Dayton Audio RPH20 20" Round PA Horn
Brand:| Model: RPH20
Affordable, durable horns for demanding sound reinforcement applications.
  • Large horn mouth extends response to lowest possible frequency
  • Weatherproof aluminum construction
  • Stainless steel hardware for long service life
  • Suitable for indoor or outdoor installations
  • Standard 1-3/8"-18 threaded throat
300-196
Weight: 7.2500 lbs.
IN STOCK
List Price$38.99
You Save49%
$19.97
Buy 4-up$18.86
Part # 300-196
Affordable, durable horns for demanding sound reinforcement applications. The re-entrant style horn flare design provides an expansion path that is longer than conventional straight horns; this ensures that the lowest possible frequency response can be achieved. The Dayton Audio RPH-20 PA horns are formed from lightweight aluminum and painted with a durable polyester finish, so you know that they will survive years of exposure to sun and rain. Great for indoor or outdoor applications, sturdy mounting yoke for precise alignment included. Standard 1-3/8"-18 threaded throat; 20" mouth diameter, 13" depth.
  • BrandDayton Audio
  • ModelRPH20
  • Part Number300-196
  • UPC844632008030
  • Product CategoryPA Horns
    (4 Reviews)
  • Weight7.2500 lbs.
View similar products to the Dayton Audio RPH20 20" Round PA Horn
in the PA Horns product category.
Dayton Audio RPH20 20" Round PA Horn is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from Very controlled patternI recently installed 4 of these to cover the stands at a raceway. they covered the area well where they were directed, but even a few degrees off axis they attenuate rapidly. Be sure to plan your installation for the roughly 60 degree sweet spot. They are quite efficient, so moving them back works well if you need more coverage.
Date published: 2014-03-29
Rated 5 out of 5 by from Excelent value, Incredible performance.When I plan to install a public adress system, I usually go and order one of the speakers that we choose before we really go through with it . mainly to see if its cut out for the job, and this one is great. The performance with vintage University sound drivers is great.I am keeping this one. the 5 others, I will install.The horn has good construction. The only bad thing is, the bolts supplied were too short, but I have some and it worked out fine. the sound is alot deeper that the old rusty originals. very clean.
Date published: 2011-09-30
Rated 4 out of 5 by from DuckworkI used two of these with the Dayton 75 watt drivers. Sound is good and clean, efficient with little power needed, fine with low power amps. I had a little trouble with the U-shaped mount, the bolts supplied were too short, requiring a Lowes run to get longer bolts. Metric bolts were supplied but I found that 3/8" x 1-1/4" from Lowes worked fine. I plan to glue the little plastic inserts into the horns to keep them from turning when the bolts are tightened. If you're willing to put up with these problems, you'll have some nice outdoor horns for half the price of name brands.
Date published: 2011-09-03
Rated 4 out of 5 by from Great for the money!I coupled this horn with the Dayton D1075T and installed 4 in a local football stadium. Impressive frequency response for a pa horn! On the first test we got a clean echo from a tree line about 500+ yards away at half volume. Need I say anymore?
Date published: 2010-09-13
  • 2015-01-29T18:49CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_300-196, PRD, sort_mostRecent
what is the coverage pattern for this horn
A general purpose, average - e.g. 80x80 - would be OK, actual graphs at different frequencies would be better.
Asked by: taco66
Up to about 90 degrees.
Answered by: Local Critic
Date published: 2012-04-28
What is the lowest frwquency cut-off?
Asked by: SpeakerFreak95
usually with driver 1"3/8 it's difficult to down at 400/500hzthe horn with 20" cut about 290hz.a driver with this horn has a bell curve between 800 to 2200hz, and down to 300/400hz with big attenuation.It's made for outside comprehension speak, against windand rain..
Answered by: alzin5342
Date published: 2014-05-20
  • 2015-01-29T20:45CST
  • loc_en_US, sid_300-196, PRD, sort_recentQuestionsFirst
Customer projects that include: Dayton Audio RPH20 20" Round PA Horn
