute to sound quality and eliminating unnecessary frills, the drivers offer value unparalleled in the industry. Dayton Audio Reference Series RS125-8 5" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
  • Nominal Diameter5"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)50 Watts
  • Impedance8 ohms
  • Frequency Response65 to 5,400 Hz
  • Sensitivity86.8 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)59.2 Hz
  • DC Resistance (Re)6.2 ohms
  • Voice Coil Inductance (Le)0.57 mH
  • Mechanical Q (Qms)1.74
  • Electromagnetic Q (Qes)0.42
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)0.17 ft.³
  • Mechanical Compliance of Suspension (Cms)1.22 mm/N
  • BL Product (BL)5.69 Tm
  • Diaphragm Mass Inc. Airload (Mms)5.9g
  • Maximum Linear Excursion (Xmax)4 mm
  • Surface Area of Cone (Sd)52.8 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.94"
  • Baffle Cutout Diameter3.7"
  • Depth2.17"
  • Bolt Circle Diameter4.43"
  • # Mounting Holes6
  • Sealed Volume0.07 ft.³
  • Sealed F3162 Hz
  • Vented Volume0.1 ft.³
  • Vented F391 Hz
  • BrandDayton Audio
  • ModelRS125-8
  • Part Number295-353
  • UPC844632088735
  • Product CategoryWoofers
    (7 Reviews)
  • Weight2.15 lbs.
View similar products to the Dayton Audio RS125-8 5" Reference Woofer
