Dayton Audio RS125-4 5" Reference Woofer 4 Ohm
Brand:|Model: RS125-4|Part # 295-370
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Woofer features a black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, solid aluminum phase plug, and gold terminals.
List Price$41.99
You Save24%
$31.96
Buy 4+$30.51
Part # 295-370
  • 4 ohm impedance is perfect for series pairs in MTMs and center channel speakers
  • Excellent car audio midrange/midbass
  • High-end low-distortion motor with two shorting paths to reduce inductance
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofer features a black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, solid aluminum phase plug, and gold terminals.
  • Nominal Diameter5"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance4 ohms
  • Frequency Response65 to 5,400 Hz
  • Sensitivity89.9 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)57.2 Hz
  • DC Resistance (Re)2.9 ohms
  • Voice Coil Inductance (Le)0.28 mH
  • Mechanical Q (Qms)2.04
  • Electromagnetic Q (Qes)0.45
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)0.187 ft.³
  • Mechanical Compliance of Suspension (Cms)1.35 mm/N
  • BL Product (BL)3.63 Tm
  • Diaphragm Mass Inc. Airload (Mms)5.7g
  • Maximum Linear Excursion (Xmax)4 mm
  • Surface Area of Cone (Sd)52.8 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.94"
  • Baffle Cutout Diameter3.7"
  • Depth2.13"
  • Bolt Circle Diameter4.43"
  • # Mounting Holes6
  • Sealed Volume0.05 ft.³
  • Sealed F3139 Hz
  • Vented Volume0.12 ft.³
  • Vented F379 Hz
  • BrandDayton Audio
  • ModelRS125-4
  • Part Number295-370
  • UPC844632056321
  • Product CategoryWoofers
    (14 Reviews)
  • Weight2.6 lbs.
View similar products to the Dayton Audio RS125-4 5" Reference Woofer 4 Ohm
