Dayton Audio RS100T-8 4" Reference Woofer Truncated Frame
Brand:|Model: RS100T-8|Part # 295-338
Utilizing an advanced motor system and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price.
List Price$39.99
You Save23%
$30.80
Buy 4+$28.37
Part # 295-338
  • Truncated cast frame, great for line arrays and MTM speaker designs
  • Long-excursion motor and suspension for strong bass performance
  • Advanced low-distortion motor design
  • Extended, linear response
  • Distortion-reducing copper ring in magnetic gap
  • Lightweight black anodized aluminum cone
  • Designed and engineered in the U.S.A.
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing an advanced motor system and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofer features a black anodized cone, heavy-duty cast frame, low-loss rubber surround, solid aluminum phase plug, distortion-reducing magnetic gap copper ring, rubber magnet boot, and gold terminals.
  • Nominal Diameter4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response90 to 20,000 Hz
  • Sensitivity87 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)94.9 Hz
  • DC Resistance (Re)6.5 ohms
  • Voice Coil Inductance (Le)0.5 mH
  • Mechanical Q (Qms)2.40
  • Electromagnetic Q (Qes)0.79
  • Total Q (Qts)0.60
  • Compliance Equivalent Volume (Vas)0.08 ft.³
  • Mechanical Compliance of Suspension (Cms)1.3 mm/N
  • BL Product (BL)3.27 Tm
  • Diaphragm Mass Inc. Airload (Mms)2.2g
  • Maximum Linear Excursion (Xmax)3.7 mm
  • Surface Area of Cone (Sd)36.3 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter3.86"
  • Baffle Cutout Diameter3.03"
  • Depth2.01"
  • Bolt Circle Diameter3.54"
  • # Mounting Holes4
  • Sealed Volume.105 ft.³
  • Sealed F3124.8 Hz
  • Vented Volume0.12 ft.³
  • Vented F377 Hz
  • BrandDayton Audio
  • ModelRS100T-8
  • Part Number295-338
  • UPC844632079788
  • Product CategoryWoofers
    (3 Reviews)
  • Weight1.4 lbs.
View similar products to the Dayton Audio RS100T-8 4" Reference Woofer Truncated Frame
